ferro rod
Discussion in 'Bushcraft' started by Huntinbull, Jun 6, 2011.
Register to hide advertisements
  1. Huntinbull
    Offline
    Huntinbull Monkey
    Looking for opinions on ferro rods. Would like hands on opinions only. Have bought other rods that people "heard were good" and had them fall apart, lose their strike-ability, etc.
    What ferro rod do you use and recommend? I have 1800's style flint and steel, and enjoy it, but looking for more wet reliability.
    Thanks
  2. Hispeedal2
    Offline
    Hispeedal2 Nay Sayer
    I currently use a Light My Fire.
    I have bought several of various sizes from firesteel.com
    My first impressions are good. I have one I set aside to test. The others are stashed. It appears to do everything my LMF ferro rods do (so far). Their strikers kick butt too and save your knife blade.
    ETA: I did a bit of research before I decided. The other place you could go is goinggear.com. The reason I chose firesteel.com is they seemed to have slightly better, more consistent reviews.
    Example: http://jungletraining.com/forums/showthread.php?t=5615
  3. Huntinbull
    Offline
    Huntinbull Monkey
    Thanks for the info. Great website. Might order me a couple on payday. Any experience with the handles coming loose or falling off the rods? That is my biggest peev with ferro rod kits. With a 4inch firesteel I could bypass a handle at all.
  4. Brokor
    Offline
    Brokor OPSEC ENABLED Site Supporter
    Nah. I'm not saying it can't happen, but it's never happened to me. You will most likely wear through your ferro long before the handle separates.
    The firesteel mini's are great "light my fire" type, works well.
  5. Hispeedal2
    Offline
    I have not seen a handle fall off. My LMF ones have handles. The ones I ordered from firesteels.com do not have handles- just drilled for a lanyard. A handle isn't really needed assuming you get one of a decent size. The other advantage to no handle is the ability to turn it around if you start getting less "sparkage" on the normal striking end.
    The lanyard holes are nice. I put a piece of 550 cord long enough to make a couple friction fire sets through the hole for a lanyard. I also attach the striker and a piece of fatwood to the lanyard. The length is important. If you make it about 4-5' long-
    1) You have back up cordage (like previously mentioned, you can make several friction fire bows as a back up or for rod preservation)
    2) It allows you to sling your whole fire making kit around your body
    3) It keeps your whole fire making kit together so you are less likely to lose a single item
    4) You have enough cordage to use every item without removing them from the cord
    If you want to handle your own, I would say that a strong epoxy will keep em' in there longer than the rod will last....btw....on how long they last....
    I just now finished up my first Army Model LMF after some 4 years. That includes hundreds of different fires and I'd say thousands of practice (show off) strikes. I couldn't even begin to make an estimate on number of strikes. When I took it on my last deployment, my teammates got a kick out of using it to start our morale fires. We uses it at least weekly for the entire deployment, not to mention the hundreds of times they played with it the rest of the week. Most were sold. The ones who weren't couldn't start a fire with a pile of newspaper, dry kindling, and a Bic. JK. Really though, the difference in those that became good with it and those that weren't is in the preparations they made. In that year, I can't think of a single time I failed to make fire when using my own prep. Hence the fatwood comment from above ^
  6. sticks65
    Offline
    sticks65 Monkey+
    Lightmyfire are good.
  7. Huntinbull
    Offline
    Huntinbull Monkey
    Thanks all for the input. Looking into both the LMF and the firesteel.com units. Maybe the wife will get the hint for father's day?!?!
  8. Radar00
    Offline
    Radar00 Monkey
    I think this mini inferno stuff is interesting- although I havent tried it myself
    i use the magnesium firesteels- I think theyre better than the swedish stuff‬‏
  9. Huntinbull
    Offline
    Huntinbull Monkey
    That Mini Inferno stuff does seem to do the job. think i might try getting vaseline dipped cotton balls wet and see what happens. Never tried that, but probably should.
  10. SurviveN
    Offline
    SurviveN Monkey
    ultimate technologies strikeforce. Nice carring case, comes with striker, showers sparks and holds tinder. I have two in my BOB, one goes around my neck with my mora and one in my cook kit. LMF are good as well. but the SF is the best In my opinion. either will get the job done tho.
Share This Page
Null
Locations of visitors to this page
Find us on Google+
