AR -15 Firing help needed.
Discussion in 'Humor - Jokes - Games and Diversions' started by Salted Weapon, Jun 1, 2016.
  1. Salted Weapon
    Salted Weapon Monkey+++
    Need some technical help Monkeys:
    And and all help appreciated seemed quite a deal for only 25.00 so I bought two more extras if anyone is interested ???
    foosedNO!!
  2. Bishop
    Bishop Monkey+++
    Lol think you might need a hammer to get it in
  3. ghrit
    Get out some files and go to work. You'll need to heat treat it when filed to fit --
    Salted Weapon likes this.
  4. Oltymer
    Oltymer Monkey++
    I'll take two of them, got some gutters coming loose...
    Salted Weapon and Yard Dart like this.
  5. RightHand
    It sounds like you bought just the firing pin and not the bolt carrier group. This is just a rough sketch, not a production drawing. We're doing a run of about 40K AR15 firing pins right now.
    AR_firing_pin.
  6. Yard Dart
    Have you matched it up side by side with another AR15 pin? The pic does not give enough detail such as measurements. Bottom line is, if it don't fit... you been had.
  7. RightHand
    There are variations depending of mfg specs. An Armalite may not have the same spec as a Stag
  8. AD1
    AD1 Monkey+++
    Run some extra....my birthday was last week [touchdown]
  9. RightHand
    Sorry AD1 - these are under contract. I can't even divulge the customer's name
    Salted Weapon, sec_monkey and AD1 like this.
  10. AD1
    AD1 Monkey+++
    Hey what machine shop dosent make a over run....just in case. As long as you dont charge them for the xtras.
    Salted Weapon and Tully Mars like this.
  11. ghrit
    Is not mil spec?
  12. Yard Dart
    That is a hell of a question....
    @RightHand are you suggesting that my Stag will not take a pin that I bought for my Colt's. I have not tried that with my excess supplies... since they are all mil spec and assumed to be "universal".
  13. 3M-TA3
    Depends, @Yard Dart - did you buy 8 penny or 10 penny BCGs?
    Interesting that I bought my firing pins separate from the rest of the BCG's on my piston builds and they worked fine. I assumed the same as you. Perhaps if I knew better they wouldn't have worked?
    Salted Weapon, svjoe, Taku and 3 others like this.
  14. RightHand
    They probably will but unless not guaranteed. A couple issues come into play. Every parts has a dimensional tolerance. Come may be made on the low side, some on the high side. they most likely will work with no problems. However, there are also tolerances with the bolt bolt that effects the firing pin. the firing pin made for the M16 has a larger collar. Even with Mil Spec parts, there can be subtle differences. the parts can usually be "massaged" and will fit fine but there can be differences
  15. Tempstar
    Tempstar Monkey+++
    LOL. Good job Salted! Ya got a couple of 'em!
  16. svjoe
    svjoe Angry Monkey
    If you use this during assembly, it just might work out............
    hammer.
  17. marlas1too
    marlas1too Monkey+++
    boy did they see you coming--what you bought is what we called in my time is a stage nail a 2 headed nail made to be removed quick and it seems to be a 16 penny one too lol
    T. Riley likes this.
  18. ghrit
    For those that don't know:
    A stage nail is used for assembling temporary wood things like, (and especially) staging (which is more likely known as scaffolding.) In some jurisdictions they are illegal because the extended head can catch on people or stuff carrried or worn while working on the scaffolding. People have lost jobs for using them. Even where legal, it is best to drive them flush as a safety measure. Uv cuss, that sorta makes the extra head useless --
    (And I'd still like to see someone file out an AR firing pin from wunna dem tings.)
    AD1 likes this.
  19. OldDude49
    n here I was gettin all readys to be sellin some real estate to this person... [winkthumb]
    Witch Doctor 01 likes this.
  20. kellory
    They are very useful for pinning double sash wood windows in place. With a hole drilled just larger than the nail diameter, they go through both sashes, and the double head makes them easy to adjust.
    I use them to lock window air conditioners in place, or set a window for a small gap ventilation.
