I had never heard of this. Pretty neat idea. We have occasional power outages here but they were very frequent where I last lived. This could save you some guess work. If you’re committed to a lifestyle of homesteading and prepping, there’s a good chance that you own a freezer that’s fully stocked with the essentials. From meat to vegetables, you might have thousands of dollars’ worth of food socked away in your freezer. If you’re prepping, don’t rely solely on freezing your food. Make sure you have a stockpile of long shelf-life foods, like canned goods and dehydrated foods, in your pantry as well. The freezer food should merely be an accompaniment. Freezing food for long-term storage is a great way to get ahead – but what do you do when a power outage threatens everything that’s inside? You can’t necessarily prevent or predict power outages, though having a functional generator and other emergency preparedness supplies can help. However, you can avoid the all-too-common guessing game that occurs during and after a power outage when you’re forced to ask yourself, “is this food safe to eat?” It all has to do with putting a coin in a cup of water in the freezer. It sounds simple, but this technique could help you save thousands of dollars – and help you keep safe in an emergency, too. Here’s why you should put a coin in a cup of frozen water in your freezer – and how to do it correctly. Why You Should Put A Coin In A Cup Of Frozen Water In Your Freezer When we focus on emergency preparedness and survival as preppers, we often think of how to stockpile food and how to make sure we have electricity even when the weather’s bad. However, very few of us think about how we’re going to keep that food safe in a storm. If you have a power outage – particularly a long one – there’s a good chance that the food in your refrigerator will spoil. That’s not always the case with a freezer, though – particularly a well-stocked one where the solidly frozen food serves as additional protection for all the rest. During a power outage, you might wonder how much your food has thawed – but opening up the freezer to check is a recipe for disaster since it will let warm air in and cause the food to thaw more quickly. Instead, you should wait until after the storm has ended. The problem with this is that you’ll never really know exactly how frozen or thawed the food was – and you won’t know whether it’s safe to eat. Enter – the coin in a cup of water trick. This is something you can do before a storm to help you know whether you can safely eat the food in your freezer. All you need to do is fill a cup with water. Put it in the freezer until it’s frozen solid. Then, place a quarter on top of it and put the cup back in the freezer. After the power outage, check the cup. If the quarter is still on top, your electricity didn’t go out for a significant amount of time and the food is likely safe to eat. If the quarter has sunk to the bottom, that indicates that the ice thawed completely and the power was out for quite some time. You should probably get rid of the contents of your freezer to avoid getting sick. And if it’s in the middle? It’s a toss-up. If your freezer is one that’s attached to your refrigerator (not a freestanding unit), you should get rid of the contents of your refrigerator if the coin is in the center. The frozen food is likely still okay, but the food in your fridge definitely is not. Remember, our ancestors did not actually have access to everything we do right now. Cowboys and their families struggled to keep their food fresh for longer periods of time, especially during tough winters. You'll never guess the ingenious method they used to cool foods from temperatures around 158 degrees F to freezing in under 90 minutes. Here's where you can find a step-by-step tutorial. What To Keep In Mind Although this method is mostly reliable, it’s not foolproof. There are some other variables that need to be considered here. For example, the size of your freezer plays a role in how much the ice in the cup melts, as does the position of the cup in the freezer. We recommend placing the cup in the spot of the freezer where it would be most likely to melt first (like the door rather than deep in the center of piles of frozen food). That way, even if the ice partially melts, you’ll still have a pretty good idea that your food is safe to eat. Ice is not as dense as water so the ice will float on the water it creates as it is melting. It’s possible that the ice could melt partially before refreezing and the coin would still be in the same position – but putting your cup in a more telling position will help you determine this. Of course, you’ll also need to consider how much other food is in the freezer and what the temperature inside the house is. These can impact how long it takes your food to freeze and thaw, too – and impact the reliability of the coin ice test. Keep Your Food Safe In any event, you should follow the Food and Drug Administration’s guidelines to keep the temperature of your freezer below zero degrees Fahrenheit and the refrigerator no higher than 40 degrees Fahrenheit whenever possible. You can freeze containers of ice water to help your food stay cooler longer in the refrigerator. If you have any refrigerated items that you won’t use immediately, put them in the freezer to help them last longer, even in a power outage. Remember, refrigerated food will stay safe as long as the door is kept shut and the power isn’t off for more than four hours. Frozen food usually stays frozen for 24 to 48 hours as long as the freezer is unopened. Some freezers can keep food cold even longer than that – up to five days, in some cases, and of course, depending on the conditions. Try putting a coin in a cup of frozen water long before a storm is forecasted. Do this today so you’re prepared for any power outage – especially if you’re living off the grid, you probably already know how common these can be! The coin in a cup of frozen water hack may not be perfect, but it’s still a great way to determine whether your food is safe to eat – or needs to be tossed. Give it a try so you’re prepared no matter what Mother Nature throws your way.
The article said you can add containers of water to help the food stay cold longer. Note some food such as ice cream or meat or things with sugar can actually start thawing at temps a bit less than 32 degF or 0 degC. So, ideally we want to keep the freezer colder than their thawing points. That is easy if you have some spare room. Line the inside walls of freezer with 2 liter bottles of frozen salt water. One gallon of water with one pound of salt added to it is very roughly a 10% brine (those are easy numbers to remember) and it will freeze/thaw at about roughly 20 degF or -6.5 decC. Fill the bottles only about 80% full and usually best to freeze them on their sides since water expands about 10% when it freezes. With a bunch of these bottles in the freezer, when the power goes out, and lets say the freezer was at 0F when that happened, then it will slowly warm up to 20F then plateau there until most of the saltwater has thawed (absorbing heat that has entered the freezer) before climbing again. If you have a genset or backup power for the freezer, when the temp in the freezer starts climbing above 20 or 25F, then turn on the genset and cool it back down refreezing the water jugs. You will likely run the genset longer at a time, but also much longer between runnings and the food stays at a more consistent lower temp which may help reduce freezer burn or texture compromises. You can also start refreezing when the bottles are say just half thawed facilitating a schedule that might be more easy to keep. Stay frosty. AT
If the nighttime temperatures are freezing you can put jugs of water out to freeze and in the morning put them in the frig to assist in keeping it cold. "Ice Box". Keeping the fridge full, even if it's water, is one way to of using less electricity in the long run, for those of you that are still on the grid.
Yep, taking advantage of freezing temperatures is good. Use salt water if you want to keep a freezer cold. Plain water ice is fine for a refrigerator. Keeping a frig or freezer full of stuff won’t reduce energy consumption in the long run, it will stay the same. The time for how long the compressor is off and then on will increase but the mass inside won’t have much affect on the overall heat transfer rates from outside to the inside of a freezer.
I thought the trick would be good for someone who was away for periods of time. Say you go on vacation for a week or two and when you get back you know the power was off due to the electric clocks being wrong and the clock on the microwave, VCR etc is flashing. But you don't know how long it was off. If the coin is at the bottom of the glass you know it was off for some time and your food is probably spoiled. I read somewhere that a freezer if the door is left closed would keep things frozen for about 3 days. Of course there are variables to that. How densely packed it is etc. That's why I like chest freezers over uprights. It keeps the cold, heavier air inside when you open the door.
Just load up all of grills and invite everyone you can think of to the cookout stressing that if you wait to long the beer will be warm Thermal Mass is your friend! If it going to thaw break out the pressure canners and jars and get to stepping. What is worse than canned meat??? NO MEAT!
with the investment $$$$$ - $100s if not $1000s involved - and now a critical asset that just might not be recoverable at any cost >>>> it pays to use TECHNOLOGY you need a simple alarm at the very least - plenty of people lost their freezer load because the plug got pulled by accident - most people don't use or check their storage freezer on a daily basis - and a day makes a difference in food recovery ..... from the simple temperature-triggered alarm you can get into systems that will not only locally alarm but give you a cell phone call and send an email that something has happened >>>> definitely an advantage if you travel and can get some local assist to save your food ..... I'd also give consideration to some extra insulation - eazy enough to build a foam board "box" around it (not over the compressor area!!!) and still maintain accessibility - not only good to extend the freezer longevity in an emergency but daily $$$$$ savings .....
I can remember my grandparents back in the day ,, when a bad storm came thru and knocked out the power ,, they'd go out to the freezers ,, pull out about 2 days or so worth of food ,, and throw a couple of grandma's old hand stitched quilts over the top of everything , and close the lid . Grandpa kept the 2 liter water bottles in there as well ,, as long as he didn't need the room for food .
