DIY barrel rifling
Discussion in 'Firearms' started by OldDude49, Mar 4, 2017.
  1. OldDude49
  2. oil pan 4
    Yeah it would work. A process like this is already being used by the OEMs.
    Dunerunner likes this.
  3. Airtime
    Airtime Monkey+++
    Interesting idea but consider a couple aspects:
    1. The area electrically eroded is not very smooth. This may smooth out with use but you would likely want to follow with some other machining process to improve the surface finish. Lacking that you would likely want to only shoot jacketed projectiles or it seems lead fouling could be a problem.
    2. Most rifling has lands that project into the bore as opposed to grooves cut outward into the bore. This allows for good engagement with the bullet to spin it. The bore's base diameter is comparable to the bullet's diameter so force required to move the bullet is the friction plus force to deform the bullet where the rifling lands are (that expands the bullet a tiny bit creating a good gas seal with barrel). This electro-machined barrel won't have good engagement with the bullet and will leak gas around it unless the base diameter of the barrel is smaller than the bullet. If that is the case, then more deformation of the bullet will be required to create that engagement. That will require more force and energy to squeeze the bullet smaller and cause it to bulge into the rifling groove. Initial pressures in the chamber will be higher and the barrel, chamber, bolt and receiver will need to be able to accommodate those. I suppose enough of the barrel could be eroded away to make a more conventional shaped rifle. Two issues with that is the base diameter of the barrel is now that rough surface and probably a secondary machining operation (such as broaching) would be desired to fix that. If that process is capable of being employed from the git-go then just skip this electro machining step. Secondly, it seemed the electro-machinist who wrote the article had some difficulty in predictably controlling the amount of material removed. Presumably with experience this could be overcome.
    With more development this may be a viable solution for very low volume needs (1 or 2 DIY units) but it seems a questionable process for higher production runs. Still quite interesting and creative.
    Thanks for the link. This might be a process I can use in the shop for other things.
    AT
  4. Tully Mars
    Like @Airtime mentioned, it is interesting and I know a couple of big outfits use this type of process, but for now I'll just continue to repurpose old barrels and order new blanks-until I am the proud owner of a used rifling machine. A machinist friend thinks he may have one located in southern Mississippi.
    Airtime, Dunerunner, Trouble and 2 others like this.
  5. Dunerunner
    I just thought I'd show everyone how my mind works... I read this thread as "DIY Barrel Refilling" and thought to myself how many fifths of whiskey it would take to fill a barrel and why would anyone want to do such a thing?
    Got me to read the thread, though..:censored:
    Pretty doggoned slick.
    Ura-Ki, Trouble, oldawg and 4 others like this.
  6. Tully Mars
    [fnny][booze]
    Altoidfishfins likes this.
  7. Altoidfishfins
    There are places where you can get therapy for that, Dunerunner.
    :lol::lol::lol:
    Ura-Ki likes this.
  8. Ura-Ki
    Interesting look. I would make a mandrel my self maybe using this process, and rifle my barrels the old fashioned way by cutting the rifling from a core. Cut Rifling is considered the most accurate method devised, and the rifles accuracy will be better as well. Now for that Old Pratt and Whitney Sine Bar Riffling Machine I have been wanting.
    Tully Mars likes this.
  9. ghrit
    Electrochemical machining is not at all unknown, and this is an interesting application. One thing that stands out as can be seen in the five groove pic, is that the grooves are very rough. This is pitting, which is all that "normal" pitting in a barrel really is, and is directly related to what's in the steel alloy and how the grain structure develops during the barrel making process. Controlled rusting if you will. I can see it could be fun to mess around with, but I'd be wary of the loads sent down that barrel (the groove depth is apt to be non uniform ---)
  10. DarkLight
  1. Witch Doctor 01
  2. oil pan 4
  3. Tully Mars
  4. GOG
  5. 10brokenpromises
  6. 10brokenpromises
  7. 10brokenpromises
  8. 10brokenpromises
  9. 10brokenpromises
  10. 10brokenpromises
  11. 10brokenpromises
  12. 10brokenpromises
  13. 10brokenpromises
  14. AD1
  15. TailorMadeHell
  16. stg58
  17. VisuTrac
    [MEDIA]
    Thread by: VisuTrac, Feb 11, 2015, 5 replies, in forum: Firearms
  18. Dont
  19. Dont
