Gear Review Kestrel 2500NV Pocket Weather Meter
Discussion in 'Functional Gear & Equipment' started by stg58, Oct 5, 2013.
  1. stg58
    I picked up the Kestrel 2500NV in late spring and used quite a bit for camping and biking. A bit of overkill for my uses but it works well and it is waterproof:) plus
    NK_USA.
    The Kestrel Meter 2500 Meter Measures/Features
    • Current Wind Speed
    • Maximum Wind Gust
    • Average Wind Speed
    • Air, Water & Snow Temperature
    • Wind Chill
    • Barometric Pressure
    • Altitude
    • Real-time clock
    • Protective cover with sure-grip overmolding
    • Data hold function
    • Large easy-to-read display with backlight
    • Waterproof and floats
    • Innovative design for stability and accuracy in abrupt condition changes
    • Patented user-replaceable impeller
    • Quick response, external thermistor
    • High precision pressure sensor
    • Reliable, portable and easy to use
    • All instruments and accessories are completely assembled in the USA
    • Particularly handy for military applications with its night-vision preserving backlight
    • Accurately measures wind and temperature; includes air pressure sensor for altitude and barometric information.
    • Enables you to follow changes in air pressure that help predict impending changes in the weather
    • User-replaceable CR2032 coin cell battery; 5-year warranty
    1334755366-27302100.
    Kestrel Meters - Handheld Weather and Wind Meters - KestrelMeters.com
  2.
  3. Silversnake
    Silversnake Silverback
    It looks like these are more geared for calculations when applying precision small arms fire (PSAF)
  4. stg58
    The 4500NV is the one for that.
    The Kestrel 4500 NV with Horus ATrag Ballistics combines Kestrel's flagship meter, the Kestrel 4500 with Night Vision, with Horus ATrag Ballistics software to bring you the first lightweight, hand-held tool to give you both comprehensive environmental data plus integrated aiming solutions. Kestrel Pocket Weather Meters and Horus Vision partnered to provide a powerful shooting tool that combines the critical environmental data and targeting software solutions required for precision shooting.
    The Kestrel 4500 NV with Horus ATrag Ballistics allows you to load, customize and store multiple guns, rounds and targets. Target parameters include distance, angle, longitude, speed, direction and wind. Kestrel's highly accurate measuring and averaging of wind together with built-in digital compass for target bearing and wind direction assists in defining the target winds. The Kestrel 4500 NV with Horus ATrag Ballistics is available with Bluetooth technology, which allows you to communicate with your Kestrel wirelessly at a range of up to 30-feet, and maximize the battery life of your meter. Note: The Horus Ballistics support G1 ballistic coefficients only.
    Pre-programmed Guns: This unit can be used with any combination of scope and reticle, here are several pre-programmed guns that come in each unit:
    Gun New Gun 223-BlkHill 308-M24 308-Scout 300-Win 338LabBlkHI 50BMG-HSM
    Muzzle Velocity 2900 2900 2600 2503 2900 2850 2905
    Ballistic Coefficient 0.533 0.372 0.496 0.365 0.533 0.567 0.994
    Bullet Weight (grains) 190 77 175 150 190 250 750
    Bore Diameter (inches) 0.308 0.223 0.308 0.308 0.308 0.338 0.500
    Zero Range (yds) 100 100 100 200 100 300 600
    Bore Height (inches) 1.90 2.95 1.85 2.25 1.90 2.00 2.50
    Rifling Twist (inches/revolution) 10.00 7.00 7.00 12.00 10.00 9.00 12.00
    Rifling Twist Direction Right Right Right Right Right Right Right
    Click 1/tmoa 1/tmoa 1/toma 1/tmoa 1/tmoa 1/tmoa 1/tmoa
    *With the exception of New Gun, these can be removed/overwritten with the use of the Gun Loader software distributed by Horus Vision.
    The Kestrel can measure in TMOA (true minute of angle), SMOA (shooter minute of angle), and MILs (milliradians). The unit displays ballistic tables with data of the shot extending out to various distances (see Range Card on page 17 and 18 in the manual). This Horus meter can provide ballistics solutions out to 4000 yards (or about 3700 meters).
Null
