Mosin Nagant :: Chinese Type 53
Discussion in 'Firearms' started by VisuTrac, Mar 2, 2013.
  1. VisuTrac
    Let me tell you, If you wind up picking up one of these, It's not going to be rearsenaled.
    It's is going to be covered and filled with cosmoline.
    The wood is going to be have major dings, dents and divots. Mine even came with about a 2 inch piece of the upper handguard busted off.
    It's no mater to me as it's a tinker project. I don't even know if it's going to headspace or not in this receiver (it looks like they beat the bolt out of the receiver with a sledge hammer) so it's questionable.
    Just to let you know, this is my first Mosin, and I'm no gunsmith. So Just seeing what i can do with this fugly gun.
    After selling all my firearms before Christmas to cover medical expenses, well all except the now crazy uncle joe approved dbl bbl shotgun. I've finally reached a point where i want/need to rearm and can afford to. Unfortuantely, I can not afford to replace the guns I sold due to the craziness in the marketplace right now. No way I can afford a 2k AR that previously was 700. Let along find ammo for it. So what to do.
    First off, you need to buy one of these puppies (Any Mosin Flavor). I'd say checkout your local gun store, so you can feel it and check out the bore, and see if the fugly grows on you.
    I bet it does, because you can get 440 rounds for under 100 bucks, And you can still find it!! (that was the reason I went with the Mosin.) Heck, the firearm was under 100 dollars too!
    And the saga begins....
    JABECmfg and Brokor like this.
  2. VisuTrac
    So what does this thing shoot? Well, it shoots a .30 caliber projectile.
    DSCN3096_zps24b20b85.
    the 7.62x54R on the left is the choice of the Mosin-Nagant family
    Compare it to the .223 snap cap in the middle
    and the dimunitive .22lr on the right.
    Bullet weights for the Mosin are available from 145gr ball surplus to 208gr soft point hunting rounds.
  3. Falcon15
    Falcon15 Falco Peregrinus
    VisuTrac likes this.
  4. Brokor
    Not to mention the Archangel kit you can use to mod that baby out! It can be turned into a very reliable, modernized bolt action rifle. It still kicks like a three-legged ninja, but...damn nice. ;)
    Brought to my attention courtesy of Visutrac:
    Not your standard ArchAngel now is it?
  5. VisuTrac
    I didn't grab any unboxing picks because it was a freaking mess of cosmoline and cosmo soaked paper.
    The first thing i did was wipe off the cosmoline with one of Momma's recent thrift store towel purchases. That was done so i could get at the 2 barrel bands and 2 screws that hold this puppy together.
    I pulled off the barrel bands, remove the 2 screws and pulled the bolt, the cosmoline filled trigger guard and internal magazine. I think this was dipped in cosmoline because the entire barrel was bedded in the stuff. Unless that's a Chinese Accuracy Technique
    DSCN3092_zps70d42625.
  6. VisuTrac
    I'm getting there. This is going to be a multi post work in progress ;)
  7. VisuTrac
    More tear down pics.
    DSCN3091_zps9343b879.
    DSCN3090_zps1f2164d3.
    If it ever does run out of ammo, it's got a nice attached bayonet. For roasting Marshmallows of course.
    Actually the Bayonet maybe the nicest thing about this gun.
  8. VisuTrac
    Then I tore apart the bolt (which was filled with cosmoline) because I could hardly open and close the bolt and it's like 20 degrees here in the mitten. I'm not going to include any bore pictures because the thing is (i hope) solidly filled with cosmoline, I did run a wire down it so it's not obstructed.
    I wiped down the pieces, blasted them with brake cleaner and put them in my parts soaking pan.
    DSCN3088_zpsd8afc76c.
    and then i poured in about a pint of mineral spirits and let it marinade over night.
  9. VisuTrac
    This evening, I took a toothbrush, tooth picks, qtips, bottle brush and a bunch of rags and went to town on the parts after they marinaded.
    Now that the parts from the bolt, trigger, sear and ejector were no longer cosmoline encrusted/filled hunks of metal. I went about wiping them down and looking at the wear surfaces.
    They were really easy to spot. Machining looks like someone held a beaver up to spinning chunk of metal and started making chips.
    I reassembled the bolt and could feel the bolt binding on cocking and firing. I'd have to do something about that.
    So, I tore it back apart and went about removing machining (tool marks) and polishing mating surfaces where i noted contact / burnishing.
    DSCN3093_zps7c899755.
    Basically I spent about 3 hours with some jewelers rouge, and a dremel and slowly polished the surfaces on the bolt, firing pin, bolt head, locking lugs, carrier, cocking piece, trigger pivot pin, trigger and the sear.
    Needless to say, the wife now does not like the smell of cosmoline, brake cleaner nor jewelers rouge.
  10. tacmotusn
    tacmotusn RIP 1/13/21
    You could tell her, It smells a whole lot better than napalm in the morning with overtones of thatch huts and crispy critters, but, you probably shouldn't.
    HK_User, oldawg and VisuTrac like this.
  11. VisuTrac
    I'm not an expert gunsmith, I'm not going to pretend that I am. So I'm not going to show you the polishing that I did on the trigger, the sear nor the cocking piece. Why, because if you get over zealous here and start rounding edges you have basically ruined your gun and will have to buy another because the pieces themselves cost more than the gun itself.
    If you are going to play with the trigger, sear and cocking piece, do you research and understand how these function in the weapon. If you start tinkering here on a semi auto you are going to be in a serious world of hurt.
    Anyway, I reassemble the polished bolt, slid it into deadeyes MN. You know what? It is freaking smooth. Smooth as any MN I've played with. The firing pin spring is a freaking monster so it's not the lightest bolt ever. But it's feels better than Deadeye's Numbers matching MN. So it's good enough for me.
    DSCN3094_zps79bada1b.
    So we've got a working bolt.
    I still have to check the firing pin height but my gauge does not arrive until next week. Neither does the .30 caliber cleaning kit for the cosmoline filled barrel, so here we are for now.
    I'm still not out of the woods yet though. If the Chinese bolt removal technique caused any damage to the receiver this could just wind up being a learning experience. Albeit a rather inexpensive one as guns go. I've still got to get some head spacing guages for this monstrosity . Maybe I'll go and order them right after this post.
  12. VisuTrac
    And you better believe I'm planning on restocking this gun with the ArchAngel stock. That's pretty much why i didn't care that there was a chuck of the cosmoline oops, wood stock missing.
    stg58 and Brokor like this.
  13. ghrit
    OK. FWIW, I have two Russian MNs. The bolts are smooth cold. About 5 rounds and you'll need a 2X4 to operate them, even after a smoothing out that I've done. Did eye wuz U, I'd get a Russian to go with it so you can cool them off while shooting the other one. Plus, the Russians I've seen have almost decent bores, and they are still less than pricy. If you mail order, make sure to pay for select, but most gun shows will let you do the picking in person, and you'll get the accessories with it. Do not expect MOA accuracy unless you pay the premium for a Finnish gun.
    You will want milsurp ammo, even if it is (and it will be) corrosive. A squirt of Windex as you leave the range with a good cleaning when you get home does the trick. It is WAY cheaper than buying commercial stuff, especially now. If you get to pick, go with the 147 grain stuff, the 182 gr Bulgie that I am working on is brutal on the shoulder.
    There's no one rifle in my armory that out kicks the MN, except the Krag carbine.
    For a LOT of info, go to 7.62X54r.net. That's the Compleate Knowledge on MNs, soup to nuts.
    CATO, JABECmfg and VisuTrac like this.
  14. VisuTrac
    You are right @ghrit but right now, try finding a Russian, Polish or a Finn.
    You can find 'Snipers' at around 600 and going to the stratosphere.
    Locally M-N's are starting around 250 were they were 100 a few months ago.
    I went with the cheapest I could get.
    I've got feelers out for a Finn or one of the select better models out there. But so far, nada.
    So I picked this one up. All i want it to do is print on paper at 150 yards or so. So, I'm hoping i wont be disappointed.
    But I am getting my ducks i a row for future purchases of these fire breathing behemouths.
    getting guages for Firing pin height, Headspace, .30cal cleaning kit (first .30 cal i've owned), and a method for quickly degreasing and removing cosmoline (well besides using gasoline and a match).
    This one may be the first but It's probably not going to be the last.
  15. tacmotusn
  16. ghrit
    Saw that, tac. Too high. Should be able to get a spam can of 880 for well under 200. There's plenty out there, that 242 is a gouge. Shouldn't take too hard a search. I'm not looking these days, have five or six hundred left for the zombies. May need to restock next fall, dunno yet. Last gun show I went to was in Oct last year, I think it was 175 bux for 880 147 grain romy.
  17. VisuTrac
    Sportsmans guide is like 180 for 880 delivered.
  18. VisuTrac
    This short carbine is going to be a mule kicking fire breathing dragon. The rifle at least burns most of the powder before the bullet leaves the barrel. So if i can't hit the deer I should at least be able to blind it and cook it at the same time.
    JABECmfg and Gunny Highway like this.
  19. Gunny Highway
    Gunny Highway Hard Work and Sacrifice blessed by God's Grace
    I'm still looking to pick one up but not at the prices I have seen. Would be worth a plane ticket to PA if the price The Economist quoted is still valid - well it would be a push price wise and I would get to see some family and scope out my property etc
  20. CATO
    CATO Monkey+++
