Natural gas generator conversion
Discussion in 'Off Grid Living' started by Harbin, Dec 30, 2012.
  1. Harbin
    Harbin Monkey+
    I've been looking at putting a conversion kit on a commercial Generac so it can run on gasoline or natural gas. Im keeping an eye out for a used onan rv unit, but for the occasional storm related outage this 8kw unit has performed really well. If/when shtf, any ideas on how long natural gas would continue to flow? I store enough fuel right now for at least 2 weeks of continued running, plus what's in the cars and truck.
    Sent from my SPH-D710 using Tapatalk 2
  2. JABECmfg
    JABECmfg multi-useless
    I think nature and extent of SHTF event would be huge factors.
    Good idea though, being able to use either fuel. Gasoline won't keep forever, but the propane tanks like the ones found on gas grills are abundant.
  3. Gator 45/70
    If you decide to pull the trigger on this conversion, Call 1.887.425.8383, Ask for Richard.
    I've been doing business with him since 05, He's good to go !!!
  4. Harbin
    Harbin Monkey+
    Thanks! I'm pretty set on it, just wanted some input. I'll be sure to call him for the kit.
  5. Mountainman
    Does he have a web site to check out the products?
  6. kellory
    They already make generators they call Tri-fuel. You can switch fuel without even shutting down. usually set up as gas, propane, natural gas, but other fuel options are available. I looked into them before I bought my unit. They were in the 8kwt range, and more than I needed, but would have been nice to have.
  7. kckndrgn
    Mountainman likes this.
  8. Mountainman
    Number no workey!
  9. Gator 45/70
    Really.. ? Wait let me look it up again...
  10. Gator 45/70
  11. BTPost
  12. Harbin
    Harbin Monkey+
    Does anyone have any thoughts on what would cause NG to stop flowing? Would a massive power outage cause this? Forgive the ignorance if this is really obvious and I'm missing it, I know very little about natural gas distribution and storage plants. I'm assuming they require power to keep the gas flowing, whether it comes from the same grid we all use or they produce their own with backups gensets.
    Anyone live in the Northeast during that last massive outage and know if gas stopped flowing as well?
  13. kckndrgn
    The only thing that I know of that will stop NG is an earthquake. I may be wrong, but that's what I learned in my CERT class. Earthquakes may break or damage the underground lines and the system will be shutdown until they are inspected after a quake.
    some useful info
    How Does the Natural Gas Delivery System Work? - Natural Gas
  14. ghrit
    NG delivery may/will be affected by the duration of an outage. If the pipelines remain intact and storage can remain under enough pressure to supply the distribution system, all will be well. I believe, but am not positive, that local tankage is supplied by transmission pipeline (from the gas fields to local storage) pressure, meaning that upstream pressure takes care of holding storage pressure high enough to maintain the distribution system. Lots goes on between the wells and the kitchen stove, any of which could be problematic. There is a LOT of designed in work-arounds to accommodate failures upstream. Upstream compressor power is always a tender spot, but there are LOTS of them such that one (or many more) offline won't even be a hiccup.
    This does not mean that local pressure will be high enough to fuel vehicles. That is a whole 'nuther subject.
  15. BTPost
    On MOST NG Pipelines, all the Pumps are run off the NG that is coming down the Pipe.... This allows everything to keep running as long as the Pipeline Integrity stays intact. the Pipeline Companies just figure that the BTUs used to pump the pipeline are just "The Cost of doing Business"....
  16. Gator 45/70
    True enough...There are bypass valve's in place to go around a facility with problem's, Earthquake's WILL shut one down,Also the safety system will have a PSH/L (pressure safety high low) should catch it and automatically close valve's..There are way's to bypass this...But that's all i'll post...
  17. Gator 45/70
    We pay a fuel tax to the gooberment for fuel usage...Our own gas from our own well's..Go figure...lol
  18. ghrit
    I can't say this for an absolute certainty, but I think the (local) compressors are driven by dual fuel ICEs, ng and diesel. Straight or blended, I don't know. I do know they are turbo boosted and noisy as hell. Even with sound enclosures, you can hear them at half a mile. There are diesel tanks on all the compressor sites, whether as primary fuel, starting fuel, or blended, dunno. Will try to find out, now the question has occurred to me.
  19. Gator 45/70
    Most of the compressor's are Nat.gas, The diesel is usually for back up generator's...
  20. -06
    -06 Monkey+++
    A bud simply drilled a hole into the top of the carb tapped a fitting in and ran a line to the tank. He adjusts the speed via a shut off valve. Says it works fine.
  1. survival junkie
  2. T. Riley
  3. techsar
  4. Benjamin A. Wood
  5. Asia-Off-Grid
  6. Asia-Off-Grid
  8. Asia-Off-Grid
  9. Asia-Off-Grid
  10. Asia-Off-Grid
  11. Asia-Off-Grid
    Resource
    Generator FAQ 2001
  12. Asia-Off-Grid
  13. BenP
  14. BenP
  15. Thunder5Ranch
  16. T. Riley
  17. Rsparks
  18. Adam_L
  19. T. Riley
  20. Asia-Off-Grid
