Trouble Starting My Chainsaw
Discussion in 'Back to Basics' started by Gaowlpoop, Jun 20, 2019.
  1. Gaowlpoop
    Gaowlpoop Monkey++
    Chain Saw Trouble
    I started having trouble starting my chainsaw a few weeks ago. The starter rope seemed very hard to pull. I had several people look at it and no one could figure out what was wrong. I finally got a hold of a guy that really knew what he was doing when I came to small engines. After he carefully went through it he made his recommendation. He said the best he could figure out was that I was just getting old and weak.
    Thanks a bunch fella. But he is right I’m getting old and weak.
    Zimmy, Alf60, Gator 45/70 and 4 others like this.
  2. BTPost
    It is amazing how well a rebuilt Carb, and new Spark Plug, refreshes my 30 year old Stihl 030AV.... and AlaskaChicks 20 year old Stihl 018....
  3. SB21
    I bought a Stihl MS211 a few years ago for small stuff,,, 18 inch bar ,, it's got that EZ start pull system . You don't snatch on the cord , you slowly pull the cord out and at a certain point , it'll release and spin the motor over . And most of the time starts pretty quick . I don't think it's offered on larger saw's , it wasn't when I bought that one . But it's really hard to get used to , whenever you pick up a chainsaw , the most common reaction is to snatch on the cord , you have to force yourself not to snatch it .
    But like BT said , a new carb , or carb rebuild may help immensely . Look on ebay or amazon , they're actually pretty cheap .
  4. Bandit99
    And, only use non-ethanol gasoline if you want to keep that rebuilt carb clean and operational...
  5. Meat
    Meat Monkey+++
    Put a hair dryer on it for 5 minutes before starting. Return hair dryer ASAP after starting. Seriously.
    oldawg, TnAndy, v0lcom13sn0w and 4 others like this.
  6. Ura-Ki
    Never had one get hard to pull through unless it was Loaded up with too much oil in the case, then turning it upside down and turning it through a few pulls would clear it out and usually start first yank! I run Sthil, Husquvarna, and old school HomeLites, not a one has ever been hard to pull through! Mine all get ran HARD and often, and other then the Sthil 490 needing rebuilt recently, it never had issues other then getting low on power!
    Meat, Gator 45/70 and SB21 like this.
  7. sdr
    sdr Monkey+++
    Ditto on the carb rebuild. I did both of mine a couple months ago. Take lots of photos while disassembling. Remember what looks like one gasket might be 3 separate ones stuck together. Hi and low adjustment screws should be set with a tachometer (If I remember right). Google how to do it by ear if you don't have one. Like me. 2 strokes don't handle very lean mixtures to well.
    Rebuilt carbs, new plugs and clean airfilter makes a big difference.
    Meat, Gator 45/70, SB21 and 1 other person like this.
  8. Cruisin Sloth
    replace all lines from Ebay sellers 5 years , fuel , intake , and pulse , soak carb in chems H2Cl% is mine
    Sloth
    Meat, Gator 45/70, arleigh and 2 others like this.
  9. Wild Trapper
    Wild Trapper Pirate Biker
    I have something like a half dozen chain saws. All of them that do work have an issue with heat, gets much over 85 degrees, damned things just don't want to start. Same thing happens to my log splitter.
    The pool, now that's when it seems to work just fine for my old bones.
    Meat and Gator 45/70 like this.
  10. oldawg
    If the recoil is getting hard to pull check the spark arrestor and take look into the exhaust port for a scored piston and cylinder. I'm assuming the guy checked the recoil itself for binding.If it's a cheapo saw the crank bearings or bushings may be going.
  11. BlueDuck
    BlueDuck Monkey+++
    II noticed mine has gotten a lot heavier over the years.
  12. arleigh
    Old gas or wrong kind of oil can gum up the cylinder wall .
    Pull the spark plug and face it up word so that penetrating oil can be evenly distributed on the piston @ TDC and let it loosen up the rings .
  13. Big Ron
    Big Ron Monkey+++
    I have handsaws. and kids.
    Meat, Zimmy, Gator 45/70 and 3 others like this.
  14. Thunder5Ranch
    Thunder5Ranch Monkey+++
    My guess from my own experience would be a carbon clogged exhaust port or piston wall is gummed up. Some seafoam down the plug hole or even wd40 or PB blaster will loosen things up in the piston wall. Just slowly pull the recoil and work the piston up and down if the gummed wall is the case. LOL if the recoil won't pull just let the cleaning fluid sit and work it loose until you can pull it. Assuming it is the piston wall. Also if you pull the plug and it pulls easy that is a pretty good indicator that it is the exhaust port. Which is also easy to clean the carbon build up out of. And not saying you do or don't but only use the recomended oil in the gas and DO NOT USE ETHANOL gas. If you can't find non bio gas at the pumps, places like Rural King sell cans of real gas. Well worth the price in what it saves you on engine repairs and maint.
    Meat, Zimmy, Gator 45/70 and 2 others like this.
  15. Gator 45/70
    Do these have the screen between the exhaust and muffler?
    Meat likes this.
  16. oldawg
    Many do.Some have it incorporated into the muffler. No one setup seems less prone to plugging than the others.
    Meat, Zimmy and Gator 45/70 like this.
  17. Zimmy
    Zimmy Wait, I'm not ready!
    I remember ungumming and freeing stuck pistons with Marvel Mystery oil way back in the bygone days.
    I've used Kroil a couple of times since then.
    SB21, Meat and Gator 45/70 like this.
  18. Meat
    Meat Monkey+++
    ^^^^Good products. Both of them. Or as some people say.........”Boaf.” Lol. :D
    SB21, Gator 45/70 and Zimmy like this.
    Also, make ure you use the proper starting technique:
    oldawg, Thunder5Ranch, SB21 and 2 others like this.
  20. oldawg
    Hope he gets it started and gooses it. Already enough stupid in the gene pool.
    Gator 45/70 and Meat like this.
  1. SB21
  2. Homunculi
  4. Motomom34
  5. oil pan 4
  6. cjsloane
  7. RightHand
