240v AC Relay
Discussion in 'Off Grid Living' started by BenP, Aug 20, 2018.
  1. BenP
    BenP Monkey++
    I wanted to make my off-grid air conditioning only come on when the batteries were completely charged and kick off when they started to get low and this little relay I found is just the ticket. The relay is controlled by 12v and I wired it into the auxiliary output of my charge controller which you can program to put out a 12v signal under certain conditions. I made this whole panel switch on and off depending on the condition of the batteries, these will be my luxury appliances.
    IMG_20180819_204441.
    IMG_20180819_122452.
  2. Asia-Off-Grid
    Asia-Off-Grid RIP 11-8-2018
    Cool beans, @BenP.
    I've used charge controllers and 12vdc relays switching 230vac contacts, for single devices before. But, never to control an entire panel. Great idea, man.
    How large is your system?
    BenP and sec_monkey like this.
    Good idea. I would use a Solid State relay, control my well pump with one (based on water level in the tank, not a solar controller output). No contacts to pit, burn or stick over time. They take only 10 or 20 mA to activate the "coil".
    BenP, Asia-Off-Grid and sec_monkey like this.
  4. BenP
    BenP Monkey++
    It is a small 24v system, I have about 2600w worth of 12v panels that I wire in series to get 24v.
    Schneider Electric Conext XW MPPT 60 Amp Charge Controller (x2)
    Schneider Electric Conext SW 4024 3,400 Watts, 24VDC Inverter 120/240 VAC
    Schneider Electric Conext XW+/SW System Control Panel (SCP)
    LiFePO4 Prismatic Batteries 300Ah
    I also have a 2000w wind mill that never does anything, we get a lot of wind in the winter and I'm hoping it will pay dividends then, if not I will take it down. I think some vines have grown over it at the moment. :)
    sec_monkey and Asia-Off-Grid like this.
  5. BenP
    BenP Monkey++
    What relay do you use? If there is something more reliable than this one I would like to have it, at least for a spare.
  6. Altoidfishfins
    How much current does your Air Conditioner draw and at what voltage? We already know that you're controlling the coil with 12 volts, so we can probably find one with a "coil" that will operate from 3 to 24 or 3 to 32 volts DC. Since you're controlling AC, you'll probably need a Triac type. My well pump runs on about 150 volts DC from the solar array when it's under load (has a built in MPPT controller) so the SSR is a FET type.
    BenP, sec_monkey and Asia-Off-Grid like this.
  7. 3M-TA3
  8. Altoidfishfins
  9. BenP
    BenP Monkey++
    The air conditioner and water heater are both on that panel and they will draw 15 amps combined worse case but the panel is fed by a 30 amp circuit so it would probably be good to have at least a 30 amp relay. Air conditioner is 120v AC, Water heater is 240v AC.
  10. ghrit
    Is that starting draw, and is it possible for them both to kick on at the same time?
  11. Tempstar
    Tempstar Pray for BT
    Those solid states are also great for rapid switching. You see them on a lot of cooking equipment to control the temps by rapidly switching on and off to keep elements at the right temperature. They will last almost forever in a cooler environment.
  12. Altoidfishfins
    There are SSRs that can handle more current. Crydom, Omron, as well as Automation Direct manufacture them. They probably should be attached to a heatsink.
  13. BenP
    BenP Monkey++
    They always both kick on at the same time but their behavior is somewhat unpredictable. The air conditioner does not have a big starting load, usually 300w or so when the outdoor unit kicks on then the draw will cycle up and down between ~300-1000w. The water heater will draw about 500w at startup if it is in heat pump mode then level off around 300w. If the water is really cold it will use the resistance elements for 500w then switch to the heat pump later when the water gets to 75-90 degrees depending on the temperature setting.
  1. Asia-Off-Grid
  2. Asia-Off-Grid
  3. Asia-Off-Grid
  4. Adam_L
  5. Dunerunner
  6. Dunerunner
  7. DKR
  8. Asia-Off-Grid
  9. hitchcock4
  10. oil pan 4
  11. SpikeandKari
  12. Asia-Off-Grid
  13. hitchcock4
  14. chelloveck
  15. dewnhew
  16. newbloom1
  17. IrishMonk
  18. jasonl6
  19. hank2222
