Interesting that the additional height for higher altitudes is so little. I seldom see burn issues with anything here at near sea level, but I wonder if the added height might help with some of my more twitchy lamps? The fire breathing Rayo's would make good test subjects. I learn cool stuff here all the time.
Yup those are them. Forget how much they cost. I didn't see the reason to buy one. i try to make everything i can. I'll go broke slower that way.
Spiders are the most common problem with liquid fueled lamps. The little darlins will build a nest in air supplies and then you have a person complaing and making claims about "poor INGANEERING of X product. The most common problem is with Colemans and the airflow around the Generator and the stack. One small Spidy and folks will end up with a whole stack of parts and a Broke Lantern. I have 3 that I "fixed" after spending a Buck a piece at garge sales they are perfect. Spark Fuel Air Flow
@HK_User, you'll have no spider worries with the Aladdin. Just burn them off. Multi-fuel pressure lamps are my weakness, and I can make them perform well on lots of inefficient field due to my altitude. I know of the spider frustration in the air tubes. The only thing that I've not been able to fix on any model has been stress cracked and leaking founts. The old Mil-Spec Coleman lanterns had dual air tubes, with one plugged. This plug was removed for high altitude use, or when spiders blocked the first one. I have a couple that I run on both tubes and they roar like jet engines and look like dual stars on the porch from a distance. Even Coleman propane lanterns have a mild hiss, and Rayo's make a purr sound as they warm up, but the Aladdin is silent. The final great pinacle of wick/mantle lamp development before people started switching to quick-lite Coleman gas pressure lamps and electric light. My only objection to the Aladdin is its height. If you store them without the chimney the mantle is exposed... and there's a mild kerosene smell. The fix? I fit the cup over the fragile mantle, and box the chimney and shade. Then I can stick unused lamps on a shelf for storage
Yeah....SM has a special photo feature that recognizes books and arranges the photos in 'read title mode' unless you click a box to over ride to "normal" layout. /sarc......
ALSO KEEP 4 FEET MIN FROM TOP OF PIPE , TO ANYTHING !! FIRE STARTER IT IS !! SEE PIX ^^^^^^^^^^^^^^^ Sloth know the lamp and power it has.
True. They make great heaters in the winter with adequate ventilation, are near useless in a breeze and don't fare well if knocked over. Yet they survive, and bring us joyful silence and white light. Forget where the chimney is while reaching for something and pass an arm too near it and it becomes an unpleasant depilatory device. I'm not testing the results of knocking over an Aladdin, but I will try it with a beater Rayo when it cools off outside a bit. Coleman I know can be safely inverted, and Dietz hurricane lamps will self extinguish if the globe is intact when they're knocked over. Little to nothing I can find online about the results of knocking over a lit Aladdin 23. As a guy who enjoys late nights working with fire and pressurized gasoline this makes me really curious. Mrs. O'Leary's cow isn't telling. FYI, my Rayo with the whisps of blue flame above the chimney was intentionally over-fueled to get that shot.
