Ammo boxes
Discussion in 'Firearms' started by oil pan 4, Nov 6, 2020.
  1. oil pan 4
    Well if you're like me and picked up all the range brass that goes to your guns, for years and actually reloaded it. Then you probably have a few piles of ammo that are just hanging out in ziplock bags.
    It's hard to look at a ziplock bag and know how many rounds are in it. Or at least it is for me.
    I find it easier to just be able to grab boxes by 50, 20, sometimes 25 at a time.
    So to fix that I bought all the cheap 44mag ammo boxes on ebay. Since all the factory ammo I ever bought for 44 mag has been fired and reloaded or originated from range brass pickup.
    I went to buy some used 45acp boxes and there weren't any cheap ones. Other people must have had the same idea as me.
    But then got it idea to search "1911 ammo" box, figured maybe I might find something.
    No not something, that's the mother load.
    There's a seller called "the ammo box guy" (but with no spaces between the words). His name is as functional as his products. He or they sell some original but mostly reproduction cardboard WW2 ammo boxes. That's it. The 45ACP boxes are pure utilitarianism, just single piece ammo boxes that fold up and hold your bullets, for $2 each shipped to your door, I think there's 7 different ones. So now my ammo can stuffed loose packed with 45acp reloads can actually go into boxes.
    There's also 30carbine boxes, you can get 1 or 2 piece 30 carbine boxes. The 2 peice ones are $3. I splerged and got the deluxe 2 peice boxes.
    Also there's 38spl, 30-06, 22LR, maybe some more.
    The blank white Styrofoam boxes are cheaper, if you want a lot of boxes. These are definitely cooler and the minimum order isn't 25 boxes.
    I'm pretty sure I don't need 25.
    These old style boxes pack the same number of rounds in about 2/3 of the same space and ammo cans were designed around holding boxes this size.
    So if you're going to put your ammo on a shelf, the cheap white boxes are best, assuming you need exactly 25 or 50... If you are going to put them in ammo cans the old style is better, unless you want to buy more ammo cans.
    Oddcaliber, Gator 45/70 and HK_User like this.
  2. Brokor
    Gator 45/70 and 3M-TA3 like this.
  3. oldman11
    oldman11 Monkey+++
    The metal ones are the best,better seals.
    [flag]
  4. 3M-TA3
    You can also get these:
    Same MTM can as @Brokor 's post, but three of them and a tray. $25 bux on Amazon. The tray is handy to help keep them sliding around in a vehicle. The benefit of these over a metal can is that the lid makes it just a wee bit taller so you can store 30 round AR mags vertically. Ammo Cans for Ammo Storage by MTM Case-Gard
    They are also great to organize other things like first aid and other things you might want to be able to quickly load up and split. You can get then in four and five can trays, but with progressively smaller boxes.
    I use the metal ones for loose ammo: 50 cal cans for 5.56 and 30 cal cans for 7.62. I only use surplus, but the new manufacture ones at Harbor Freight and Costco are reputedly as good. My only issue with them is they are manufactured "you know where", so in addition wanting to send minimal dollars off shore I'm not convinced the seals will hold up over time. Mil-Spec for me on these.
    Gator 45/70, Brokor and ghrit like this.
  5. Brokor
    Yes, those MTM boxes come in handy. I also have some for .308 and it has 4 cases inside to hold the ammo.
    --Reloading necessity for me.
  6. oil pan 4
    Yeah I was talking about what goes inside the ammo cans, assuming you just aren't dumping loose packed ammo in there.
    I buy actual surplus ones from cannon airforce base.
    I inherited some plastic ones and just don't care for them.
    john316 and Gator 45/70 like this.
  7. oil pan 4
    Brokor and Gator 45/70 like this.
    Pack a "Strap, carrying, universal." In each can. Makes carrying them much easier.
    upload_2020-11-7_0-55-8.
    3cyl and Gator 45/70 like this.
    Looks like it's all in pretty short supply, and where available has doubled in price. Metal cans are still available.
  10. oldman11
    oldman11 Monkey+++
    If you filled a steel ammo box full of ammo and sunk it in the pond ,how long would the ammo be safe? A good friend wanted to know.
    [flag]
  11. BTPost
    Unless the Ammo Box was sealed AND Water-Tight, a month on the outside depending on the depth of the box...
  12. 3M-TA3
    I would test each ammo can first by submersing it in the same location ()or at least the same depth for a month.
    Ammo can always be vacuum sealed before it goes into the can.
    Mountainman and Gator 45/70 like this.
  13. Gator 45/70
    I for one on here don't recommend vacuum sealing boolits.....Try it out and wait...
  14. oil pan 4
    I shot ammo from 1953 and it wasn't vacuum sealed, worked fine.
  15. BTPost
    Rather than Vacuum Sealed, it would be much better to seal it Flooded Nitrogen containers....
    Dont, ghrit and Gator 45/70 like this.
  16. ghrit
    Pulling a vacuum on a cartridge might do something funny. Like pulling the bullet loose. Don't take that to the bank, but do test it with ALL the calibers you have in mind. Or better yet, do the nitrogen trick after pressure testing the box.
  17. Mountainman
    I get so tired of this SHIT!!! (Nothing against you) If it's time to hide it it's time to use it. If the Biden disaster actually happens we will find out pretty soon.
    3cyl, Yard Dart and Gator 45/70 like this.
  18. Mountainman
    If you're talking about the bullet points eventually popping the bags wrap the ammo in cloth before sealing. If not, please explain.
    From what I've been reading the powder can out gas some nasty stuff as it ages, but it would seem that storing in a sealed ammo box would have the same issue. Also bullets that don't have enough neck tension or a proper crimp can move with the vacuum pressure.
  20. Gator 45/70
    Sea tried it...Ended up with loose powder,projectiles,cases....Ask him
    Mountainman likes this.
  1. OldDude49
  2. Oddcaliber
  3. deMolay
  4. Grandpa Patch
  5. Bishop
    Thread
    Socket mold
  6. Bishop
  7. Bishop
  8. Bandit99
  9. arleigh
  10. Oddcaliber
  12. Oddcaliber
  13. Asia-Off-Grid
  14. Tackleberry
  15. oil pan 4
  16. Seacowboys
  17. oil pan 4
  18. arleigh
  19. Seacowboys
  20. Seacowboys
