Bit Message vs Tor Chat reccommendations
Discussion in 'Bitmessage' started by Witch Doctor 01, Dec 20, 2014.
  1. Witch Doctor 01
    I noticed that several monkeys are using Bit Message.. I'm considering either Bit Message or Tor Chat... why should I choose one over the other? Why did you choose Bit Message?
    Recommendations?
  2. sec_monkey
    None ;)
  3. Dunerunner
    Bit Message... quite possibly one of the best encryption programs the NSA has ever developed....
    Just kidding, but don't fool yourself into thinking it is in any way, secure.
    sec_monkey likes this.
  4. BTPost
    @Dunerunner BitMessage is Open Source, so the Code is available to ANYONE, to look at. Where in the BitMessage Code, is this suspected BackDoor, or exploitable Hole? Inquiring Minds want to know?
    Dunerunner and sec_monkey like this.
  5. sec_monkey
    MonkeyChat is obviously the best ;)
    Not really
  6. BTPost
    Well, actually MonkeyChat, now, is about as secure as anything going, that is NOT end to End Encrypted, these days, as it runs on SSL between your computer and the Server, and from the Server to their computer. SSL encrypts those exchanges in both directions, using the SSL Certificate Published by Melbo. As long as the Server, itself is secure, the messages, are Secure. MonkeyChat Logs are clear every 24 Hours, so there is no long term records, kept.
    BitMessage is an End to End Encrypted Messaging System, so it has One Less point of vulnerability. CryptoCat is half way in between these two systems.
    If one wants to have Total SECURE Messaging, the One NEEDS to go clear up to OnePad.exe, where you are dealing with a virtually UnCrackable Coding System that is generated InHouse. If the Pad is SECURE, the Message is SECURE, Period.... and there is and never will be a system that can BruteForce the encryption.
    sec_monkey and Dunerunner like this.
  7. Dunerunner
    I guess I'm just so paranoid and at the same time trusting that my government counter intelligence alphabet agencies are able to decipher anything out there that it is hard believe there are any secure online communications methods. Shoot, terrorists then could use Bit Message to plot attacks and the NSA would be none the wiser! It just seems logical....
  8. BTPost
    I am under the opinion that BitMessage is SECURE enough, to make it NOT worth while to even try breaking it, unless there is Significant Intel that leads them to think it is worth expending the REQUIRED Resources, to do such a Crack. Certainly it can't be done in Real Time, no matter how big the SuperComputer may be... The way to keep your Comms SECURE with BitMessage, is to vary the Encryption Key used in every Message. This is why BitMessage generates 8 Keys, when you set it up. If you use a different Key for each message and rotate thru those 8, regularly, it truly complicates and Crack, they try. If you keep the Keys SECURE, on both ends, then you have SECURE Comms. If you need more then, ONEPAD is what you need....
  1. selvagem
  2. BenP
  3. survivalmonkey
  4. survivalmonkey
  5. survivalmonkey
  6. survivalmonkey
  7. survivalmonkey
  8. survivalmonkey
  9. survivalmonkey
  10. survivalmonkey
  11. survivalmonkey
  12. melbo
  13. melbo
  14. DarkLight
  15. 10brokenpromises
  16. melbo
  17. DarkLight
  18. kckndrgn
