Building a 500 gallon diesel tank trailer
Discussion in 'Back to Basics' started by oil pan 4, Mar 24, 2020.
  1. oil pan 4
    I would like to build a 500 gallon diesel tank trailer. I have a 500 gallon propane tank I got from the agg auction for $100 last year. It lacks a valve tree to be usable, which is about a $200+ part.
    I also have a barrel hand pump, mechanical, hand operated.
    The large barrel bung is a 2 inch NPT.
    So I bought a 2 inch NPT half coupler.
    I watch Chemical Safety board videos on industrial accidents and cutting, grinding or welding on, next to or over top a flammable storage tank ranks just about at the top of the list for ways to die. Probably pull all the valves, let it air out for a few days. It appears to have two 3/4 inch NPT and a 1 inch NPT.
    So no plasma cutter. I'll hole saw it.
    To make it safe put an air line in one of the existing holes and pump in air from a running air compressor while hole sawing, that should eliminate explosive atmosphere.
    Not a little toy air compressor, probably use my 5hp gasoline powered air compressor.
    Once there is a about a 2.5 inch hole in that tank it should help reduce explosion potential. Then continue to purge the tank with air while welding. Instead of boom it goes wooosh, if it cooks off.
    So diesel weighs about 7 pounds per gallon. That's 3,500lb of fuel if I could fill it up all the way. Or around 70 MM btu.
    I bet the empty tank weights 400 to 500lb.
    So just the propane tank filled with diesel assuming I could fill it all the way is pushing 2 tons.
    It should probably have a tandem axle trailer with a brake axle.
  2. sec_monkey
    have ya stripped the paint off of it and inspected it fer rust, corrosion, cracks, that sorta thing??
    done a pressure test??
    a static water test??
    and so on??
    I may have missed a thing or 2 or 4 .. ..
    [winkthumb] [winkthumb]
  3. DKR
    500 gallon may require a DOT or State issuedd permit/license for hazmat....
  4. HK_User
    AS well as a diked storage area.
  5. Tempstar
    Tempstar Monkey+++
    108 gallon limit of hauled fuel without a CDL with Hazmat certification and trailer must meet all DOT specs. We just went through all of it to build an emergency fuel trailer for the transmitter site. Ended up with a 100 gallon tank on a much smaller trailer.
  6. Illini Warrior
    Illini Warrior Illini Warrior
    OH YAAA - 500 gallons on the road - you betcha >>> you couple an unrated & uncertified bulk hauler with a spill and your life is over ...
  7. oil pan 4
    I see a lot of home made big fuel tankers in new Mexico.since I'm white and have money therefore the law applies to me and I am liable.
    I do have a 50 gallon tank I can toss on the back of another trailer.
    sec_monkey and Gator 45/70 like this.
  8. Gator 45/70
    No oil pan,Just no.....The tank and trailer are ''Grandfathered'' in since this has been in the family since way before any rules and regulations......
  9. Illini Warrior
    yep - the big farming ops around here sometimes have their own tanker for re-fueling the rolling stock out in the fields - alot of times it's a 100 gallon fuel tank on their maintenance & re-supply flatbed
  10. Tempstar
    Tempstar Monkey+++
    Now, if you don't take it on the highway and just use it around the farm, the sky is the limit as long as you're not a commercial operation.
    3cyl, Thunder5Ranch and Gator 45/70 like this.
  11. Tully Mars
    You would be better off using Co2 or Argon as a purging gas. I have a squirrel fan necked down to fit into the opening on the tank. I plug it in and let it run for 3-4 days. Gas sniff it and if it's good use the torch or plasma. If not run the fan a few more days and or charge it with Co2.
    You would be wise to hydro test it 1st to be sure it's worth the effort.
    3cyl, Gator 45/70 and sec_monkey like this.
  12. Tully Mars
    [ditto]
  13. BTPost
    Pull all the removable valves... Fill it with water, to overflowing, for a few days..... Empty it out and then do you fabricating with whatever you like... When Done, let it Air Dry, in the Sun, for a few more days, and reinstall the Valves, on fabricated ports... then fill, with Fuel....
  14. oil pan 4
    I'm good with a fixed tank.
    Building a 4k tandem axle fuel tanker was kind of a big project.
    The tank has had pressure in it for a year. I figured as long as it has pressure in it water and dirt aren't getting in and there's no cracks or holes rusted through.
    I could pump it up with 120psi of air and see if it comes apart.
    All I need to make the smaller stainless tank mobile is some wooden stands cut from something like a 2x8.
  15. Ura-Ki
    No joke, i got busted for having more then 100 gallons of fuel on board one of my nom CDL trucks! They gave me a pass on it as its not a comercial truck, but warned me that I could expect troubles in other counties and states!
    Had to re engineer the rig to hide the tanks better, which turned out to be a good thing anyway!
    Also, dont ever get caught using a water tank to carry fuel, big no-no! Ask me how I know this!
  16. oil pan 4
    With the oil prices going down I'm going to have to get moving on this.
    Hell I haven't even poured the pad.
  17. Cruisin Sloth
    Im full and next is to build the roof structure next week ,got all the Fir milled and now its in the drying room.
    Pads here are a Taxable item !!
    The green paste inside the bowl , is water sensitive and turns pink .
    We use this to sound tanks. Split tank Runing Diesel #1 /Biodiesel .
    Last weeks work !!Quick unions to swap filler hose on all my tidys and tanks.
    Sloth
  18. oil pan 4
    I still got a ways to go. I loaded 960lb of concrete in my Nissan leaf, will need to do that 2 or 3 more times before I have enough to pour the pad.
  19. ghrit
    For fixed tankage, might be worth looking at TnAndy's installation for ideas.
  20. Ganado
    Your stuff is always so neat and tidy. Well done!
    TnAndy, Gator 45/70 and Cruisin Sloth like this.
