Casting bullets for muzzleloader
Discussion in 'Back to Basics' started by kellory, Feb 16, 2015.
  1. kellory
    Thermostat is not there. I think a simple potentiometer should do the job, checked by a mechanical thermometer.
  2. HK_User
    Seems to be a close match.
    Product Details
    120V 210W table top 500ml mantle heater
    Product Highlights
    • Self-supporting, can be placed directly on counter top
    • Easy viewing of flask contents
    • Stackable for easy storage
    • Includes 6 foot cord with either a NEMA 1-15 (for 120VAC) or NEMA 6-15 (for 240VAC) plug
    Specifications
    • Fiberglass cloth outer shell
    • Uniform, low-watt density knitted and braided heating element.
    • Temperatures up to 900oF (482oC).
    • Multi-stranded resistance wire for increased durability and flexibility
    • Plug-and-play
    • Temperature controller required
  3. kellory
    Looks like it uses a timer for heat on time. That would be easily doable with a light timer. ( 15 minute variables.)
  4. HK_User
    I would imagine a real heat controller with the thermocouple providing the feed back.
  5. kellory
    Download shows no heat sensor, and one of the controllers on your link shows it to be an on power timer.
  6. HK_User
    The link is only part of the site. It was sampled as a way to see the advertised max temp for the given volts and watts.
    Note the last line; Temperature controller required. It gives you the options on the attached sheet.
    http://www.gordosales.com/store/pc/catalog/hm-instructions.pdf
    TS0 Portable Bulb and Capillary Temperature
    Controller Features:
    120 or 240VAC
    15 amps
    4-foot copper bulb and capillary
    Compact portable design
    • Plug-in operation
    TP0 Portable Time Percentage Dial Temperature
    120 or 240VAC
    15 amps
    Plug-in operation
    The TP0 series controller varies the proportion (length)
    of time a heater is in the “on” or “off” heating mode.
    The heating application will determine the actual
    percentage set point required. The controller does not
    use a temperature sensor and therefore satisfactory
    operation requires occasional supervision under
    changing load conditions.
    BriskONE Digital PID Thermocouple Temperature
    Accuracy: ±1 least significant digit
    Operating voltage 120 or 240 VAC, +10% -15%,
    50-400Hz
    Rated 15a @ 120VAC, 10a @ 240VAC
    Type J thermocouple input
    Dual display shows set-point and actual
    temperature
    Programmable to either °C or °F
    Automatic tuning of PID parameters
    Auto / manual control ability
    • Simple four key user control
    For more information and choices, go to the full temperature controller section at pages 80 through 100.
    Temperatures up to
    900°F (482°C)
    IMPORTANT: Temperature controller is required for this product. See pages 80 through 100 for options.
    Ordering Information:
    Self-supporting: can be placed directly
    on counter top
    Includes 6-foot (1.8m) power cord with
    Product Highlights
    SDC Benchtop Temperature Controller Features:
    Temperature Control Range: 32-999°F (0- 600°C)
    J-type or K-type Thermocouple Sensor
    - 5-foot (1.5 m) factory installed
    120 VAC or 240 VAC power input
    10-Amp Fused Output
    Small Unit Size
    HM Table Top Heating Mantles
    Temperature Controllers for Heating Mantle
  7. kellory
    "Plug-in operation
    of time a heater is in the “on” or “off” heating mode" ....yep, just like a light timer. As for temp, just like over a burner, it will require supervision, and a thermometer. Lead does not heat or cool very quickly.
  8. HK_User
    You need to be aware of the reason this heater was designed. It is a shaped heater and it will require a good controller to have a service life for melting lead. This system is a lot like an immersion water heater that is not air rated. By that I mean that it may have a propensity to burn out when it goes over 900 degrees.
  9. kellory
    Understood, but since lead melts at about 620° why would I let the temp climb that high? Monitored, and power cut when it gets to the right temp, it should do alright.
    On the other hand, the burner build continues.;)
  10. HK_User
    I guess because you made no mention of monitoring it during your first run.
  11. kellory
    No? Don't have the thermometer yet, and the test was just to see if it would get hot enough. At one hour, I have a melted puddle, but not a full melt yet, so more time or more insulation would be needed. No danger of that 900° mark yet, by a long shot.
  12. HK_User
    Keep on with the burner, it will have a better volume of production.
    kellory likes this.
  13. kellory
    Alright, question about the wax flux. People keep saying "beeswax", but no one local seems to sell it, yet I have thousands of wax toilet rings available. Does it need to be a particular type of wax, or will any wax do?
  14. BTPost
    I use Bees Wax.... I bought 30# Back in the day, and still have over 25# still in stock.... Got it from an Art Supply House.... Google is your friend....
    kellory likes this.
  15. Gator 45/70
    Throw about 2/3'' in, You'll see instant flame and black smoke.. Wait
    Once all of it burns down mix it in or stir like Hades, The impurities will leach to the wax and float to the top, Same as wood shavings
    Skim off the black and start casting!
    BTPost, Tully Mars and kellory like this.
  16. kellory
    Mechanical thermometer ordered, faceshield acquired. :)
    HK_User and Gator 45/70 like this.
  17. kellory
    Alright, gauntlets, faceshield. Thermometer, pot and ladle are ready, beeswax is on order, though I am now told that any wax will do. (3lbs should be enough for a long time.) Heating element does work but is ungodly slow, so I opted for oxy/acet and used a small hand gardening tool as a rake to skim out solids. Thirthy pounds of wheel weights, trash, zinc, steel, and clips yielded 18lbs of lead, cast in round pot shaped discs.
    This was done in the open air, with a breeze at right angles to the work, so no fumes. Lead still needs to be fluxed to remove dirt and ash. IMG_20150315_173250689. IMG_20150315_175530344. IMG_20150315_201052767.
    HK_User likes this.
  18. ghrit
    A garage sale muffin tin will be your friend for ingots.
    HK_User and kellory like this.
  19. kellory
    True enough, but I'm making mine.
    HK_User likes this.
  20. HK_User
    Bricks, the type with an indentation in the middle and the name molded in the center, make an excellent casting source. Each Brick Ingot runs about 1/2 pound.
    kellory likes this.
  1. Gator 45/70
    Link Shooter's Reference Cartridges
    Thread by: Gator 45/70, Dec 11, 2023, 2 replies, in forum: Firearms
  2. 3M-TA3
  3. wideym
  4. Gator 45/70
  5. Oltymer
  6. Ura-Ki
  7. deMolay
  8. ochit
  10. Oddcaliber
  11. Seacowboys
  12. Brokor
  13. ghrit
  14. marlas1too
  15. Seacowboys
  16. Seacowboys
  17. AD1
  18. Bishop
    Has any one ever used this?[ATTACH]
    Thread by: Bishop, Feb 29, 2016, 22 replies, in forum: Firearms
  19. thegoldlock.com
  20. Dont
