Caveman welding
Discussion in 'Bushcraft' started by William Antrum, Mar 25, 2013.
  1. kellory
    Oh, I like Mig, That is what we used for drivelines. (I did all the big stuff)I just no longer have one. I could use the ones at work, but that requires both special weekend access, and someone knowing my business. I have Oxy/Aset on the truck, the buzzbox in the basement, and I glad to know I have a few other options. I hope to score a welder, but food preps must come first.
    I don't want to have to hold this sign at intersections will weld for food. ...
    HK_User likes this.
  2. Airtime
    Airtime Monkey+++
    There are cheap ChiCom mig welders for 100-150 bucks or so. Decent used Miller, Hobart and Lincoln 120 volt MIGs can be found on Craig's list for 2-3 hundred. A 2500-3000 watt generator or battery inverter will power most of these. Add some rolls of flux core wire and you are in pretty decent shape for many repairs or fabrications.
    AT
  3. DMGoddess
    DMGoddess Monkey+
    Right. Tractor Supply, Rural King, etc., in Los Angeles. Pull the other one. On the other hand, there is a welding supply place up the street from HD. If HD doesn't have it, they should.
  4. KAS
    KAS Monkey++
    remember 90% of a good weld is making sure the steal is prepaired ... clean it first .. it dont take anytime any u will be much more pleased with the results...
    Another tip... if u need to cut something and have no other means hot rod it .... get a mild steal rod crank up the amps and start pushing it the metal will go away ...
  5. William Antrum
    William Antrum GunMetal Monkey
    BOOOOYYY I did not know I would get so much input?
  6. William Antrum
    KAS carbon rods may work better for cutting but what do I know.
  7. William Antrum
    RABID : use propane its cheaper and is located everywhere.
  8. William Antrum
    oh by the way the "metal" in a metal coat hanger is not steel its a high tinsel amalgum of crap metal with enough silica to give it its required tinsel strength. Hence the bends without breakage. I have more info than i do have time to share but please exercise greatttt caution in who you get your info . I have forgotten more about welding then 100,000 will learn in a lifetime. I am not sharing to hurt I am sharing to teach. I have been formally trained in Tig,Mig(fluxcore&hardwire),And Stick .If God gave man to make the material he made me to put it together and it does not matter to me the type of metal, the processes, If it can be made I can weld it,braze it ,silver it,etc...........
  9. KAS
    KAS Monkey++
    possibly... i have onl done it with 60snot or 6010 6011 so i know that works ...
    good thread by the way ...
    dont forget about the plasic welding
  10. HK_User
    Yup, made for that, add air and you can blow real sparks.
  11. KAS
    KAS Monkey++
    correct me if im wrong but to use carbon rods dont u have to have a carbon ark {couging rig } to do this ?
  12. ghrit
    Yeah, more or less. The carbon arc is high amperage and melts the metal. Compressed air then blows melt metal out of the cut. I imagine you could come up with a way to aim a compressed air nozzle at the arc if you didn't have a specially designed rig for it. You really need full leathers, yes you do ---
    Silversnake likes this.
  13. KAS
    KAS Monkey++
    yes i am aware i dont believe i would gauge even if i had to ... i hate it i hate the noise / and ever thing about it ....
  14. HK_User
    Gouging is best used to repair a bad weld, usually found after Xrays. Goug out the bad part, grind down to a bevel and make it right. Xray again to check your work. Air Carbon Arc Gouging. In the air carbon arc process, an electric arc is generated between the tip of a carbon electrode and the metal workpiece. A jet of air is directed around the tip to remove molten metal from the area, forming a groove.
  15. William Antrum
  16. Pax Mentis
    Every time I see this thread, I think it is a business in my town...for just a moment.
    We are near the Oregon Caves and the high school teams are Cavemen and there are a number of businesses like Caveman Fence, Caveman Heating, etc...
    [peep]
  17. William Antrum
    Funny huh? But no copyright infringement here no buz, no money made just good freeforall info
  18. William Antrum
    Who else but a caveman would beat two things together expecting them to stick?
  19. ghrit
    Ahh --- any good blacksmith on a forge? ;)
    VisuTrac and KAS like this.
  20. VisuTrac
    Ok, i've not read the entire thread yet but I'll pre-emptively post this.
    DO NOT WELD GALVANIZED ANYTHING UNLESS YOU WANT TO DIE or at least be very ill for a long time.
    Ok, enough for my PSA
Null
