for the Mechanics and Gunsmiths
Discussion in 'Functional Gear & Equipment' started by tacmotusn, Apr 6, 2010.
  1. tacmotusn
    tacmotusn RIP 1/13/21
    Received the following from a friend who is a pretty good mechanic himself. Just thought I would pass it along.
    For all of you that are mechanically inclined.....
    Penetrating Oils Compared
    Machinist's Workshop magazine actually tested penetrants for break
    out torque on rusted nuts. Significant results! They arranged a subjective
    test of all the popular penetrants with the control being the torque
    required to remove the nut from a "scientifically rusted" environment.
    Penetrating oil ..... Average load
    None ..................... 516 pounds
    WD-40 .................. 238 pounds
    PB Blaster ..............214 pounds
    Liquid Wrench ...... 127 pounds
    Kano Kroil ............ 106 pounds
    ATF-Acetone mix... 53 pounds
    The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic
    transmission fluid and acetone.
    Note the "home brew" was better than any commercial product in this
    one particular test. A local machinist group mixed up a batch and all now
    use it with equally good results. Note also that "Liquid Wrench" is about as
    good as "Kroil" for about 20% of the price.
  2. melbo
    always been a kroil fan myself. Used to by it by the case.
    Have to try some homebrew next time I'm removing something...
  3. kckndrgn
    Very interesting, thanks for posting.
    I've got some ATF fluid and Acetone laying around, I'll have to mix and see how it does. I've always used WD-40 & PB Blaster. Tried Liquid wrench once, didn't work that well, so I stuck with primarily PB Blaster.
  4. gunbunny
    gunbunny Never Trust A Bunny
    When working on the Jeep- I've found that nothing works.
    I usually resort to a torch.
  5. gunbunny
    I wasn't being a prick yesterday, heck I wasn't even surfing angry. I just never had any luck, living in the rust belt, and owning old jeeps, when it came to removing old bolts.
    I use WD-40 when working with aluminum, it really helps when drilling, tapping, turning, or parting. I'll have to try the 50/50 mix next time I get a chance to play on the lathe.
  6. tacmotusn
    Hey don't worry, you ain't the first or the last to find themselves having to resort to the torch. I just break'em off flush and cuss a blue streak for hours....lol
  7. ghrit
    I had an old Chief once upon a time, told me that a torch is the last refuge of the incompetent. However, he also said, make sure you have one because it ALWAYS works.
  8. Sherman
    Sherman Dog Eat Dog
    I use ATF, have an old oil can filled w/ used fluid. I also use it when bringing an old motor to life I pull the plugs and pour some right in the cylinder. Then over the course of a few days try and rotate the crank a little w/ a breaker bar till it turns free.
  9. tired-medic
    tired-medic Monkey+++
    Once upon a time kerosene was a good penetrant/light lubricant. Don't know how it works now. Seems the last I had was a bit dry. Diesel fuel is quite dry feeling now also.
  10. KAS
    KAS Monkey++
    gotta love the old smoke wrench!!!
    Only use wd-40 for cleaning my hands...
    definatly will be trying the home brew!!!
  11. Witch Doctor 01
    A long breaker bar helps especially when you are limited in your choice of Penetrating Oil...
  12. KAS
    KAS Monkey++
    also while u have the torch out u dont have to cut it just try heating it a little ...
    and u dont have to have a "cutting torch" to heat it ...
  13. Cruisin Sloth
    here is the thirsty crowd , Beer involved & a mini Ductor with a dog.
    This is used many times around here , liquid wrench (Oxy-Aclene) also.
    & 1K watts , Not AMPS , glad he's not fixing digital machines ..
    KAS , I have many type of great hand cleaners , never use Acetone / MEK type . each type is for a different dirt/grease.
    If you find one for Cooties , I'd be in .
    Sloth
  14. KAS
    KAS Monkey++
    sloth another thing u never clean ur hands with is oven cleaner ... espically if you have and cuts on your hands or busted nuckles...
    dont worry about how i know...
    i think gasoline will work for cooties ... i know it does wonders on crabs !!!!
  15. natshare
    natshare Monkey+++
    Diesel is MUCH drier these days, due to the lower sulfur content formula they're selling. Not sure about kerosene....
    One of the very best penetrating fluids I have ever seen was oil of wintergreen. On my first ship, we scored some from the "doc" (corpsman in charge of medical, on the fast frigate). That stuff might take a day or so, but it creeped in and broke up rust better than any creeping oil we had on hand. Seems they use it in the medical field as a topical analgesic, if I remember correctly (that's going back 30+ years, so no telling how good my memory is on that subject!).
  16. HK_User
    My choice, also good for other uses. I wonder what the torque rating is of Ed's Red Bore Cleaner?
    1 part Dexron II, IIe or III ATF, GM Spec. D-20265 or later. This is automotive transmission fluid
    1 part Kerosene - deodorized, K1
    1 part Aliphatic Mineral Spirits, Fed. Spec. TT-T-2981F, CAS #64741-49-9, or substitute "Stoddard Solvent", CAS #8052-41-3, or equivalent, (aka "Varsol")
    1 part Acetone, CAS #67-64-1.
    (Optional up to 1 lb. of Lanolin, Anhydrous, USP per gallon, OK to substitute Lanolin, Modified, Topical Lubricant, from the drug store)
    MIXING INSTRUCTIONS:
    Mix outdoors, in good ventilation. Use a clean 1 gallon metal, chemical-resistant, heavy gage PET or PVC plastic container. NFPA approved plastic gasoline storage containers are also OK. Do NOT use HDPE, which is breathable because the acetone will evaporate. The acetone in ER will attack HDPE in about 6 months, making a heck of a mess!
    Add the ATF first. Use the empty container to measure the other components, so that it is thoroughly rinsed. If you incorporate the lanolin into the mixture, melt this carefully in a double boiler, taking precautions against fire. Pour the melted lanolin it into a larger container, rinsing the lanolin container with the bore cleaner mix, and stirring until it is all dissolved.
    I recommend diverting a small quantity, up to 4 ozs. per quart of the 50-50 ATF/kerosene mix for use as an "ER-compatible" gun oil. This can be done without impairing the effectiveness of the mix.
  1. 3M-TA3
  3. HK_User
  4. chelloveck
  6. Survivalmike
  7. 3M-TA3
  8. DKR
  9. UncleMorgan
  10. Tempstar
  12. melbo
  13. Dunerunner
  14. Witch Doctor 01
