Gear Review Fresnel lens solar cooker using TV lens
Discussion in 'Functional Gear & Equipment' started by hidden211, Apr 19, 2013.
  1. hidden211
    hidden211 And thats no BULL!!!!!!
    or for purifying water.....
    Icefoot likes this.
  2.
  3. Witch Doctor 01
    Hummm... time to start saving all of those champagne bottles....
  4. Icefoot
    Icefoot Monkey+
    My wife is going to hate you, hidden211, because now I'm adding rear projection big screen TVs to my curbside junk pickup list. I already stop for CRT TVs so I can strip them for electronic components. Drives my wife nuts... :eek:
  5. hidden211
    we must be married to the same woman lol[lolol]
  6. kellory
    It did not occur to me, there was a Fresnel lens in there. I have been offered several over the last couple of years. (the last one was nearly 4X6 screen size.) i will have to keep my eyes open for one. (or 6)
  7. hidden211
    I never knew either kellory makes for an interesting project though
  8. hidden211
    Brokor, kellory and Icefoot like this.
  9. kellory
    Found one out at the street and stripped the Fresnel Lens out of it. took a lever to pop the front off the chassis, wire cutters for the small wires at the bottom of the housing, and a #2 Phillips in a drill and I had it out in about two minutes. Think I will surround it with 1 inch PVC, slotted to fit around it like a picture frame. :cool:
  10. hidden211
    let me know how it turns out still looking for one.i did order a 5 pack of the fire starter lenses
  11. RangerRick
    RangerRick RangerRick-North Idaho Oath Keeper
    I saw this on Dooms Day Prepper a year or two ago. I now have two but found out there or 5 or 6 screens that end up with a different focus so some of the beams are wider than others. They do cook food and boil water fine, but one with a tight focal point heated up a piece of steel to where he was working the steel. I wish I could remember what TV he used. Anyway, if the wife gets upset it is Bushs fault not yours.
    Regards, RangerRick
    North Idaho
    Be Prepared - Be Prayerful - Be Thankful - You are an American
  12. kellory
    [​IMG] [​IMG] [​IMG]
    Witch Doctor 01 and Ganado like this.
  13. Motomom34
    Motomom34 Moderator Moderator
    I have a question regarding fresnel lens. I took one out of a TV. It is big and awkward. I was wondering if I cut it into smaller pieces would it still be effective or does it need to remain large? I would like to chop my lens into 12'x12" so it could fit into packs and easy to store. I have not read anywhere that someone has cut a lens, only used them whole.
  14. ghrit
    Effective, yes, but reduced a bit in heating rate. The amount of ol' Sol's power is directly related to the capture area.
  15. Brokor
    Motomom34 and ghrit like this.
  16. arleigh
    Cutting up you lens will not work .
    If you look closely at the surface it is a series of circles like a record all working together to make the focused beam of light.
    Also not all fresnel lenses will work for this . not all are made to focus into a beam . You may go through several TVs to find one .
    Motomom34 and chelloveck like this.
  17. SkinnyRabbitWithGuns
    SkinnyRabbitWithGuns "Libertarian with soul of a flower child"
    Motomom34 and Brokor like this.
  18. Brokor
    Negative. The lens I linked is for concentrating a small point of sunlight for starting a fire. With the fire you can do many things, though. ;)
  19. ghrit
    @Brokor- I think the question was intended more generally than that. As asked, there are too many unknown factors to give a good answer. So, maybe.
    Brokor likes this.
  20. ghrit
    If you cut to save the center, it'll work, just as stated above in post 13. You are right, a random hunk of busted fresnel will do nothing useful but cut. The center is the important part, and then only if it is big enough.
  21. Brokor
    Ah, okay. Well, if one were using a fresnel lens to heat water in volume, it would be ideal to use a focus chamber of sorts and find a method to pump the water through it in a timed fashion which would allow each quantity of water inside the chamber to be heated according to the requirements. (As opposed to trying to heat a large container all at once due to latent heat problems)
    GrayGhost and ghrit like this.
Null
