German Utility Workers Parka, Not a Hoodie but a heck of a bargin.
Discussion in 'Functional Gear & Equipment' started by HK_User, May 18, 2018.
  1. HK_User
    Yes I now own this item, in fact two! A large for over wear in really cold temps and a Medium for use with just a wool shirt or other wear such as Rain.
    German Utility Workers Parka | Keepshooting
    NEW At $24.95 and it Meets or Exceeds EN343 Standards for Breathable, Wind and Waterproof Work Wear
    Features:
    • Water and Wind Resistant Parka
    • Made for German Utility Line Workers
    • High Visibility Snaps and Stripes
    • Stowable Hood
    • Unissued - Made in Germany
    • Meets or Exceeds EN343 Standards for Breathable, Wind and Waterproof Work Wear
    Motomom34, GOG, Mountainman and 11 others like this.
  2. Seawolf1090
    Sadly, they don't have my size.
  3. Bandit99
    That's a hell'va deal for $25 if the quality is anywhere close to what I assume it is given it's Germany standard.
    Does the sizing run about normal or do need get one size larger?
    Tully Mars likes this.
  4. HK_User
    Sizing is normal for a utility coat. The Medium has 48 on the inside collar tag and works well over a heavy work shirt. I wear a 44 so it gives a little working room.
    Quality is excellent, the inside seams are protected by folding the liner over itself. this means the last point to fail in even the roughest wear is the liner. Minimum Velcro, mostly zipper closer pockets and the outside lower pockets have drain holes which means you can put wet gloves, parts or tools in the pockets and even keep the pocket flaps open and water won't collect in the pocket.
    Well made inside pockets too.
    Hood under the collar has a small bill and a typical toggle tightener.
    Since my winter go to jacket lost its zipper this will replace it.
    The cats like that since the older coat is now the cover for their OP.
    Gator 45/70, Tully Mars and Bandit99 like this.
  5. Bandit99
    I need something to bang around in. Something I can toss around, that has big pockets, waterproof and big enough that I can get heavy shirts or sweatshirt under it for winter. Durability is the keyword as I am hard on clothes and for $25 bucks this is a steal. It also have all the reflector stuff in case I get caught next to the roadside or etc. I will order one this evening. Thanks!
    Gator 45/70, HK_User and Tully Mars like this.
  6. HK_User
    I just found another plus. If you turn the left sleeve side inside out you will see a long zipper that provides access to the inside of the jacket that meaning between the liner and the outer water proof membrane. I imagine it will allow you to repair the outer part of the jacket as well as the liner. More than once I've had to slit a seam when I need to repair a jacket.
    Now a quick iron on patch will be easy to apply inside the jacket where it won't get ripped off with wear and tear.
    Buttons are also reflective.
    Ends of the sleeves are also designed to allow you to work with your arms above your head and rain is limited in its ability to flow inside the sleeve.
  7. BTPost
    I get my OuterWear from "Washington Tent & Awning"... they Custom Fit, just for me...
    Zimmy, HK_User and Tempstar like this.
  8. ghrit
    Is that Omar's shop?
    j/k
    Zimmy, HK_User and Tully Mars like this.
  9. BTPost
    Naw, they are the PNW Sailmakers... in Seattle, Wa...
    Zimmy, HK_User and ghrit like this.
  10. Tempstar
    Tempstar Old and crochety
    Ordered one. Thanks for the tip!
  11. Mountainman
    Got one along with 2 100% wool blankets, thanks for the heads up!!! Going to take off the reflective material and paint the buttons black.
    Motomom34, Zimmy and HK_User like this.
  12. HK_User
    Got any patterns for those blankets, inquiring minds want a pic.
  13. Mountainman
    Just going to use as regular blankets, nothing special.
    HK_User likes this.
  14. Tempstar
    Mine came in, ordering a large and gifting the Xl to someone. They seem a tad big, but a really nice coat.
  15. Mountainman
    Damn, ordered one size bigger then I need to have extra clothing under and hope I don't have to order another one. German sizing must be from all the great bier and schnitzel the have.
  16. Tempstar
    My XL compares to a 2X, what the friend I gifted it to wears. Fits him loose enough for layers underneath. These are really well made with a hide away hood and velcro sleeve cinches, and flap over the zipper. Should be a great storm coat as it is thigh length. My new one will get waterproofing on arrival.
    Mountainman likes this.
  17. HK_User
    When you get it undo the arm zipper and look on the inside. It has a gray gortex like middle liner.
  18. Tempstar
    I will, thanks!
  19. Mountainman
    Nice jacket and well worth $25. Forget about taking off the reflective material unless you want to tear it apart and sew most of it back together. Sizing is a little big but okay if you want to wear extra clothing and hardware under it.
