Recipe Homemade Pork Tasso
Discussion in 'Recipes' started by tacmotusn, Nov 1, 2015.
  1. tacmotusn
    This one appears to be an easy to make Tasso recipe with common ingredients and the use of a smoker suitable for jerky.
    with pork as cheap as it has been recently, I will be trying this real soon. Tac
    Homemade Tasso Recipe
    November 3, 2005 Danno 22 Comments
    Tasso (TAH-so) is a smoked seasoning meat used to flavor dishes like Gumbo, Jambalaya, and Red Beans & Rice. Tasso used to be made from the trim after an Acadian Hog Boucherie, thin strips, heavily seasoned, dried, then smoked for hours. These days however, most of the Tasso that is available is a little more fancy, more of a ham than the style of the old days, mine is somewhere in between. I always find it amazing how ingredients and recipes, that basically came from scrap and the poorest times evolve into Gourmet, I love it. Tasso will keep in the freezer and is pretty easy to make, but you have to do a little planning.
    A few Tips:
    After seasoning it, I recommend keeping it in the fridge, at least 3 days to let it cure, look at how nice and pink the center is.
    Take it easy on the Cayenne when making your seasoning blend, start off with a small amount, then add to your taste, the amount here is moderate. It should have some heat, but I don’t like losing control of the heat in a dish I’m cooking because my Tasso was too hot, so I cut it back a little, for the same reason that you don’t salt stocks.
    Here is my recipe for Tasso. I used a Boneless Pork Roast cut into about 4-5 inch long, 1/2 to 1 inch thick slices. This is seasoning for about 5 lbs of pork:
    5 lbs Pork cut as described above
    Seasoning:
    3 Tbsp Kosher Salt
    2 Tsp Cayenne or To Taste (see above)
    4 Tbsp Paprika
    2 Tbsp Fresh Garlic, minced
    2 Tbsp Coarsely Ground Black Pepper
    1 tsp Cinnamon
    1 Tbsp White Pepper
    1 Tbsp Brown Sugar
    Mix the seasoning together well. Rub the seasoning into the meat, you want a lot on there, call it 1/8 inch, use it all. Place on a plate or tray, cover and refrigerate 3 days.
    Before smoking put the Tasso on an elevated rack so that air can circulate around it, then put a fan on it for about 2 hours to dry it out. I also don’t use a water pan when smoking Tasso, this is something that I actually want to dry out during the smoking process.
    I hot smoked this batch in an inexpensive upright barrel smoker using charcoal as the heat source (heated with a chimney starter, no lighter fluid or matchlight coals please.) I used Pecan chips that were soaked in water for 1 hour for the smoke.
    I smoked this a total of about 4 hours, the first 2 hours at about 150-160 degrees F. The second two hours at 180-190 degrees F.
    The object is to get as much smoke into the meat, before cooking it all the way through. I brought the internal temperature of the meat to 150 degrees F in the last 2 hours of smoking.
    When finished I again put the Tasso in front of a fan for about 1 hour. Refrigerate. When completely cold portion and store the Tasso in vacuum sealed packages. Freeze.
    Makes 5 lbs of Tasso
    Related Links:
    Andouille Sausage Recipe
    Chaurice Sausage Recipe
    Pickle Meat Recipe
    More on Tasso:
    Check out these Pics at Egullet of Wayne Jacob’s beautiful Tasso and Andouille, made the old way in LaPlace, Louisiana.
  2.
  3. pearlselby
    pearlselby Monkey++
    Tacmotusn, I have a couple of pork tenderloins. I think I will try it. The pictures at Egullet sure make me want to go back for a long visit.
    Ganado and tacmotusn like this.
  4. pearlselby
    pearlselby Monkey++
    Tacmotusn, I clicked on one of those links and spent quite a while reading about curing meat then you click on something else..lol..
  5. tacmotusn
    My dear lady, you started this. .... LOL, I am only just starting to explore the branches of the tree you provided. I love a new source for a journey. ...... The starting point "Nola cuisine" is a treasured diamond of a starting point. It has only 12 pages of recipes at this time, but many are big fat pearls that also will be cherished. They copy very easy for my email recipe file and or to easily print out for hard copy or to give away to other foodies.
    Ganado and pearlselby like this.
  6. pearlselby
    pearlselby Monkey++
    I ended up all over the map on "Nola cuisine." I even woke up at 3 am and came back in here to check on some links I had saved. You are right. It was a tree alright.
  1. sdr
  2. Bishop
    Here is my twist on veitnamess pho [MEDIA]
    Thread by: Bishop, Nov 19, 2017, 4 replies, in forum: Recipes
  3. chelloveck
  4. tacmotusn
  5. Hanzo
  6. Motomom34
  7. Seacowboys
  8. tacmotusn
  9. Motomom34
  10. Motomom34
  11. tacmotusn
  12. Homunculi
  13. Thunder5Ranch
  14. Ganado
  15. Pax Mentis
  16. Motomom34
  19. Dunerunner
Null
