How do you limit amp output from an alternator?
Discussion in 'Off Grid Living' started by Duck, Jun 18, 2014.
  1. Macgyver
    Macgyver Monkey++
    Look up Progressive battery charge controler. These are used in the RV and marine areas. Great controllers. Amazon has them available.
    mechstdr and Dunerunner like this.
  2. mechstdr
    mechstdr patriotic grease monkey
    i remember a file in resources-energy-build your own 12 volt dc generator. the alternator used was an external regulator type, the design used a fixed or variable resistor to control input voltage to the field and conversely the output voltage/amperage. i agree you would be better off with an automatic V.R. but this setup may be useful for equalizing charging.
  3. mechstdr
    i saw a generator at an equipment auction once it was used for jump starting trucks/hvy. equip. it consisted of a 1cyl. engine 12-16 hp. and 4 big truck generators not alternators, it was wired using ford start solenoids to use 1 or 4 gens. series/parallel 12 or 24 volts, was way cool but went for big bucks. :cry::(
  4. Big Ron
    Big Ron Monkey+++
    Most alternators have a voltage regulator. If not a charge controller for solar would work. I remember my big rig had a 130 amp alternator. I think it was a 24-volt system(several batteries) military M series was 24 volts.
