Resource How To Wire Your House For Solar Electricity 2018-07-18
A Brief Article On Wiring Your Home For Solar
  1. Asia-Off-Grid
    Asia-Off-Grid RIP 11-8-2018
    Zimmy and snake6264 like this.
  2. Out in the woods
    Our house was 'on-grid' then we shifted it to solar-power. There was no change in the house wiring.
  3. Asia-Off-Grid
    Fair enough. But, let's compare 12vdc to say 120vac. Lower voltage equals higher amperes to perform the same job. You would never be able to power something on 12DC, that you could using the same sized AC cable run for 120vac, at the same ampere draw. It won't happen.
    Lower voltage = higher amperes
    Higher voltage = lower amperes
    4000 watts at 12 VDC = 334 amperes
    4000 watts at 120 VAC = 34 amperes
    The only way to lower your ampere draw, is to run higher DC voltage for your solar powered system. If I may, what is the voltage of your battery bank?
  4. BenP
    BenP Monkey+++
    It can be done as long as you use low watt DC bulbs/fixtures. Our house is wired like it would be for AC with 12g thhn wire but we use DC lighting fixtures that draw 3w each. Thhn 12g is good for 20 amps but I put them on 15 amp breakers 15 amps X 24v = 360 watts would let me run about 100 light fixtures. Most of the house is 4 fixtures per breaker just due to the way I ran the wiring, 1 light circuit per room, 2 for living room.
    I expect Sloth to chime in here anytime. :)
    Asia-Off-Grid likes this.
  1. naveedsaddar1111
  2. T. Riley
  3. TnAndy
  4. DKR
  5. Prepper12
  6. Yad Tsalach
  7. Gafarmboy
  8. TnAndy
  9. Sojourn
  11. jcsok
  12. Cruisin Sloth
  13. ED GEiN
  14. Redi2
  15. SurvivalJester
  16. Asia-Off-Grid
  17. Asia-Off-Grid
  18. bsr1st
  19. Asia-Off-Grid
  20. Asia-Off-Grid
