Inherited a solar problem
Discussion in 'General Discussion' started by Tempstar, May 26, 2018.
  1. Cruisin Sloth
    Nothing , IT'S your Trailer !!!
    I deleted MY points .
    I CANNOT have a conversation with DIY while we have a OP who is in a NEC /UL and a school (KIDS) with comments that are not true !
    Licence , Teach , Design ,
    IBEW since 70's
    NABCEP 2002
    And I wright some questions !!
  2. Tempstar
    Tempstar Monkey+++
    Update: After chasing this around for a bit, I finally got my answers. The system provides 24 KWH(full sun May to September) which is fed to the grid, and offsets our usage charge for any period it is making power at a 1:1 rate. Since the building draws more than 24KWH even on weekends and holidays, there was never any provision to sell power, only trade. There is an automatic transfer switch that cuts the solar power to the grid anytime there is a grid power failure that must be manually reset by the power company. The initial thoughts were that 5 schools so equipped would offset the energy usage for one, thus the 5 we have and the 5 more scheduled to be built. We have "Smart inverters" that will match cycles before flowing power, much like an emergency generator will sync before transfer. Estimated payback for the 2.4 million dollar system is 20 years, excluding any repair expense. The initial focus was on the monthly energy savings rather than ROI.
    Now I move on to the Ice Banking system that isn't making ice and is just functioning as an ordinary chiller system. How anyone could justify spending this kind of money with no one onboard to maintain it is beyond my feeble comprehension.
    Cruisin Sloth, Dunerunner and HK_User like this.
  3. Dunerunner
    It is my experience that the school district maintenance department is largely made up of poorly skilled individuals who can change fluorescent lamps, mow the grass, fix a loose screw on a door hinge and paint. Anything beyond that the maintenance manager hires a contractor.
    Cruisin Sloth likes this.
  4. HK_User
    And they think they are saving money.
  5. HK_User
    Low on refrigerant?
  6. Dunerunner
    Lint clogged condenser ?
    HK_User likes this.
  7. Tempstar
    Tempstar Monkey+++
    Two 400 ton Trane chillers with air cooled condensers, system has been hacked to run during the day because of faulty loop valves and un-programmed VSD's. They make chilled water and keep the building cool, but no one can get the system to make ice at night during low demand rate time. The walk through today revealed 3 loops, one for the chilled water to the building, one for chilled water through the chillers, and one for making ice in 12 above ground tanks. This one is really broken and will take some time and $$$ to get straightened out. Control valve actuators are $900 each and I need 4 just to get started.
    Dunerunner, Cruisin Sloth and HK_User like this.
  8. HK_User
    Any schematics or Op Manuals?
  9. ghrit
    Trane turbo machines? Check the inlet vane actuators, they used to be used for capacity control and were a failure point years ago. (I believe, but do NOT know that more recent machines are powered thru VFDs.) If there really are three loops, the control algorithm is the hackable point. I have this awful suspicion that there are only two loops. One that looks like two just might have a valve manifold that can shift from parallel to series operation. That very well could be way off the mark, but I've seen a design that tried to do that.
    Dunerunner likes this.
  10. Cruisin Sloth
    enphase grid tie are set to disconnect on no grid & resysnc in . POWER company has no override or link that I have ever seen .
    This design was done in arlington WA , where Im AT NOW.
    Sloth
  11. Tempstar
    Tempstar Monkey+++
    Screw machines running on VSD's. Building is a loop and uses a decoupler to tie to the chiller loop, and the chiller loop can switch between a straight chilled water loop or to the ice bank loop via 3 way valves. I see the intent and it's a proven idea to get off peak demand, but they allowed it to be installed with no training for any of the staff back in 2008, and it worked until it didn't. Then no one had a clue how to fix it.
    ghrit likes this.
  12. Tempstar
    Tempstar Monkey+++
    Their guy tells me that they have to verify integrity before allowing the system back on the grid, so the manual reset point. I'm used to much smaller scale with single grid-tie inverters, not 100 inverters that sync themselves.
