Gear Review K8 Nuke Safeguard - Personal Radiation Indicator
Discussion in 'Functional Gear & Equipment' started by Brokor, Sep 10, 2014.
  1. Brokor
    This K8 Nuke Safeguard, tested by using NIST traceable sources, is capable of detecting low level of nuclear radiation & very small amounts of radioactive materials nearby, and is an ideal personal nuke safeguard device. It meets NCRP Guidance & Recommendation for Management of Terrorist Events.
    knuke2.
    Applications
    The Market's Most Sensitive Miniature Radiological Warning Device:
    • Fast Acting - Alarms in 2 to 4 seconds of source presenceSensitive
    • 5 mR/h or greater triggers the alarmsEconomical
    • A low cost / high value solution for exponentially expanding your detection capabilities
    • Discrete
    • Fits easily almost anywhere. 25 mm x 39 mm x 12 mm; 13g or, 1" x 1.5" x 0.475'; 1/2 oz.
    • Rugged - A durable clamp that you just can't shake.
    • Exceeds drop test requirements of ANSI 13.27
    • Audible alarm. And, the bright LED alerts in inaudible environments
    • Certified - CE. NCRP. EMC. NIST. ANSI. And, each unit is tested by a Doctor of Physics
    Features
    Red flashes/alarm @ 5 mR/h (50 ìSv/h)
    Specifications (All specifications are subject to change without notice)
    Detector; Si-detector
    Detection: X & Gamma; 30 keV - 6.2 MeV
    Natural radiation: Approx. 5 to10 minutes per green flash
    Extreme high field: LED keeps flashing/Alarm keeps beeping @100 Sv/h
    Battery: One standard CR2032 battery with ~1500h battery life
    Low battery indication: Yellow flash; 12 hours usage after low battery indicated
    Temp. & Humidity: -30°C to +50°C, >95%,
    Ruggedness: Exceeds drop test requirements of ANSI 13.27
    Package: High impact plastic housing and clip
    Size & Weight: 25mm x 39mm x 12mm, 0.5 oz. (13g)
    ___________________________________
    My photos of the modified K8 Nuke:
    My Personal Findings
    Surprisingly enough, it really is a clip-on and forget kind of item. I had to modify the belt clip after I broke the original one. I have had this for about 4 years now, so it's seen some use. The battery lasts for several months, but I do turn it off occasionally. I suppose one could just buy a supply of CR2032 batteries and keep this running all day every day. I would estimate the battery lasting maybe two months like this, perhaps longer. I think the ambient temperature has something to do with battery life.
    Check the video out below on how I attach this modified K8 Nuke. I have an elastic band attached to the new clip, and I flip that over top to secure it. There's no way it can ever come off until I want to take it off. I used a clip from a Kershaw OSO Sweet knife, and JB-Weld with some spray paint. It suits it very nicely!
    It can be bumped around, the case is quite sturdy. Some folks with big, meaty fingers will need a small toothpick-like object to flip the power switch. Also, when changing the battery it likes to chirp for a bit once in a while. I just flip it on and off a few times, then it calms right down. It's no problem, just keep it in mind.
    DSC00005.JPG I live in between two nuclear plants. It always pays to have protection by way of an early warning system, even though these nuclear facilities are very safe. Regardless, I also carry KI (potassium iodide) on me at all times.
    VIDEO:
  2. BTPost
    @Brokor So, how much is it? Inquiring Minds want to know......
  3. ghrit
    Looks to be a rate meter and doesn't record the total dose a wearer is exposed to. Gamma and xray only, so won't measure beta or alpha emitting surface contamination that you might breathe or eat. I guess I don't see the utility of it unless you are going to enter a known radiation area, but in that event, it should do quite well if properly calibrated.
    AmericanRedoubt1776 and Brokor like this.
  4. sec_monkey
  5. sec_monkey
  6. sec_monkey
  7. Brokor
    I think people can do their own shopping. I didn't link a price or place to buy because it's been out a while and the price varies.
  8. Brokor
  1. AgentPickle
  3. JC Refuge
  4. Asia-Off-Grid
  5. Asia-Off-Grid
  6. ED GEiN
  7. JC Refuge
  8. Yard Dart
  9. melbo
  10. melbo
  11. melbo
  12. survivalmonkey
  13. Blackjack
  14. survivalmonkey
  15. Bear
