Figured this area would be the best place to put it OTAL with A.R.M.S. Throw Lever Mount (635nM) Laser for AR-15, M-16 and M-4 Day & Night Visibility Item #: 19105 Price: $646.00 This personal demo model can be yours for $510 via USPS money order and that is the DELIVERED price! You can not tell the difference between this and "NIB". I mounted it on a SIR and RAS to demo a couple of times...after that, it was in the safe. The OTAL with an A.R.M.S Mount is designed for military and Law Enforcement applications. This unit mounts behind the front sight cage on the AR-15, M-16 and M-4 style rifle. Comes with a right angle connector a, 6' inch standard remote cable and a pressure pad switch. Features A.R.M.S. mount provides a solid repeatable alignment for all aiming lasers and tactical lights Fits all NATO 1913 and Picatinney rails Manufactured in the U.S.A. No tools required Offset design allows the laser to be mounted behind the front sight cage on AR-15, M-16 and M-4 style rifles Proven MIL-SPEC mount locks the accessory to the weapon rail. Quick release system allows the user to instantly attach and detach the laser and tactical light Supplied with a right angle connector and a 6 inch (15.25 cm) standard remote cable and a pressure pad switch Windage and elevation adjustment knobs are protected from impact Windage and elevation adjustments can be made in precise 0.4 milliradian clicks Electrical Specifications Battery: One 1.5 volt AA Battery Life: 5 hours continuous Beam Diameter: 6.5 mm @ 25 meters Laser Type: Laser Diode Class IIIa Power Output: <5mW Range/Visibility: 450 meters (low light) 30 meters daytime Wavelength: 635nM (SPP) Mechanical Specifications Width: 1.4 in.; 3.6 cm Environment: Waterproof to 20 meters Length: 2.8 in.; 7.2 cm Limited Warranty: One year Material: Anodized aircraft aluminum 6061T-6 Weight: 4.9 oz.; 138.9 grams with barttery
Yes. It will go to about 35m in bright daylight. At night it is unreal...a beam as far as you can see
