Methane generator
Discussion in 'Survival Reading Room' started by monkeyman, Aug 13, 2005.
  1. monkeyman
    This site is a bit overwhelming to me but if you can get it figured out you could do like a few large farms I know of that have larger versions of these that turn raw sewage into methane which runs generators (in at least a couple cases that provide power to surounding area) and even farm equiptment and vehicles.
    link;
    http://journeytoforever.org/biofuel_library/MethaneDigesters/MD6.html
    Methane Digesters
    For Fuel Gas and Fertilizer
    With Complete Instructions For Two Working Models
    by L. John Fry
    10 Building an Inner Tube Digester
    Fig. 21 Attachment of pipes and buckets
    I hope that in these times of ever increasing pressures in the energy crisis, that this inner tube unit will be made available to the millions on millions of people around the world who could benefit from it. To those on the land eking out an existence, I dedicate this unit. As a morsel of technology, it might well benefit them more than a man standing on the moon.
    -- L. John Fry
    Inner Tube Digester Parts List
    1. Main Chamber of the Digester
    2. The Plastic Insert
    A. The Plastic Cylinder
    B. The Inlet, Gas and Effluent Pipes
    -- Inlet Pipe
    -- Gas Outlet Pipe
    -- Effluent Pipe
    3. Attaching the Cylinder to the Inner Tube
    4. Inlet Fittings and Attachment of the Slurry (Feeding) Bucket
    -- Attachment of Bucket
    5. Fitting the Effluent Pipe
    6. Fitting the Gas Outlet
    7. The Scum Collector
    -- Gas Outlet Continuation
    8. Gas Yield Indicator
    9. Pressure Release Bottle
    10. Inner Tube Storage
    11. Burner
    12. Temperature
    13. The Bacterial Brew
    14. Feeding
    15. Removing Scum and Effluent
    A. Scum
    B. Effluent
    16. Safety Precautions
    -- Precautions In Gas Usage
    17. Lighting the Flame
    18. pH
    The following inner tube unit was made at a cost of about $20. If it could be produced in quantity, the cost might be as low as $2 using cheaper material.
    The unit has no working parts and should last the normal life of the materials used.
    This inner tube digester has been tested out in Santa Barbara for over 18 months, during which all the "bugs" have been eliminated. It is a thoroughly reliable device.
    NOTE: Read "Safety Precautions" (#16 below) and "Starting The Bacterial Brew" (Sump Digester) before beginning construction.
    Truck or tractor sized inner tube
    Plexiglass (1/8" thick) 7" x 28" (or circumference of inner tube). Plexiglass 10" x 10".
    Methyl chloride liquid (hobby shop)
    Plexiglass tubes (2" x 3')
    2 x 2-inch diameter bicycle inner tubes
    Polyvinylchloride (PVC) tape
    3 x 5-gallon polyethylene buckets
    5-gallon container -- metal or plastic -- for scum collector
    Epoxy resin
    Rubber sealing compound
    Rubber cement
    Wire
    Pipe adapter (kind that goes from steel to plastic)
    1/4" rubber or latex hose
    1 gallon jug with cork with two 1/4-inch holes
    Bottle
    T pieces
    Truck inner tubes (storage)
    Screw type pinch clamp.
    This consists of a discarded truck-sized (or better still, a tractor-sized) inner tube.
    Test carefully for leaks. (Bear in mind that every part going into the digester should be carefully tested for leaks. Any gas escaping, out of even a pinhole, is a potential cause of explosion.)
    Patch over, if necessary. If there is a large gash or hole, cut that portion completely out of the tube.
    Make a clean cut at right angles to the long circumference of the tube. This is where the plastic cylinder will be inserted (Fig. 21).
    Thoroughly wash and dry the inside of the tube. The inner tube is now ready for the plastic insert.
    Fig. 22: Preparation of the inner tube
    Heat a 1/8" thick x 7" wide x about 28" long (length should be the circumference around the opening of the inner tube, picture 2) piece of plexiglass in a 400°F (200°C) oven, until it will bend (about 5 minutes).
    Bend it around a saucepan or other cylindrical object which has the same circumference as your inner tube. Make the ends of the plexiglass meet to form a cylinder.
    Glue the ends together by generously applying methyl-chloride glue. The glue can be made by melting some acrylic scraps in methyl-chloride.
    Cut a round flat piece of plexiglass to fit inside the cylinder, and glue this plate with methyl-chloride glue midway inside the cylinder (Fig. 23, 24). This will make a central dividing wall to keep the manure from circling around and around the inner tube.
    The lip. Heat a 1/4" x 29" strip in a 400°F (200°C) oven for 5 or 10 minutes. Wrap around the outside edge of the plastic cylinder to form a rim. (This will help keep the inner tube from sliding off the cylinder.) Hold the hot plastic strip in place with clothespins until cold. Eyedrop straight methyl-chloride between the two surfaces. Keep the clothespins on until surfaces are securely stuck together. Repeat for other cylinder edge.
    These are constructed of 2" diameter, heavy-duty plexiglass tubes. The inlet pipe will be inserted on one side of the central dividing wall of the cylinder and the gas and effluent tubes on the other side, as follows (Fig. 23, 24).
    1. Make three 2" diameter holes, one on one side of the center divider, two on the other side (Fig. 23, 24). Exact placement is not important, but must be so close to the baffle as to touch it and in the general area shown in Fig. 24. Apply a little glue at the touching point for added strength. Allow at least 1" between the tubes to the lip of the cylinder (Fig. 23). We made the holes by burning around the outside edge of the hole with a simple soldering iron. A FRET saw would do a better job.
    Fig. 23 Cross section of the plastic insert
    Inlet Pipe:
    2. Ream out the inlet pipe hole to allow the inlet pipe to go in at a slight angle (Fig. 24). This angle helps the mixing in the inner tube, by tending to make the incoming raw slurry revolve in the tube.
    3. Insert the pipe in at an angle, 4" down into the cylinder (Fig. 23). The distance the pipe sticks out the top of the cylinder is not important.
    4. To eliminate leaks, seal the seam around the pipe and hole with: (1) a layer of melted plexiglass and methyl-chloride and then (2) a layer of rubber sealing compound available in hardware stores.
    Gas Outlet Pipe:
    5. This pipe is glued to the top of the cylinder (Fig. 23). Again, the length of the pipe sticking out the top of the cylinder should be about 6 inches. Length in Fig. 23 is about right.
    6. Seal as above.
    Effluent Pipe:
    7. Insert the effluent pipe straight down into the cylinder to 1" from the bottom. (Fig. 23.) Again 6" above top.
    8. Seal seams as above. Where the inlet and outlet pipes touch the center baffle, apply a little glue to give added strength to them, as mentioned above.
    Fig. 25 Placing the cylinder in the inner tube
    Paint the inside of each open end of the inner tube to a depth of about 2" with any kind of rubber cement (Fig. 22).
    Insert the cylinder into the inner tube, past the lip, to a distance far enough to ensure a good seal (Fig. 25).
    Tape in place with polyvinylchloride (PVC) tape to hold cylinder and inner tube securely in position (Fig. 26).
    Then wind wire twice around on the tape. Twist the ends of the wire to make a very tight hold. (The wire and the tape are never removed.)
    Fig. 26 Fastening tube to plexiglass cylinder
    1. Cut a 2" diameter balloon bicycle inner tube to a length of about 3', after checking for leaks.
    2. Place it on the inlet pipe (Fig. 21).
    3. Tape with PVC tape which is adhesive on one side only, by stretching the tape very tightly around the pipe and inner tube. Make sure it is taped firmly.
    Attachment of Bucket:
    4. Burn a hole in the polyethylene slurry bucket, 1" from the bottom of the bucket. (Fig. 20 and 22.) When the hose is attached to this hole off the bottom, it will allow sand, feathers and other heavy indigestible material to settle to the bottom of the bucket and be left behind when feeding the slurry to the digester.
    5. Attach an adapter in the hole of the type used to go between steel and plastic pipe.
    6. Attach a length of 2" bicycle inner tube to the adapter in the slurry bucket with PVC tape. The tube should be long enough to allow the bucket to be held up for gravity feeding the slurry into the digester (Fig. 20).
    Simply tape another length of 2" bicycle inner tube to the effluent pipe (Fig. 21) .
    Hang the tube in a bucket.
    Attach a 2' or 3' length of the 2" bicycle tire tubing to the gas outlet with PVC tape.
    Lead it to the scum collector.
    If you remember, scum is a mixture of (1) floating material (bedding, straw, feathers, etc.) and (2) liquid interspersed with (3) gas bubbles. Scum rises up with the gas out of the gas outlet. Scum formation is a major problem in any sized digester. On this scale, though, it is simple to eliminate.
    1. Select a metal or firm polyethylene container with at least a 2" wide filler cap. We used a 5 gallon, plastic milk container. It is much easier to attach the pipes to a metal container, though.
    2. Turn the container upside-down (filler cap underneath) and make a 2" hole in the top. Solder or weld a short length of 2" wide metal pipe to the top (this was the bottom of the container originally) (Fig. 27).
    3. Firmly tape the inner tube coming from the gas outlet to the short length of pipe. Scum will be forced through the gas outlet, through the cycle tube and drop in the container. Gas will continue on its way to storage via:
    Gas Outlet Continuation:
    4. Solder or weld a second pipe at another point on the top of the container. The hole should be 1/4" in diameter (Fig. 27).
    5. Tape a length of 1/4" rubber or latex hose to the 1/4" pipe. This will go to the gas yield indicator bottle (Fig. 20).
    Fig. 27 Scum collector
    This is a jug of water, through which the gas from the digester bubbles. It is a nice way to see that your digester is producing gas. (Also, if the water is changed frequently, it will filter out some of the carbon dioxide in the gas.)
    Take a 1 gallon jug and place a cork with two 1/4" holes in the bottle's mouth (Fig. 28).
    Place between the scum accumulator and pressure release bottle (Fig. 20).
    Fill the jug with about 6" of water.
    Run the hose from the scum accumulator, through one cork hole and to 4" below the level of water in the bottle.
    Run another piece of 1/4" rubber or latex tubing out of the other cork hole, to the pressure release (overflow) bottle.
    This bottle is placed between the gas yield indicator and inner tube storage (Fig. 20). It allows the release of extra pressure in the inner tube storage, or overflow of gas to escape through the water in the bottle, rise to the atmosphere, and disperse harmlessly.
    A 12" or so deep bottle is fitted with a "T" piece (Fig. 29).
    The tubing from the gas yield indicator is attached to one arm of the "T" and a tubing to storage is attached to the other arm.
    A plastic tubing is attached to the leg of the "T" piece and immersed in 8" of water.
    In the event that the gas pressure is more than 8" water gauge, the gas will escape through the water, to the atmosphere.
    Gas can be stored in one or a number of truck inner tubes, stacked on each other and interconnected with "T" pieces (Fig. 20). Check for leaks and patch if necessary.
    A weight, such as pieces of lumber, are placed on the topmost tube to create pressure.
    11. Burner
    The gas produced by this digester is about 700 BTU per cubic foot at sea level (585 BTU at 6000 ft. altitude). The average daily production of this system is 5 cubic feet; enough to bring 1/2 gallon of water to the boil and keep it there 20 minutes. THIS IS ENOUGH TO COOK A MEAL.
    The simplest burner can be a piece of 1/2" metal pipe 18" to 2' long.
    Place on a reducer to 1/4"to fit the tubing from storage.
    Place some sort of on/off clamp on the tubing, plus a pinch screw to regulate the amount of gas (Fig. 30).
    The 1/2" pipe is laid between 2 bricks and a third brick is placed on the pipe to hold it in position.
    12. Temperature
    Methane bacteria only work their best when kept warm. The best temperature is 95°F (35°C). Without artificial heating the only areas in which a digester will function is in or near the tropics. Thus, without supplemental heat, this unit is limited to the tropics. Alternatively, if placed in an insulated box and heated by two 100 watt light bulbs in series (this takes very little electricity and the bulbs last a long time), with a thermostat set to 95°F in the circuit, it can be operated almost anywhere.
    Add to Manure Contents (See 9 Building a Sump Digester -- Making Starter Brew)
    14. Feeding
    The daily routine consists of collecting three 1-pound coffee cans full of dry chicken manure. (Almost any kind of manure is suitable, but to avoid excessive scum formation, a finer texture manure is better. Chicken or pig manure is probably the most suitable.)
    Stir in the slurry bucket with 3/4 gallon of water or urine to form a slurry. If you can use urine instead of water, it will aid fermentation and make the effluent a better fertilizer after digestion.
    Now raise the bucket high so that the slurry will gravity feed into the digester. It will mix with yesterday's load, which by now has been "seeded" with active, hungry bacteria. The inlet pipe (set at an angle) helps the mixing, by tending to make the incoming raw slurry revolve in the inner tube.
    Dispose of the feathers, fiber, sand, etc., left in the bottom of the bucket.
    The action inside the digester is the same on any scale. The raw material, heavily seeded, tends to skulk along the floor of the digester but as the bacteria work on it, gas is formed and lightens it in relation to surrounding material. Vertical motion begins, throwing up chunks of dung and bubbles of gas. Each load displaces the last, around the circuit round the inner tube. At some stage each and every particle has to pass a point of maximum fermentation where the whole mass seethes and bubbles furiously. Up and down currents mix the contents thoroughly. From there the fermentation slows and stratification begins into the layers of gas, scum, supernatant and sludge... the spent portion of the original solids. Through digestion this sludge will have contracted considerably from the original raw state.
    Failure of the bacterial "brew" will occur if excessive loads of manure are used. Keep to three 1-pound coffee cans daily. If not fed daily for one reason or another and the unit is left without "food" for a week for instance, start it up again with four and one-half coffee cans full the first day and continue as usual afterwards. Do not feed in back coffee cans full for each missed day (21 cans for 7 missed days).
    A second reason of failure of the brew is an excess of water, particularly cold water.
    A. Scum
    1. When the scum collector container feels heavy, remove the filler cap from the bottom of the scum container and let the scum out.
    2. Care must be taken that air is not allowed to enter the container at this point.
    B. Effluent
    3. Effluent is drawn off daily or so to the extent of approximately half of volume of daily input at feeding. The other half of daily input is accounted for as (1) gas and (2) contraction during fermentation.
    4. The superior fertilizing value of the effluent is discussed elsewhere. This inner tube digester will produce enough to improve growth of plants on an area of 2,152 sq. ft. per year -- a good sized vegetable patch.
    Gas will burn with a hot flame when ignited as it leaves the burner (in contact with air). But if gas and air are mixed together in proportions of 1 part in 4 to 1 in 14 and then ignited in a closed area or container, a violent explosion will ensue.
    To avoid any possibility of explosion in this sized unit, the first time the digester produces enough gas to fill the pipes, scum accumulator and storage tanks, this gas should be allowed to disperse to the atmosphere. The second time it fills up will be relatively -- almost certainly -- safe to light. The flame is so clean and blue that it will be difficult to see in sunlight but clearly visible at night.
    The second safety factor is to keep a positive (however slight) pressure of gas in the pipelines and storage, so that air is never drawn into any part of the unit. (Weights on the storage inner tubes, pressure on the main tube when emptying the scum, so the pipes won't collapse).
    The third safety factor is to check the unit daily for leaks; there will be a discoloration of the tubing in places where the gas has leaked out.
    Finally, smell is important in safety handling. Never light a match in a room with a strong smell of gas -- or even a slight smell. Air out the room first.
    A small gas flame can be lit at the open end, provided the gas flow is held low. If the flow is too strong, the flame will burn inches away from the open end and be difficult to control The adapter on the burner decreases the flow.
    18. pH
    To keep track of pH values, narrow range litmus paper with a range from 6.5 to 8.5 or 9 can be used to check effluent. In my experience of digesting animal manures, a healthy brew, working at top efficiency will have an effluent pH of around 8.5. This is in contrast to all published literature on digestion of sewage plant solids in which a working range of 7 to 7.6 is considered average. If it should drop to 7.6 or so in this unit, reduce feeding to miss the first day, then half feed until the pH of the effluent rises to 8 at least.
    Should the pH drop as low as 7 or 7.2, add a cup of ammonia (the ordinary ammonia bought in a store) to the raw slurry at the next feed in. Reduce the feed in (or loading) slightly from then on.
    When organic material decays it yields useful by-products. The kind of by-product depends on the conditions under which decay takes place. Decay can be aerobic (with oxygen) or anaerobic (without oxygen). Any kind of organic matter can be broken down either way, but the end products will be quite different (Fig. 1).
    Next: 11 Necessity is the Mother of Invention
    12 References
    Back to Table of Contents
    Back to the Biofuels Library
    Back to the Small Farms Library
    Biofuels
    Biofuels Library
    Biofuels supplies and suppliers
    Biodiesel
    Make your own biodiesel
    Mike Pelly's recipe
    Two-stage biodiesel process
    FOOLPROOF biodiesel process
    Biodiesel processors
    Biodiesel in Hong Kong
    Nitrogen Oxide emissions
    Glycerine
    Biodiesel resources on the Web
    Do diesels have a future?
    Vegetable oil yields and characteristics
    Washing
    Biodiesel and your vehicle
    Food or fuel?
    Straight vegetable oil as diesel fuel
    Ethanol
    Ethanol resources on the Web
    Is ethanol energy-efficient?
    image.
    Gafarmboy likes this.
  2. ghrit
    I've been building sewage treatment plants for longer than I care to remember. A couple notes to add to MM's very good idea.
    1) pH is very dependant on feedstock. Public facilities handle human waste as well as a mixed bag of commercial and industrial by products. MM's observation of operating pH is probably accurate considering the chicken only feedstock.
    2) To operate most gas burning appliances, pressure has to be high enough to allow regulation at a (nearly) constant pressure. Public waste plants generate (most effectively) at about 12 inches water guage, which can work for an atmospheric burner, but NOT for a vehicle, even if the gas bag were big enough to hang on your pickup. Plus, the amount of gas at that pressure would make for one big balloon in the box just to get you to the grocery store. Meaning, you might use it for some sort of heater to keep the digester warm enough to continue working efficiently.
    3) Digester gas is a mix of methane and carbon dioxide, with a few other things mixed in. It ain't methane gas you are going to smell, it is the other stuff. Methane by itself is essentially odorless. Commercial NATURAL gas has a smelly component (hydrogen sulphide) added so that it can be readily detected. Chickens or pigs will add their own detection agent.
    4) Digester gas is relatively low in heat content because of the other stuff in it. It won't burn in a commercially available natural gas burner, it takes special burners with larger holes and corroson resistant parts.
    5) It is more than possible to compress digester gas, it is often done to get the energy stored in a small(er) volume tank. However, it is a process requiring a lot of safety consciousness. "Don't try this in your basement."
    6) Digester gas is wet, that is, it has a lot of moisture in it. Saturated, in fact. The wet gas is highly corrosive in the case of public plants, mostly because of sulferous compounds in the waste stream. When it condenses, it rots most metals in short order. Which is why MM's manual calls for plastics and rubbers which are corrosion resistant. Meaning, make no substitutions to the recommended materials without considering the corrosive effects of sulphuric acid (hydrogen sulphide occurs naturally in digesters.)
    7) Do NOT let air in the system. A very real possibilitiy of BANG at the least provocation.
    8) Even if you don't use the gas for fuel, there are benefits to the digestion process. The digested solids are excellent fertilizers, once stabilized. The best home method for that is composting for a while, let the decay heat sterilize it. It is heavy in nitrogen, and that will be released very quickly to the plants. Go lightly, or you will burn your crops. I'd be cautious about using it for food crops, more than any other reason because I don't know what pathogens might survive the composting. (General rule is 165 degrees in the compost pile for a week in the case of public works for Class A use, i.e., crops for human consumption or human contact.) The sheer volume of waste will be about halved by digestion, saving space in your "storage" yard.
    More as requested. If I don't know, I'll find out and report back.
    image.
  3. monkeyman
    I dont know a whole lot about this topic, just enouph to have done a bit of research and found this. So, while I dont know how hard it would be to downscale it to be reasonable for an individual home, I know one of the farms here in MO has an arangement with the electric COOP where they get paid for all the juice they put into the grid. They put in enouph that they power (IIRC) something like 50 of the surounding farms from thier generators t5hat are powered from the methane off I think it was something like 150 cattle on thier dairy. It had cost them like 1-2 million to set it up but they also produce so much electricity that selling the excess is expected to pay for the setup in the first 10 years or some such. Some of the figures may be off as its been several months since I read the right up on it.
    I know I have also heard about one of the ranches in Texas powering an entire town in adition to the ranch that way (I think it may have been big sky ranch but dont recall for sure) and that they also powered some of the trucks, skid loaders, etc. that were used around the ranch from them.
    Short version, you would know a LOT more about it than I do, all I know for sure is that if you know enouph of what youre doing it can be used well to power generators and such and aparently (over a long period) for around the same price as buying the electric or less.
    So would a modified air compressor work for livestock waste produced methane?
  4. ghrit
    The idea is very sound, it is a matter of scale. Small is probably not economical, but I can be proven wrong. The cases you cite are pretty much larger than a home based system, but might be workable for a community of some size, most especially if there was stock waste that could be collected as feed stock. A guy that lives not too far from my ex BIL used digesters for cattle waste reduction and stabilization several years ago, but I don't know how well it worked out. I do know that it was not well controlled and stank worse than the cows in the field. He had a feed lot operation, with very little done in the actual pastures, thus collection was not a big deal. He was producing fertilizer, not fuel, had two 50,000 gal digesters in batch mode. You are right, it is a resource that is sorta tempting to not waste, and if it can be worked out, will add to the independance.
    I had not thought of adapting an air compressor. It can probably be done with a bunch of caveats. You MUST keep the heat down for fear of autoignition (dieseling) with the obvious launch of cylinder heads. This may force you to shim up the head to reduce the compression ratio. Would have to think about it a bit more other than that. The public plants have very stringent design controls for safety, and the compressors are pretty special designs as well. The highest pressure I've been connected with was 60 psi, and that was felt marginally dangerous by the experts. There were two stages of compression, and two of reduction to the engines before the fuel flow regulators. (It was also one of the more complex systems I've seen. It is on a plant that serves the Boston MA area, lots of folks contributing to the feedstock. For what it's worth, the engines could not supply the entire power requirement for the treatment plant.)
    So far as powering rolling stock goes, it is becoming common to use natural gas, which is indeed methane. and can be used either in pressurized bottles or in LNG form. However, I haven't seen anything that indicates use of digester gas directly in vehicles. Which means nothing much, really. Just haven't seen any applications in the literature. I suspect, but do not know, that the 40% or so of carbon dioxide in digester gas would have to be removed before the usual engine could use it effectively.
    There are many installations of engine generator sets that use digester gas directly, but they are in large plants that have large volumes for gas storage. The engines are run as long as there is sufficient gas in storage at pressures high enough to control the gas flow. These installations are used intermittently when the gas volume is sufficient to allow the machines to run for a significant period of time, that is to load them down at the most efficient operating point for long enough to sell power in a block. The economics are a heavy study when cogeneration is contemplated.
    To summarize a bit, digestion has it's uses, the products have value. Fertilizer and heat are the most likely useful on a small scale.
    One more thing. I'm an engineer, and often I over complicate things, so don't let me discourage [troll] you from looking further into it I do NOT know it all in spite of my ex's opinion (frequently expressed with a few other adjectives thrown in.)
  5. monkeyman
    No problem, its basicly so folks can see how to do it and go from there if interested and give food for thought. Something to show things outside the box.
  6. fosyxe1
    fosyxe1 Monkey+
    alternative heat in SHTF
    In a collapse we may have to resort to this to stay warm, I live in the midwest with a lot of cattle for the raw material , manure and straw and it would be a way to heat and cook. In the event of a grid breakdown it would be one way to cope, Thanks.
  7. oil pan 4
    I know this is old but I have seen what happened when you try to use bio gas in a piston engine.
    There is a Cummins natural gas engine building and testing facility not far from me.
    They had engines sent back after the bio gas completely ate through the pistons.
    By the time Cummins could develope good erosion resistant pistons their customers had already switched to boilers and gas turbines.
    So it's not a long term solution to running piston engines.
    I read the thread title and thought, "She's not so bad as long as I take her for a walk after she eats."
  9. Gator 45/70
    You would have to run your raw gas thru a contact tower first before it can be used for fuel gas.
    What you would be doing is removing the impurities with Glycol, This takes high pressure special pumps to circulate the Glycol
    Then the Glycol needs to be filtered before it goes thru the pumps again to be circulated.
    The gas coming out of the contact tower is now usable as fuel.
  10. oil pan 4
    I haven't actually seen anyone do that with bio gas.
    Everywhere I have seen that uses it just rubs it through special made bio gas blowers, though stainless steel lines to burn in boilers.
    No clean up needed.
    The boilers that run bio gas experience slightly accelerated tube erosion. But when you are replacing $1,000 to $2000 of natural gas with near $0 bio gas per day, a $30,000 retube job every 6 to 8 years is nothing.
  11. Gator 45/70
    The stainless steel is for the CO/2 in the gas,Even a small amount will eat holes in regular flowline or even drill pipe.
  12. oil pan 4
    There is hydrogen sulfide also.
    Where I work the schedule 40 thickness pipe in 304 stainless has been in place since 2008.
    Some day it might get eaten through, when it does the cost to replace it will be no object.
  13. Gator 45/70
    Oh Yeah, H2/S is nasty stuff, Not only on piping which at least needs to be S.Steel lined but on you if the concentration is high and containment has failed.
    I got into some of it years ago, Ended up with headaches and lost some of my sense of smell for a long time!
  14. DKR
    Pigs is big business in Utah.
    Circle 4 Farms, near Milford now has quite the setup to produce both power and quality fertilizer taking whay used to generate lawsuit into a secondary, and positive, revenue stream.
    Pig manure provides power for thousands of Utah homes | KSL.com
    Question - What do you do as a coop when you generate 40K pounds (dried) per year in 'hog waste"?
    Answer - you make money
    Merkun and Gator 45/70 like this.
  15. arleigh
    I wonder how they are doing it in third world countries with out all that science ?
  16. oil pan 4
    In s-hole countries they use plastic line and burn the gas for cooking and water heating. For power generation they burn it in boilers or the more sophisticated s-holes use gas turbine. Possibly even combined cycle gas turbine.
    Remember poverty is the mother of invention.
    arleigh likes this.
  17. arleigh
    The experiment in diesel engines was a waste of time . methane is one of the hottest gasses. in the world , even in for 4 stroke engines they need stellate valves and seats to survive.
    Race cars mixed the gas to keep it stable, methane like acetylene is very unstable, it is why you don't compress it alone. ( acetylene is mixed with acetone in carbon filled bottles ,It is why the pressure regulator on the bottle has a red line for maximum pressure in the hose or it will explode on it's own, because the acetylene with out acetone is unstable. ).
    It is why unmixed methane is stored in large vessels and inflatable bladders, it develops 5 PSI on it's own .
    People in Europe use it all the time and do not jump through all the scientific hoops,
    Yes it is a gas easy to make and like any gas it has it's dangers so does propane and natural gas and gasoline and alcohol for that matter.
    If you respect the fuel the dangers are governed then problems are averted .
    In Asia there are schools that make alcohol from garbage, for the children to take home and be able to do their studies using alcohol lights. It' not rocket science it's discipline.
    If you do not have good disciplines with working these things, stay away .
    Resign your self to be dependent on commercially processed fuels .
    Ideally one does not make gun powder in their home, but people do.
    Any thing potentially explosive/flammable needs done cautiously in it's own environment .
    In the very old days even cooking was done in it's own building or out side ,not in the house.
    So if your going to do this, do it in it's own dedicated structure away from the house/garage .
    Because it is a fumeious gas and not a liquid, your structure, if any, needs to have it's walls off the ground so the place can breathe . some gases rise some fall , know which is which ,and with this in mind you don't want to be doing this in a neighborhood as you will gain justified unwanted attention .
    Years ago I made some methane gas but lost the opportunity to experiment with it ,due to a change in moving.
    Where I live now I plan on doing the experiment over again especially being surrounded by people with horses and wine country.
  18. oil pan 4
    Nothing happened to the valves.
    Methane is stable. It can be bought in a standard 2,200 psi bottle.
    It's not an experiment. Cummins and GE manufacture engines that run off natural gas. This is how some s-hole countries generate power.
    In this area used to use natural to fuel converted gasoline pickup truck engines to pump water. The only time they would burn valves is when natural gas pressure dropped too low and the engines ran lean. Running lean under load burns valves, doesn't matter if you use, gasoline, propane or methane for fuel.
    Waukesha 275GL+ Engine | GE Power
    If you need something smaller than 5,000 horsepower there are these:
    Cummins Westport - ISX12 G - Models
    If those are too big Kohler makes small ones.
    Methane runs such low pressure into a house for safety. Natural gas has a very low coefficient of stiffness, which means a lot of gas can leak through a tiny crack or hole.
    Where I work the 1,200hp boilers have 30 psi of natural gas going to them so all natutal gas applications don't have to run at 0.4psi.
  19. Merkun
    Merkun furious dreamer
    @arleigh I think you may have confused methane and methanol. Methane is the same thing as natural gas, there is NO restriction on compression beyond the strength of the compressor and associated piping and vessels. Very stable. Methanol is also stable if it is correctly stored, sealed containers.
  20. Gator 45/70
    When I was offshore in the GOM (Gulf of Mexico) we ran Waukesha's, Ingersall Rands Cooper's,Clark's MEP's Cummings and Cat's
    on Nat. Gas
    Even had a couple of Detriot Diesels 12V71 that were duel fuel, Had Impco carbs mounted on top of the blowers.
    Merkun likes this.
