MTM Plastic Ammo Can Review
Discussion in 'Functional Gear & Equipment' started by Gator 45/70, Aug 2, 2020.
  1. Gator 45/70
    Sux's. Fin
    Can't upload pict's wth?
    mtm.
    techsar and sec_monkey like this.
  2. Gator 45/70
  3. DKR
    One of these?
    no Buenos for me. plastic shatters when cold. I live someplace really cod.
    john316, Gator 45/70 and sec_monkey like this.
  4. sec_monkey
    @Gator 45/70
    please try dis .. ..
    click here
    https://www.survivalmonkey.com/media/add
    select create an album
    give it a title [ required ]
    plus a description [ optional ]
    set it to Everyone
    set it to owner only
    Click Create album
    select Upload an image from your files
    or
    Upload an image from a URL
    [ some URLs have protection plus security measures to prevent linking or downloading and so on ]
    then follow the instructions on screen
    (y) (y)
  5. techsar
    One of these? Had one...it lasted until it was picked up, then it warped...junque du jour.
    ammunitioncan.
    oldawg, STANGF150, john316 and 2 others like this.
  6. sec_monkey
    sorry DKR that did not werk :( :(
  7. sec_monkey
    yall the palmettostatearmory pics have captcha protection direct linking will be difficult or impossible
    sorry yall :( :(
    best way is to download to yer PC, then upload to an album on the monkey [ that prevents dead links too ]
  8. Gator 45/70
    Contents became water logged,Not recommended at all !
    can 8-2-2020 005.
    can 8-2-2020 002.
    STANGF150, HK_User, Yard Dart and 5 others like this.
  9. sec_monkey
    :shock: :shock:
    HK_User and Gator 45/70 like this.
  10. HK_User
    When you live in a swamp>>>>>
    Brokor, Yard Dart, Tully Mars and 2 others like this.
  11. HK_User
    FWIW, that's why they put them on sale.
    Brokor, Gator 45/70 and sec_monkey like this.
  12. Gator 45/70
    What? I can hit water at say 2 feet?
    Glad no ammo was harmed in this experiment !
    oldawg, HK_User, Brokor and 5 others like this.
  13. Yard Dart
    In the spring I was hitting water at 18 inches doing some landscaping....... thanks for the review!!!!
  14. RouteClearance
    RouteClearance Monkey+++
    To test the water tightness of any storage container that will be buried, just fill the container with rocks, then completely submerge the container in water. For most of the cheaper stuff you will see the air bubbles escaping the container right away. If you do not witness any air bubbles, let the container sit for 24 hours. If the rocks are dry, then I would trust it to be buried.
    You can store a lot in a 4" piece of pvc pipe with a permanate end cap anda screw on cap. 4 " pvc pipe and its many type of fittings is sold in the plumbers supply of any big box home store.
    Your most important items should never be trusted in a cheap container that is by all accounts,"Made In China".
    HK_User, Brokor, Gator 45/70 and 2 others like this.
  15. Bandit99
    This is good information to know as thought about doing something like this and was consider one of these. If I do this, I will use PVC pipe. Thanks!
    HK_User, Gator 45/70 and sec_monkey like this.
  16. ghrit
    Depending on what you want to put in it, you MAY need a 6 inch or larger pipe. Your average AR15 won't fit. (Yes, someone proved it.)
  17. RouteClearance
    If the AR has a sighted and zeroed optic, you will have to use a 10” diameter pipe. If you remove the pistol grip, then you can get it in 8” diameter pipe.
    HK_User, Brokor, Yard Dart and 2 others like this.
  18. Brokor
    Yeah, I like these things. Perhaps there are several manufacturers? Mine seems rugged enough, even a rubber seal. Sure, it's not durable like the metal G.I. ammo cans, but it's great for holding spare mags and range ammo.
    Damn, dude! Well, at least it's nothing a little cleaning can't fix.
  19. Gator 45/70
    Tried the Hyd.Peroxide route,Not much improvement,Then the tumbler route w/ crushed walnut shells,
    Still not all shiny and spiffy looking but clean enough to trade in at the bank,This would be after 1963 stuff !!!
    sec_monkey and HK_User like this.
  20. HK_User
    To add to the closure end of your PVC Pipe. Turn a groove in the top edge of another 4" piece of pipe, cut to fit the inside of the main pipe, set in place with PVC cement at the correct depth to contact the screw in plug, test this for accuracy. Fill the groove with Blue sealant, add grease to the threads tighten with a homemade wrench and bury the wrench at another site. Bury the main unit, covered by a non binding top piece in a vertical post hole, cover with a little bit of dirt, add an old rotted off post end, add more dirt and grass pug.
    oldawg, sec_monkey and Gator 45/70 like this.
