New to prepping
Discussion in 'New Member Introductions' started by hillbill, Jan 23, 2015.
  1. hillbill
    hillbill tbell
    Hey just getting serious on prepareing for hard times,i have a well for water need ideas on best way toget water with out power,thanks.
  2. ghrit
    Nice to see you here, welcome aboard. You'll find quite a bit on water and wells around the site. For specific info, knowing you have a well is not enough to point you in the right direction. Have a look around, try the search feature and see what turns up.
    Yard Dart and Tully Mars like this.
  3. Yard Dart
    [welcomeLG]
  4. kellory
    CHEAP and EASY, Emergency Well Pump Requires No E…:
    Mindgrinder and Dunerunner like this.
  5. Dunerunner
    Welcome, and as you can see; plenty of help available here...
  6. kellory
    How to build a simple PVC Hand Pump - the Peters …:
    Mindgrinder likes this.
  7. hillbill
    hillbill tbell
    thanks for the info,i live in the country so lucky there.i belive things are going to collapse so I need to turn from lazy to creative,depended on Walmart to long.
  8. kellory
    The knowledge pool in the shade of the monkey tree, is both wide and deep.
    Come on in, the water's fine....;)
    Witch Doctor 01 and Tully Mars like this.
  9. Gopherman
    Welcome to the site!! Enjoy!
    Fire, Water, Beans, Rice (etc....), Med's, Defense, prioritize!
    Utilize Youtube while its available and make sure to write important stuff down for when its not!
  10. Motomom34
    How deep is your well? Different methods for different depths. My advice have your well and plan o using it but make sure you have a second source in mind- just in case. As @BTPost says, two is one.......
    So welcome to the monkey. You have come to a great place
    Tully Mars likes this.
  11. Tully Mars
    Welcome to the tree, as others have already said, much to be learned here:)
  12. KAS
    KAS Monkey+++
    Welcome ....
    I believe there was a post similar to this one a few weeks ago on here ...
    I say check out engineer775 on youtube and keep doing reasearch on the monkey... tons of VERY HELPFULL info here
  13. hillbill
    hillbill tbell
    my well is 185 ft and the water comes up 50 ft.i have thought about a 7000 w generator to run the pump we have a pond and two small streams on our property we have 60 acers half fields half woods.
  14. Witch Doctor 01
    welcome... depending on the flow rate (GPM) you need you might consider a solar water pump... with a manual pump as a back up....
  15. kckndrgn
    Welcome to the monkey!
    Lots of options already posted, here's another. Use a cistern, or other water container and set it higher than where you are using it. Your current well pump fills the cistern, and have a backup solar pump. The back up pump need not be at the same specs as the main pump, and the cistern should contain a few days worth of water.
    In the event of a power failure, the cistern can gravity feed your house (you could also have an RV type on-demand water pump for increased pressure in some cases). During the day the solar pump replenishes the cistern slowly.
    There are many ways to tackle this.
    Tully Mars and kellory like this.
  16. stg58
    Greetings
