The Woodbutcher's Homage to Scary Sharp(TM) Scary Sharp as a process is quite old; possibly even pre-WWII. I know of several woodworking friends who describe an awareness of it from their early apprentice days in the '50s or '60s and who learned it from the old guys in the shop. As a named phenomenon, Scary Sharp was born on usenet, specifically rec.woodworking and those origins are described here. I lifted this neat disclaimer from Steve K.'s nice site and his tribute to Scary Sharp (http://www2.fwi.com/~krumy/) NOTICE This is not the original "scary sharp" page. The original page is apparently no longer active. I have posted this page after having made and seen many inquiries about the link no longer working. I assume it's in the public domain. If I am in error, let me know and I'll remove it. Also, I left the background white and the typeface courier to simulate the boring look of usenet, where this originally appeared. Rod P. The D&S Scary Sharp(TM) System And related posts: The original post to Rec.Wood that started it all Another Club Toter Discovers Sandpaper sharpening chisels, using the same techniqe [sic] and for those YB's that are way too busy.. the Condensed Version The D&S Scary Sharp(TM) System [No, you can't sharpen sandpaper. And please don't ask me how I know that.] [Required warnings:] [If you don't like sharpening tales, or sandpaper, or handplanes, or any deviation from simple declarative sentences, please don't read this post. Also, it's a process gloat, and it's windbaggy, so be forewarned.] [And if you prefer one-clause synopses, here: "I sharpened a plane blade with sandpaper." Now move along now.] For anyone else: I recently emailed a few folks about some attempts I made at sharpening a plane iron with sandpaper. Some suggested I post my story to the group. So here it is. (Rich and David, I've pretty much rehashed my email to you guys here, so you can move on out now, too.) Let's see. Who's left? Oh. Dear Mom, I've recently been experimenting with using sandpaper for honing. I had been getting tired out with the oilstones getting unflat and glazed and needing to be lapped all the time, tired of oil all over the place and on my hands so I couldn't even scratch, tired of having to clean the stones after each use, tired of having to keep a conscious effort going to distribute wear on the stones evenly. So tired of all of this. So I started thinking about abrasives and abrasive action in general, and read up a bit, and asked around, and found out that there's nothing different, in principle, between sandpaper and an oilstone. Silicon carbide sandpaper (i.e., wet-or-dry) goes up to 600 grit in the hardware and woodworking stores, but up to 2000 grit in the automotive finishing stores, as I learned from David Opincarne, a local rec.woodworker and admitted metalhead who works right here at the school and who sent me some 1200-and 2000-grit samples and who's recently been helping me greatly to understand the secrets of metal. For example, did you know that to produce high-carbon steel, crushed bone from the skull of an infidel is an excellent carburizing agent? Me, neither. Or that hardening the steel in cutting blades is achieved by the sudden and even cooling of the blade, and that the best known way to achieve these dual goals is to quench the blade in the still-living body of an enemy warrior? Same here; I had no idea. David's been teaching me a lot. Me and him and some other wreck.the.woodwork folks had been talking lately about this abrasive business, and it got onto sandpaper somehow, and so I decided to test something out. For the sharpening-with-sandpaper experiment, I used a slightly-pitted 2" wide jack plane blade that came with an old beat-up Stanley Bedrock #605 I bought last year at a tool swap. The bevel on the plane iron had been somehow ground *concave* by the previous owner (or else it just wore that way), so I first straightened the edge out on the grinding wheel, grinding in straight at first so as not to create a thin edge that would burn, and then grinding in a bevel but stopping a bit short of a real edge, again to prevent burning. Because of this care not to burn the steel, this grinding goes slow and light, but it's time well spent. Time now to lap the back behind the cutting bevel. I took a page out of the plane-sole lapping book -- figuratively speaking of course, you should never tear pages out of a book -- and used very light coatings of 3M "77" spray adhesive to temporarily glue small 1-1/2" x 3-1/2" rectangular pieces of sandpaper along the edge of a sheet of 1/4" plate-glass. The paper I used was Aluminum Oxide in grits 50, 80, and 100, and Silicon Carbide (wet-or-dry to you lay people) in grits of 150, 180, 220, 320, 400, 600, 1200, and 2000. The plate glass was placed with its edge flush to the edge of the workbench. I lapped the end one inch of the back of the iron on each grit in turn. I didn't use any water; I just went at it dry. So as I lapped -- can you call it lapping if it's dry? -- anyway, about every ten seconds or so I'd stop and brush off the sandpaper with a whisk broom and wipe the blade off on my shirt. (On the coarser grits, I found that a dustbuster vacuum actually cleaned up the paper quite thoroughly, much better than sweeping it off, but this sucking advantage disappeared at around 220 grit.) Since I progressed through the grits so gradually, I found I had to spend only about a minute or so on each grit, including the suck-down and sweep-off and shirt-wipe time. One trick to efficiency is knowing when you've lapped the back sufficiently on each progressive grit. I had previously had trouble gauging this, and didn't know how to tell when enough is enough. Thanks to a clever suggestion from Jeff Gorman, I tried a trick that seemed to work wonderfully. I have a cheapie Radio Shack 30-power hand microscope -- "microscope" sounds impressive, but it's only $10, although I forget where I got it from -- and used that to tell when the striations from the new grit had replaced all the striations from the previous grit, and when they had, I stopped there and moved on to the next grit. About ten minutes after starting, I had gone from 50 grit on up to 2000, and there was a mirror finish on the back of that iron the likes of which must be seen. The back of the iron became so shiny I could count my nose hairs in it; 98 on the left, 79 on the right, but 109 and 85 if you count the white ones. I then jigged the blade in a Veritas honing jig -- which, by the way, Mr. Lee, should be called a honing fixture, not a jig, since a jig's for holding a tool and a fixture's for holding a workpiece and in the sharpening operation the plane iron, while usually thought of as a tool, or as a part of one, is actually in this instance the workpiece -- man, near-terminal digression there, almost lost it for good; Boy, snap out of it! -- I clamped the blade down in the Veritas blade-holder device, taking care to have the hollow-ground bevel resting on the glass perfectly along both edges of the hollow grind. I then adjusted the microbevel cam on the jig up to its full two-degree microbevel setting -- Robin, tell your uncle that Steve said "way to go, old dude" -- and honed away on the 2000-grit. Even though I had not ground a sharp edge on the primary bevel with the bench grinder, even on that little slip of fine 2000 grit it still took only about another couple of minutes before I had a nice sharp little 1/64" microbevel gleaming back at me. I flipped the blade over on the sandpaper several times, hone and lap, hone and lap, each time gentler and gentler, to remove the little bit of wire edge. (Which, by the way, as a result of using such a fine grit must have been so tiny that it was very hard to see or feel, so pretty much just from my awareness of the process I assumed it was there.) The resulting little thin secondary bevel was shiny. I mean *clean* shiny, like nothing I'd ever seen before. Unlike the secondary bevels I'd previously coaxed out of my hard white Arkansas stone, this one was unbelievably Shiny with a capital S. I mean *clean* shiny, like nothing I'd ever seen before. Oh, I said that already. Okay, it's hard to describe; about the best I can do is to say that it looked almost *liquid* when you catch the light on it just right. I mean, it was so darn clean and shiny that it takes ten lines just to say it was so shiny it's hard to describe. Of course, shine is not the ultimate goal. But sharpness *is*. Still, they equate. The more shiny, the more uniform the surface is microscopically, and the closer to the geometric ideal of a *line* is the edge, and hence the sharper it is. Cool. I mean *COOL*!!! I was trembling in my Mickey Mouse boots in anticipation. Hell, this cutting edge looked downright *dangerous*! I didn't dare touch it. But yet, there was still something I just *had* to try. I removed the blade from the jig, and anxiously tried the old cliché "cut a finger off before you can notice and bleed all over your screaming wife in the car on the way to the hospital" test. Oops; no, wait. Sorry, that's the wrong test, for those other kinds of tools. Sorry. For the Neanderthals, it's the "shave some arm hairs off" test. Now I've done this test before, on other blades sharpened up on white Arkansas, and while these other blades would pop *some* hairs off the back of my wrist, many other hairs would just bend on over down under the blade's edge (probably from the sheer weight of four prepositions in a row), and those hairs that *did* pop off would do so quite painfully, as though the blade was more grabbing the hairs and *ripping* them out, and I could feel every one of them offering their stubborn and vengeful resistance. Not much fun, and nothing to be doing voluntarily in front of others. But the edge on this blade was something else! Not only did it cut off every little hair in its path with total ease, but it didn't hurt at all. In fact, I couldn't feel a thing; for all I could tell, there were no hairs there in its path to begin with. But of course there were many, since I'm Italian and also since I could see the fallen hairs all over the back of the blade. And my arm where I had shaved it was a smooth as a non-Italian baby's butt. Again, man, this had gotten downright *frightening*. But of course, the ultimate test of a plane iron's sharpness is what it does on wood. So I put the blade back into the plane, that old early-model Bedrock jack, which I've not yet tuned in any way. I tried it on the edge of a piece of pine, and as I adjusted the blade for the finest cut possible, it glided through the wood with no effort. None whatsoever. In fact, it almost seemed like the plane was pulling itself along, or that the wood was *wanting* to be planed and was throwing itself into the blade -- no, I've not read Krenov -- it took that little effort. I ended up getting a shaving that was so darn thin I could read newsprint through it easily. Unbelievably easily. So easily, in fact, that I thought for a moment about taking the iron back on out of the plane and putting the shaving over the shiny part of its back and counting my nose hairs again, but by this time I had grown weary of counting nose hairs, and of my concerned wife repeatedly asking me why I was doing that. I thought, no way, this can't be! So skeptic that I am -- I'm so skeptical, that I can't be fully sure that I'm really that much of a skeptic -- I put a micrometer to the shaving, and get this: it measured .0004 thick! Four ten-thousandths of an inch! (Or, as my eternally-pestered but forever-patient metalmentor David Opincarne showed me, "four-tenths" in machinist talk.) No, I read the mike right. Less than one half way to the very first line after zero. Man! That's a cubic hair less than one-half of a thousandth of an inch! Incredible! Amazing! And it just gets better. For a while there, I actually thought I had taken off another shaving that was even thinner, one so thin in fact that it was invisible and of no measurable mass. I'm pretty sure I did, actually, but I'm having a hard time trying to think of a way to check this out, or even to find the spot on the ceiling that it floated up to. And what about the planed wood itself? Well, the surface the plane iron left on the wood in indescribable! It's like glass! No, it's like glass wet down with water and a tad of liquid soap added and then some Slick-50 and then frozen and polished. And this is on pine, a softwood! Not only that, but I then gave it the torture test: end grain. I put the same piece of wood in my shooting board, and had a go at the endgrain. Man oh man, I've never seen such a smooth surface on *endgrain* in my life. And again, this is on *pine*! The endgrain was almost as smooth as the edgegrain! This has gotten good! Still, having exclaimed all this, I'm making no claims to the throne of King of the Neanderthals. I'm the first to admit that this was kind of like when I was a kid and one year I batted a thousand in the Kiwanis Grasshoppers when I was really four years too young to actually play in the league but it was the last game of the year and Dad the team manager put me up in a losing game as the last batter just for the novelty of it and to stop my pestering -- he figured I'd get beaned and would shut up for a while -- and the opposing pitcher Terry Crowley the hotshot star started laughing at me because I was so scrawny and tiny and he taunted me who's this, Mickey Mantle or something, and he threw a pitch at my crutch and I just shut my eyes and said a curse and swung and slammed a hard grounder right down the line and under the legs of the first baseman 20 some odd years before Bill Buckner got his chance and I got a hit. I know it was kind of like that, because this shaving wasn't the minimum three feet long as per the Rules for the Contest to Become the King of the Neanderthals, so it shouldn't qualify. But it still feels just as nice. One more good thing is that in the process of taking this plane iron from misshapen funkiness to terrifying sharpness I used up all of about 25 cents worth of sandpaper, and probably about 3 cents worth of spray glue, and about fifteen or so minutes of my time, twenty if you stop for a nosehair count. When it was all done, I peeled the sandpaper from the glass and threw it away -- well, actually I could have but in truth I stick them together back-to- back and save them in a "used-sandpaper" box for odd tasks that never come up. I then scraped the little bit of residual adhesive from the glass with a razor blade, a quick wipedown with acetone on a piece of paper towel, and the cleanup was done in a minute. No oil, no water, no mess, no glaze or flatness problems to worry about, and a cutting edge that is Scary-Sharp (TM). I think I'll still keep my stones, though; they can sit atop the packets of sandpaper to help keep them flat. -- Steve LaMantia [I'm talking about my oilstones.] Seattle, WA ..or, another club-toter discovers sandpaper. ***Content Summary*** Shilling, gloating, encouragement, how-to information, Neanderthal proselytizing, yard-sale-bagging, plane-iron polishing, atom-splitting sharpness gloat, planing bragging. ************************** Not too long ago, Steve LaMantia blabberd, gibberd, meandered and led us along the primrose path of obtaining a frightening edge on a plane iron with automotive-style silicon carbide sandpaper. I was interested, yet skeptical. Then, it turns out, this advice came from another, though slightly less notorious neanderbubba, David Opincarne. Curiously, both of these guys are Huskies (U Washington, not sled-pullers), but I let that pass. So, seeing as I hadn't even put an edge on my latest haul of, you guessed it, hand planes, I figgered I'd give it a try. I already had a small collection of, gack, abrasives, left over from my brief career as a car painter. I had 240 through 600 grit wet/dry paper. The iron from the type 17 bonerific-mint-#3-that-I-got-from-Patrick-Leach-who-sells-tools-out- of-his-cave-in-Ashby-Massachusetts was a little chewed, more likely from the plane being moved from place to place. This baby looked like it had never been used. It even still had some "flakes" of cast iron on the trailing edge of the heel, which I filed off in half a stroke from a mill file. For those of you who have never "tasted" a type 10, may I say they are tres cool. The castings are heavier than the preceding or succeeding Baileys. I know not why. It's nice, 'cuz you get nearly the heft of a Bed Rock, at a much lower price. Also, the cap is not plated, but almost a gun-metal color. Even though it's "just a #3", it gives it a clean, formidable look. I tried a test-run of polishing, up to 600 grit. Not impressed. Need finer sandpaper. I scored some, while ostensibly having lunch with Sir William the Duquette (who, sadly has no newsfeed, due to technical difficulties). I came home with 1000, 1200, 1500, and 2000 grit 3M sandpaper. Ok, the sandpapering. First, polish the back... sort of. I've never been a fan of polishing the entire back of an iron, for a couple of reasons. I'm lazy, and it doesn't improve the performance of the plane. Why? For a #3, you're almost always using it for fine work, which means the chip breaker is only 1/64, to 3/32 back from the cutting edge of the iron. Seeing as the thickness of the chip breaker is little more than 1/16", you're never actually *using* anymore than 3/16" of the iron for any one planing session, so therefore, polishing any further back than, say, 1/4" is silly. That said... I pulled out the yuppy bastard's version of a lapping plate: a piece of red marble tile, glommed from a friend's yard sale, where I was invited to come down and haul away all I could... for free!! I bagged 150 12"x12"x3/8" marble tiles, most of them perfect, all of them beautiful. Hmmm a marbled shop floor? Naw. Also, bagged some unfinished cabinet doors my pal's pop-in-law had previously bagged from a failed cabinet shop (a dozen in all), along with a few sheets of pegboard. <gloat gloat> Oh, and he said I could "borrow" the 50's vintage Craftsman 8" TS, if I would clean it up. :^). But I digress... I use the red marble tile as my lapping plate for no other reason than it's about the most decadent thing I can think of to use. Also, since the bottom's rough, it tends not to slide around when I really "lean" on it. Though it's certainly not as perfectly flat as optical glass, it's righteously heavy, and did I mention it was FREE!? Am I shameless, or what... but hey, they votes are in, and you people *want* to read this, don't you? Heh heh. (Begin stream-of-consciousness mode, O'Deen talking to himself) Ok, start with 240 grit, rub vigorously, find high spots by noticing where the milling marks aren't being ground off. Vacuum dust from rubbing of iron on silcon carbide paper, wipe blade on dish towel (don't cut yourself). Damn, should have gotten some 180 grit. This 240 grit is too wimpy. Rub rub rub, grind, do the hula, don't cut yourself. Ok, now work the bevel a little bit. Don't need no honing jig, mostly cuz it's in the garage, and I'm here, pretending to be interested in the roses my wife is suggesting, even though I know she's going to buy whatever she wants to (impeccable taste, has she... I hate people like that ). Ok grab 320 through 2000 grit, and polish and rub and rub and polish. Gee this thing's looking shiny. Geepers, I can see nose hairs in my reflection. Ah! Got one. God, middle age is approaching.. hairs from everywhere. Ok, whip out the wooden strop, scribble some "green crayon", stroke, stroke... stroke. Ooooh, Aaaah. (End stream-of-consciousness) The damn edge looks like an advertisement for the Wilksinson Sword razor blade. It's practically white. I do the typical bonehead sharpness test, and try shaving my hairy knuckles. Instead of the hairs being shaved off, as I scrape along the skin, they topple over, as I glide the blade a few thousandths from my thumb. Sheesh. I pull a hair from my disappering crop on top, and precede to SPLIT it!! Holy Jaysus-jumped-up-cripes-on-a- popsicle-stick, this isn't a plane iron, it's a fissionizer. I spin around, inadvertantly splitting some nitrogen atoms, and the house explodes. When the dust settles, i'm left with the #3 (I told you those castings are heavy), and a chunk of cherry. Lacking a workbench (it was destroyed in the firestorm), I faced up the little chunk, holding the piece to the table with the stump of my hand (Ok, ok, I'm getting too silly). Anyway, I did your typical smoothing action to this little piece of wood, and put a surface on it that literally shines. It looks like a piece of marble. People, if you've never seen the surface that a well-tuned smoothing plane gives to figured woods like cherry, oak, walnut and so on, please, try it. Just once. Forget the fact that you make pleasant little curlies, if you have to. Plane it, 'cuz if you do, there's no going back. Conclusion: Abrasives play a major part in neadermania. They let plane-crazy folks like myself put an unimaginable edge on their tools, which puts an indescribable surface on wood. O'Deen Just say And you thought I was leaving for another group? From: Steve Mashl <mashl@ameslab.gov> Newsgroups: rec.woodworking Subject: Re: sharpening chisels Date: 15 Dec 1995 23:02:15 GMT RayTSmith@Aol.com (RayTSmith@Aol.com) wrote: I use silicon carbide paper stuck to 1/4" plate glass which, in turn, rests on a heavy, flat work surface during sharpening. If I am doing a full sharpening I use 240, 320, 400, 600, to form the bevel and then 600, 1000, 1200, and 2000 grit papers with a final polish on emery paper for the microbevel. The chisel is held in a Veritas jig. To attach the papers to the glass I use 3M type 77 adhesive spray. A quick, light cote of this on the paper back makes it behave like a post-it note. Stick it down, peel it off when it is shot. If I am just doing a touch up I just use 600 grit and finer. I like this system because you never have to worry about flattening stones and it works good. Hair shaving sharp. The finer papers are hard to find but Klingspoor carries them. Steve Mashl mashl@ameslab.gov Condensed Version or How to sharpen a plane blade with sandpaper. Mercilessly butchered into a Condensed "How to" Version by J. Gunterman from the Original by the Steve Lamantia. To lap the back behind the cutting bevel: Use a very light coatings of 3M "77" spray adhesive to temporarily glue small 1-1/2" x 3-1/2" rectangular pieces of sandpaper along the edge of a sheet of 1/4" plate-glass. The paper to use is Aluminum Oxide in grits 50, 80, and 100, and Silicon Carbide (wet-or-dry to you lay people) in grits of 150, 180, 220, 320, 400, 600, 1200, and 2000. The plate glass should be placed with its edge flush to the edge of the workbench. Grits can be skipped, if desired, but more time on each grit will then be required to fully remove the scratches from the previous grit. Using the gradual progression as listed, however, will require only about a minute or so with each grit." Lap the end one inch of the back of the iron on each grit in turn. You could use it wet or dry. About every ten seconds or so, stop and brush off the sandpaper with a whisk broom and wipe the blade off on your shirt. About ten minutes after starting, you should have gone from 50 grit on up to 2000, and there will be a mirror finish on the back of that iron the likes of which must be seen. Then jig the blade in a Veritas honing jig or go it by hand-- Clamp the blade down in the Veritas blade-holder device, taking care to have the bevel resting on the glass perfectly along both edges. Adjust the microbevel cam on the jig up to its full two-degree microbevel setting -- and hone away on the 2000-grit Flip the blade over on the sandpaper several times, hone and lap, hone and lap, each time gentler and gentler, to remove the little bit of wire edge The resulting little thin secondary bevel should be quite shiny by this time. Remove the blade from the jig, and perform the "shave some arm hairs off" test, or the sharpness test of your own choice. Of course, the ultimate test of a plane iron's sharpness is what it does on wood. When it is all done, peel the sandpaper from the glass and throw it away. Then, scrape the little bit of residual adhesive from the glass with a razor blade, a quick wipedown with acetone on a piece of paper towel, and the cleanup is done in a minute. No oil, no water, no mess, no glaze or flatness problems to worry about, and a cutting edge that is Scary-Sharp (TM). Main Page by Rod Peterson; © 2019 All Rights Reserved Last updated: 27 January 2009
ANOTHER site you should copy Sharpening Plane Irons more than you would ever want to know about SHARP?
Interesting. Esp given that I just got my primary cooking knives, (and others), back from the ancient gnome down by the river that does all the local eateries' cutlery on a monthly basis. He uses this home-brew horizontal wheel thing that uses 16" diameter adhesive grit disks for his initial passes, and a vertical belt grinder for grits up to 6000. All followed up with a few swipes on an ancient leather strop. His work is the exact definition of "scary sharp". He's an interesting fellow to talk with about his craft - he is able to tell the quality and hardness of various blades by observing the "quality" of the sparks produced. My old ex-.mil boning knife he describes as "a cheap stainless grade", with few, dull red sparks. My professional grade chefs, boning, and paring blades, ~ $200 ea. retail, he judges to be "good" with relatively few, but "bright" sparks. My daily pocket folder, a Kershaw, is also "good". The old M8 bayonet I brought him, because I was getting nowhere using whetstones, he calls excellent with copious bright, white hot sparks. All of the blades he worked are beyond razor sharp - as the posting mentions - counting nose hairs is entirely possible. I'm thinking of relegating my sandstones to paperweight status, and working up a similar rig to what he uses. Although, at $7.00 per blade to let him do it, it may not be worth my time.
Good one. I am often convinced that the death of the hand plane for most people is that they do not know how to use them or tune them. A good sharp plane is a delight to use and is quicker than any power one I know of and gives a finish that power tools just can't. But if dull, wrong angle on cutting edge, not set up right, it just doesn't work. Lots of things in wood working, metal working, and in life are like that.
But if dull, wrong angle on cutting edge, not set up right, it just doesn't work. Lots of things in wood working, metal working, and in life are like that. WELL, duane, you just said a mouthful. I appreciate your posts, one and all. I really like the ones that relate to your early life. YOU are such a well of knowledge, much productive time can be spent reading your old posts. I am truly a fan! You make such a difference at the monkey. I boy did i mess up...................another 14 blogs to read....thanks, sec
