Trace inverter System 8000 Watts @24Vdc
Discussion in 'Buy Sell Trade' started by Cruisin Sloth, Apr 28, 2019.
  1. Cruisin Sloth
    Here is the Creators unit , reworked after extraction .
    I replaced with a outback radion system that he designed .
    Then im now getting ready to install a B17 system and remove the Outback .
    So this is for sale . Makes 8000 watts 125/250Vac single phase split leg .
    So if wired correctly , You could run one as Master for 125Vac (110-125Vac adjust , as needed , but higher Vac is less amps on starts )
    make slave (second inverter , only come alive on 220- 250 Vac draw . the slave will search for draw and use 35-40 watts/24 hrs in search mode for 24 volts DC system , 20-26 watts for 48Vdc system. Different coils .
    I was brought up to speed last week from the Gents ..
    On a pallet sealed ready to ship.
    Sloth
    Trace Engineering (Xantrex) SW4024 4000W Inverter & Battery Charger, Unused NIOB | eBay
    Make a decent offer .
    It's in Canada now .
    1.
    2.
    3.
    4.
    5.
    6.
    packed up 2 ship.
    Tully Mars, techsar and Thunder5Ranch like this.
  2. BTPost
    I would be interested, if I hadn’t just scored a Trace SW5548, that is sitting out on the front porch...
  3. techsar
    Nice! Very similar to the unit I picked up a couple of years back and has been running perfectly since installation.
    Someone is going to get a heck of a deal!!! (y) :5s:
  4. Thunder5Ranch
    Thunder5Ranch Monkey+++
    One Week Earlier and I would have been all over this :( My Outback radian units are scheduled for delivery in the morning :( Still would be but only so many coins in the piggy bank atm :)
  5. Cruisin Sloth
    BT you have set at 48Vdc , so this is NOT for you to add on , BUT to make a different system voltage ..
    The higher voltage is the best harvest !!!
    Sloth
  6. BTPost
    No Sloth, this is going to the NEW Place which does not have a System yet... I also have a SW4048 that I have keeped around as a backup, for my SW4024 System here at the Old Place... I think I will put both the SW5548 & the SW4048 into the New Place, both running off the same Battery Bank, and the SW4048 setup in a Hot Standby configuration...
  7. Cruisin Sloth
    That will work out very well . No limits on 220 stuff.
    Sloth
  8. BTPost
    At the New Place we do NOT have any 240Vac Loads, so that really isn't an issue, up there... Down here, I do have 240Vac Loads, so I generate my Power at 240Vac and have a 10Kw Transformer that drops that down to 120Vac for the SW4024 which feeds all the 24/7 Inverted Loads... The 240Vac Loads only need to be Powered if the Gensets are running....
