Trucks, truckers and trucking
Discussion in 'General Discussion' started by oldawg, Feb 4, 2016.
  1. oldawg
    First let me say that I'm a retired long haul driver.Forty years worth. HK has it mostly right. Budd bars and "tire billys" are routinely carried by the drivers seat. But any cop CAN bust you for having a weapon within reach if he happens to be an asshole looking for one more ticket for the day. He knows it won't stick in court but he also knows the driver will usually just pay the fine by mail or bond if it's low enough simply because of time and hassle. Gotta pay for city or county services somehow. A truckers friend better be in the side compartment or tool box.That said I personally have never been hassled for it. But yes it can be considered a weapon. Mostly state troopers or a county deputy have more important things to do than that. Now if your in urban California or New Jersey that goes out the window. Many drivers also carry firearms hid or concealed but that is a federal felony if caught. Boils down to how much your safety is worth and more importantly how big of a mouth do you have. Just my experience.
    Tully Mars, Aeason, stg58 and 2 others like this.
  2. HK_User
    Yup, I made hundreds of trips, mostly personal in nature, while building our home and just living a good life.
    I never got out of the truck to check a load with out my Boomer Pipe/Cheater Pipe, of course not as a weapon but "just" to check the load!
    Smart Cops know how dangerous the road can be and I was never hassled by a Cop or a Lookie Lou who may have been sizing me up for his next hit.
    The Boomer is actually the tool used to secure the load and can be killer if not used right.
    Two basic types are used and this with chains since they were around long before the nylon straps.
    This is a Ratchet Boomer/Binder and is OK but has a lot of parts to freeze in place and not one I use.
    This is a Lever Boomer/Binder and is the one most often used with chains.
    There is a third type , Cam-Action reduces whip-back for safer operation.
    [​IMG] EZ-OVER LEVER BINDER
    used that I like to use for my Tractor Hauling because it has a two part lever and as you go past the fulcrum point it allows the boomer to continue into its lock position without taking your arm or the Boomer Pipe with it. good for tight places with pinch points such as inside trailers etc.
    If you ever use the lever type and have a heavy strain, then you will hear a loud Boom as it cycles into the lock position and the Handle hits the load of pipe. So you can die or get hurt pretty bad if you make mistakes.
    Boomer Binder aka Man Killer for the novice.
    From Chain Binders - Ratchet and Lever Load Binders
    "Ratchet Binder
    Utilizes a ratcheting mechanism to tension the chain and secure the load. It features a ratcheting handle and a tension hook on each end. Ratchet load binder styles are generally considered to a more safe option compared to a lever binder. The ratcheting mechanism means the handle does not store energy, which reduces the risk of the handle recoiling and snapping back towards the operator.
    Lever Binder
    Also called a snap binder, it uses leverage to tighten chain and secure the load. It also features a hook on each end. While lever binders are generally easier to use than a ratcheting binder because they have a more simple design and tighten more quickly, the lever stores energy which increases the chance of the lever releasing and snapping back on the operator. Users will often use a “cheater bar” to gain leverage on lever, which can also be dangerous."
    Tully Mars, Aeason and oldawg like this.
  3. oldawg
    Been retired for nine years and still have a "headache" rack setting in the yard.Turned the side boxes into shop storage.
    Tully Mars, Aeason and HK_User like this.
  4. HK_User
    Still have my old flat bed short haul 454 gas eater setting under a tree. Made the bed and headache rack myself since most commercial models were just too flimsy 40 years ago.
  5. oldawg
    Just think, gas keeps going down that "ol big block could be profitable again. [winkthumb]
    Tully Mars likes this.
  6. HK_User
    Been thinking about that, problem is it has the QuadraJunk and having rebuilt it once I think I'd just as well go with a new Edlebrock.
    I last had it rigged with Gin Poles and used it to build the shop. It's set since around '96.
  7. oldawg
    Go with the Edlebrock and order a jet kit with it. You'll use that quadrajet for target practice and pay for the ammo in fuel savings.
  8. HK_User
    No doubt!
  9. HK_User
    Gas is not so bad since I put the Gear Vendors Overdrive behind the T400.
    Made a good 6 speed transmission out of it and a good Trailer Hauler to boot.
    Did that back in"90[​IMG]
    RACING AND TOWING PERFORMANCE
    OVERDRIVE ECONOMY
    The Absolute Highest Horsepower Handling Overdrive you can buy!
    Gear-Splitting Performance and Overdrive Economy.
    For RV's, Trucks, Muscle Cars, Hot Rods, and Racing.
    The Finest Quality Auxiliary Transmissions.
    The Ultimate in Horsepower Handling and Performance.
    Get Expert advice about your vehicle. Call us at 800-999-9555
    GEAR VENDORS provides overdrive product to racing cars and trucks up to 2000hp and trucks towing heavy RV's up to 25,000lbs gcvw. Whether you are trying to move a couple tons up a steep incline or moving just a couple thousand down the track — the fastest way is with the right gearing. Add the benefits of a final overdrive ratio to reduce engine rpm and increase fuel mileage by typically 20-28% and you have a product that is the single biggest innovation you can bolt to your car or truck. With fuel costs high the overdrive can pay for itself in mileage and engine wear reductions. That makes the driving pleasure of overdrive, and performance improvements free — and then the vehicle is also worth more when/if you ever sell it with the GEAR VENDORS. In the long run it just doesn't cost you anything to own a GEAR VENDORS UNDER/OVERDRIVE™. For an in-depth discussion on which vehicles can expect these mileage gains see our "common questions" section on the web site.
    Torque (times) RPM (divided by 5252) = Horsepower (this can be expressed) Tq X RPM / 5252 = HP. GEAR VENDORS is one of few products that can work both sides of this equation for real performance gains as well as consistent fuel consumption reductions. Gears are multipliers of torque and our Ratio Splitting capability allows you to shift to a gear with more mechanical advantage than the next stock gear in automatic transmissions and wide ratio manuals. This also means engine rpm drops about half what it did without the GEAR VENDORS and so rpm is sustained - higher torque and rpm on shift = more HP. And then shift to an overdrive final and reduce both rpm and torque to reduce the manufacture of HP when steady cruising to improve fuel mileage and decrease wear on the engine and engine driven accessories.
    2 world records in Drag Racing, 4 Off Road Racing Titles, and several Land Speed records all benefit from GEAR VENDORS ratio splitting performance. At the same time this ratio splitting makes less work for the main transmission in the vehicle to then advance to the next gear (less ratio change) and thus the main transmission itself becomes more reliable. This is a great benefit at the track or on the highway. Whether your interest is motorsport or recreation — you cannot buy a more proven product.
    True OEM Quality
    OEM means that new vehicles have come factory equipped with GEAR VENDORS as original equipment. When GEAR VENDORS first started producing the DeNormanville planetary overdrive in 1979 there were no American vehicles with overdrive. Only the import cars with manual transmissions had an overdrive gear. Through the years we have worked with Ford, GM, and Chrysler and our products have come factory on everything from one of Americas fastest production cars (GM's TwinTurbo Callaway Corvette) to Americas largest RV manufacturer (Fleetwood Motorhomes). In 1981 we won our first Best Engineered award from SEMA (the largest automotive aftermarket organization). GEAR VENDORS is without question the most awarded and recognized aftermarket transmission product.
    Driving Green for the Earth
    GEAR VENDORS has been manufacturing overdrives for 27 years. We have been reducing fuel emissions on the most powerful and fuel consuming gas and diesel vehicles for nearly 3 decades before Green House gas emissions became the buzzword they are today. GEAR VENDORS equipped vehicles are responsible for reducing emissions nearly 25% in the average application compared to the non-equipped stock counterpart. With nearly 75,000 units in service we are reducing tons of emissions per day. Whether your purchase of our product is for a brand new diesel truck or a 1960's muscle car it is nice to know this performance product can substantially benefit the planet and our countries oil dependency.
    Performance Electronics
    Related to fuel economy, performance, and emissions — GEAR VENDORS overdrive kits include electronics that keep the vehicle in the optimum performing gear. Whether you are driving a older non-computer controlled vehicle or a late model with all the latest emissions computers our electronics provide the interface to ensure maximum performance and correct rpm without lugging or overreving in the wrong gear. The OE factory programming remains intact and our processor just makes it aware of the actual ratio 1,000 of times per second. In older vacuum or throttle linkage transmissions the stock governor on the output shaft instantly slows down the moment the overdrive shifts and so automatically moves the shift point in any overdrive gear up by the correct 28.6%. So both electronic and non-electronic automatic transmissions gain a group of features including a passing gear or climbing gear that is automatically available without driver intervention and is at the split between 2nd and 3rd where you really want it. Electronic options also exist for racing and performance use such a paddle-shifters with our programming already installed by companies like MasterShift, and our AutoShift Sequencer that can work with stock and aftermarket shifters just like many of the race teams use. Our standard AutoDrive electronic however do include several great features for a combination of street/strip use including AutoLaunch for both manuals and automatics.
    Customer Service Guarantee
    GEAR VENDORS makes the highest quality, most expensive overdrive you can buy. We back that with customer service and warranties you do not commonly find in business today. Call us at the factory and you will talk to real enthusiasts that know drivetrains. Our factory people will ask you the details of your vehicle and its use and then recommend our product only if it is going to be exactly what you expected and give you great benefits in your application (which is exactly why we can give a money back guarantee). These factory reps can give you the details of installation and use and send you photos, diagrams, and brochures for free. If you are installing yourself we will ship product direct to you with full factory support. If you would like to have one of GEAR VENDORS 500 nationwide dealers install the product - we will make sure to communicate with the local dealer and get your exact product in his hands for the install day. All or products come with a money back guarantee and a 2 year unlimited mileage warranty (except diesel manual truck and commercial applications see warranty for details). Last but not least — we do not show pictures of racing and then deny your warranty if you race (hard to believe so many companies do just that). All GEAR VENDORS warranties cover you on the street and at the track (though we do require a contingency decal for pro users). Call us at 800-999-9555 and ask for "new product customer service" - get the kind of service you thought was left back in the 60's.
    duane and Tully Mars like this.
  10. Tully Mars
    When I was just a kid working as a welder's helper part of the job was to deliver to our job sites. Had a cheater pipe slip through my hands and go flying off the end of a boomer. Flew across the site and just missed a guy walking by. Scared the $#!% outta me and I've never forgotten that day.
    HK_User, duane and oldawg like this.
  11. HK_User
    While loading or unloading I made sure the helpers/my kids stayed far away!
