Tweaks and Tricks That Could Save Your Life
Discussion in 'General Survival and Preparedness' started by Dunerunner, Jan 25, 2015.
  1. Dunerunner
    A few of mine and some from the web...
    1. When camping or just in a SHTF situation where there is no electricity, a standard headlamp strapped to a 1 gallon plastic milk jug filled with water can light an entire room or tent.
    2. You can use AAA batteries in electronics that call for AA batteries by filling the gaps with folded up aluminum foil. the operate time won’t be as long as with AA's but, it could get you by in a pinch.
    3. A space blanket (one with an aluminum reflective surface) can be set up on the opposite side of your campfire to reflect heat back toward you. It also serves as a wind break.
    4. A 55 gallon Black Plastic contractors trash bag makes a great emergency poncho. remember when venturing out into the wilderness to always have a water proof hat. One of the roll up hats from Outdoor Research are perfect. Outdoor Research | Hats: Warm Hats, Winter Hats, Sun Hats, Rain Hats | Outdoor Research | Designed By Adventure | Outdoor Clothing & Gear
    5. An empty Altoids tin makes a nice storage container for your dry fire starter, char cloth, flint and steel.
    Got a Tip, Trick or Tweak.... Feel free to add on.
    Aeason, Meat, Sapper John and 6 others like this.
  2. Motomom34
    Clarification on #1. Turn the headlamp so it shines through the jug correct? That is a really interesting suggestion. I will try it when it is dark out. For now-
  3. Dunerunner
    Exactimundo!! thanks MM!
    Aeason and Motomom34 like this.
  4. Motomom34
    I have a roll of these in our emergency bag. Lots of survival uses for trash bags.
    10 Survival Uses For A Trash Bag | Outdoor Life
    arleigh, Aeason, Meat and 5 others like this.
  5. KAS
    KAS Monkey+++
    if u can get your hands on "drum liners" the are even better cause they are thicker and i like them cause the fold up flat....
  6. kellory
    I use drumliners, myself, for recycling. They hold more and don't tear.they are a much thicker plastic.(1st choice)
  7. Brokor
  8. Bear
    A pin or other way of making some pinhole "Glasses" just in case you lose your contacts or glasses... not the best... but if you are a blind bat like me... these could help "See" your way out of a bad situation... just the knowledge of it could help save your life... try it while you are watching tv or at the computer... it really works...
    It's one of the reasons why I keep that pin in my SAK ;)
    Aeason, 3M-TA3, chelloveck and 3 others like this.
  9. Dunerunner
    The sewing kits they supply for you in many hotels can serve many uses besides mending your socks or re-attaching a button. Needles can be formed into fish hooks, needle and thread can stitch up a nasty wound. If you throw in a small spool light fishing line like 6# test monofilament, you would have a hand line or materials for a snare.
    Aeason, chelloveck, KAS and 3 others like this.
  10. Dunerunner
    The edge of a metal lid removed from a can of food, makes an effective cutting tool. If you used your knife to open the can, you have a nice serrated edge on the can lid.
    Aeason, chelloveck, KAS and 1 other person like this.
  11. KAS
    KAS Monkey+++
    the lid from a spam can works great for slicing up the spam>
    Aeason, 3M-TA3, chelloveck and 4 others like this.
  12. arleigh
    i cary a set of hemostats and needle fine tweezers for dealing with splinters and some sewing issues.
    Aeason, Ganado and chelloveck like this.
    My trouble has always been AAAA batteries for my little Streamlight Stylus. It's my back-up for the back-up lights, but it is tiny and tough. Batteries are always an issue, so I found an easy source. Standard 9v batteries contain six AAAA size 1.5v batteries. They lack what the battery guys call "the consumer tip" are just a little shorter than the real deal AAAA batteries, and what looks like the + bump on the end is actually the - end, but by just stretching the battery spring out a bit and loading them "upside down" they work fine. (I will post pictures this evening)
    Best part is that there should always be some nearby since they are in just about every smoke detector and alarm clock I've handled. Takes just a couple minutes to strip down a 9v to it's component parts. Eleven lumens isn't much, but it sure beats stumbling around in the dark. :)
  14. Meat
    Meat Monkey+++
    I kept a crank em up flashlight around for years. Time to re-supply. :D
    Picture of AAAA batteries sourced from a single 9v battery.
    This took all of a minute to complete with a pair of pliers, and Interestingly, the batteries worked in my new Stylus without any spring stretching. That may indicate that my older work out lights have suffered spring fatigue.
    I may whip up a separate post on this now that I have pictures.
    The only strange part of the whole operation is that the + end of the batteries inside the 9v are the flat end. The familiar bump that we look for as the + end is soldered on there during final assembly of genuine AAAA batteries.
    KIMG1161.
    arleigh and Aeason like this.
  16. Ganado
    @Meat no pic no link no proof!
    @Dunerunner great post I keep one like that in my purse for the same reason.... batteries are easy to find
    Aeason and Meat like this.
  17. Meat
    Meat Monkey+++
    Blah blah. I'll post a pic of me walking on water. Stand by.
    Aeason and Ganado like this.
  18. Yard Dart
    NO!!
    Meat and Aeason like this.
  19. Meat
    Meat Monkey+++
    It's taking awhile to sort through all of my selfies but it's in there somewhere. [afro]
  1. survival junkie
  2. Preppersymbols
  3. chelloveck
  4. selvagem
  5. OlDiceGames
  6. Coyote Ridge
  7. Dunerunner
  8. Coyote Ridge
  9. Prepsteader13
  10. Dunerunner
  11. guest_52335_30603
    Thread
    _
    _
  12. Dunerunner
  13. Thunder5Ranch
  14. Dunerunner
  15. 3M-TA3
  16. Coyote Ridge
  17. Coyote Ridge
  18. Coyote Ridge
  20. Dunerunner
