Wag the dog
Discussion in 'Freedom and Liberty' started by VisuTrac, Apr 12, 2011.
  1. VisuTrac
    Falcon15 likes this.
  2. Brokor
    And when everything reaches critical mass, the elites and their favored retreat to their DUMB's while the rest of the world self destructs. How do the remaining people fight a supremely technologically advanced, defended and well stocked enemy that can reside in cities 4 miles beneath the surface?
    But it's never too late to hold these PIGS accountable for their crimes:
    http://www.infowars.com/iceland-rejects-bankster-shakedown/
  3. VisuTrac
    Cities 4 miles underground you say? How about a siphon hose and the Great Lakes or the ocean. Use that method all the time with ground squirrels.
    Falcon15 and Brokor like this.
  4. Seawolf1090
    Gasoline and a match work well with fireants down South....... [own2]
  5. BTPost
    Yep, They got to BREATH. That far down, they also have to pump out the collecting water, or drown. Also they will need a way to dump HEAT, to keep from roasting themselves, and they can't use the earth as that is where the heat is coming from.... Not a really practical place to build a redoubt, in the long term. Flood the Air inputs, Plug the Heat Exhaust Ports, and Plug the Pump Outputs, and they will scurry out of their holes, like the Rats they are..... .....
  6. TnAndy
    4 miles down ? What's the earth temp at that level....150 degrees or more ? Be spending a ton on AC.
  7. Brokor
    It depends on where they drill. The geothermal gradient is lesser in thicker crust zones, but in average areas the temperature can rise about 30 degrees per kilometer past a certain depth. I imagine a lot of time and effort went in to the DUMB's in order to accommodate temperature changes. And the Earth's crust is anywhere from 20 to 30 miles or more in depth.
    http://youtu.be/f4rk1-aQ6MY
    http://youtu.be/eJlrA6jfbbk
    http://youtu.be/AgtADCzW-Jc
    Seed Vault:
    http://youtu.be/lXW_vzQppGI
    http://youtu.be/vUlToC4lxX8
    The bases aren't for us:
    http://youtu.be/-S2J3i34XW8
    With approximately 140 in America and about 1,500 DUMB's worldwide, we can easily see where the black budget money is going.
  8. Tikka
    Tikka Monkey+++
    One summer when I was a teenager, I worked for the local lumber mill. One day one of the owners and I delivered a load of lumber to what is known as Site R. I thought it was odd that one of the owners wanted to drive the truck and unload it; however as he said he'd never forget it and neither have I.
    To build it they tunneled under a mountain and the doors are thick. It would take a very serious effort to break in.
  9. BTPost
    Take out the Antennas, Flood the Air Input holes, Bury the Entrance Tunnel, and let those inside Rot...... Not a big issue....
  10. Brokor
    Yeah, looking at Google Earth, the two main entrances were there in 1988, too. The whole mountain is fenced off, with the peak at around 1500 ft. elevation, and the entrances near the base at about 800 ft. It is definitely secured.
  11. Seawolf1090
    What can be secured from the inside can be secured from the outside - the 'shelter' becomes a 'prison'. Keep the rats inside to feed on each other......
    They likely do not realise if the S truly hits the fan, their 'security guards' will vanish, leaving them defenseless........
  12. Tikka
    Tikka Monkey+++
    It was in the early 1960s. If you are curious, an image search at Google for Raven Rock Mountain Complex.
    The site has been declassified and they give tours of it. Raven Rock Mountain Complex Site R Tour
    :D
    Edit
    It was a secret for years; yet, all the locals knew. When I grew up America was a different place.
