Making a micro water distiller
Discussion in 'General Survival and Preparedness' started by chelloveck, Dec 30, 2014.
  1. chelloveck
    chelloveck **BANNED**
    This is a clever design...you probably only need to watch the first five minutes of the video clip. The remainder of the clip explains the effectiveness of the system, finishing up with some hints and tips for best performance.
    You may possibly make a solar distiller by painting the dirty water container with stove black and containing the dirty water reservoir inside an improvised pet bottle container....though the production of distillate would most probably be much slower.
    Hanzo, 3M-TA3, tulianr and 5 others like this.
  2. Mindgrinder
    PERFECT addition to a biolite.
    They should actually have this sorta thing as an accessory, especially for the base camp stove they're marketing to Africa.
  3. Dunerunner
    Saw one on youtube that used a soda can filled with water and a 2 liter plastic water bottle to make a solar "rube" distiller.
    Found it...
    arleigh, Hanzo, Brokor and 4 others like this.
  4. chelloveck
    Nice videoclip...PET bottles and soda cans are common enough detritus even in the most isolated of places. A good way of converting Guinness stout into urine, and then the urine into drinking water....makes for an entertaining BBQ trick.
    Hanzo, Ganado, kellory and 1 other person like this.
  5. DarkLight
    @chelloveck , I love you like a brother but please, remind me to NEVER come over for a BBQ at your place. ;)
  6. UncleMorgan
    Any purely solar water distiller needs a fairly large "footprint" to soak up enough heat to evaporate a reasonable amount of water per day. The WaterCone is almost a meter in diameter and makes1.5 liters/day, at the absolute most.
    A 4" X 12" water bottle might get as much as 1/3 sq ft of sunlight, or 0.031 sq, meters. So the max output would only be about 0.046 liters per day. That's 1.55 oz/day. Survival-wise, solar distillation just won't cut it with a bottle that small. But with a fire, 1 cup of water in 40 minutes will definitely keep you alive.
    chelloveck, madmax and tulianr like this.
  7. chelloveck
    You are undoubtedly right...however, it may be a matter of doing the best with what you have.
    UncleMorgan and tulianr like this.
  8. kellory
    they are lightweight and stackable. and if affordable enough , you could have a hundred of them working at the same time.
    tulianr likes this.
  9. -06
    -06 Monkey+++
    There is a commercially available "emergency distiller" that doubles as cookware. Uses two pots and works well. Then there is the old Boy Scout plastic sheathing, stone, and straw method.
    Homer Simpson likes this.
  10. nkawtg
    nkawtg Monkey+++
    I like that still design chelloveck. So many home made distillers let in contaminants in to the final product.
    This one is simple and compact.
  11. Ganado
    I see that water cone video posted in alot of places.... But I've never seen a site that actually sells one. Any of you ever find a link?
    I like cell's better as it's portable... Still not sure how you get the condensation in the coil on a hot day. Does a cool rag alone really work?
    I wonder if it could be adapted for essential oil distillation?
  12. chelloveck
    Thank you nkawtg. Although the still will produce water clear of most contaminants...it may not prevent some contaminants, particularly synthetic chemicals from being condensed with the water. I am not so sure on its ability to remove radiation contaminated water in the event of fallout. Filtering the water to be distilled would be highly desirable.
    (1) the wet rag alone will create a temperature differential between the condenser coil and the steam travelling through it to help form condensed water droplets, it will work more efficiently if the condenser coil rag is positioned in a breeze and out of the sunshine so that evaporation and thermal radiation will help cool the condenser coil. Eventually the heat being lost from the condenser coil will heat the rag and the efficiency of the cooling system will be lost...but all one needs to do is re-wet the rag with cooler water. It may be feasible to modify the condenser coil by improving a water jacket similar in principle to the cooling system of the British Vickers medium machinegun.
    (2) There is no reason why the system couldn't be adapted to use in distilling essential oils. You'll just have to separate the the water from the oil in the distillate. having said that...it's probably best to keep your distillation systems separate, for the different end products (drinking water vs essential oils). I doubt that sipping water that has been through a coil that has produced a batch or three of lavender oil would be a great taste sensation. :eek:
  13. Ganado
    Ofc keep them Seperate silly! I just like the compactness of your design but stuffing all the leaves in that small hole could be problematic... Then you have to get them out again =)
    *hands chell some lavender water*
  14. chelloveck
    Chop the leaves in a blender with a little water, place in a muslin, or better still, calico bag, and poke through the bottle's neck and then, once distillation is complete, pull the bag out ...sew the bag long and narrow (like a sausage) with a drawstring with a ringpull....use a hook to pull the drawstring and bag out of the bottle so you don't scald yourself. Too simple.
  15. Ganado
    I don't know if you have a devious mind or a practical one =)
    But I like it =)
    Off to buy vodka bottles
    I'm not sure about either...I do like to solve problems though.
    kellory likes this.
  17. UncleMorgan
    I quite agree. Small output X multiple units = enough water. And if the small units are cheap or free, all the better!
    I've seen WaterCones "priced" at $69,95 each, but no place that actually sells them. Not even the WaterCone home page. Odd.
  18. Hanzo
    Hanzo Monkey+++
    How long to get that mouthful of water?
    Dunerunner likes this.
  19. Dunerunner
    My guess is that you build more than one...
    Hanzo likes this.
  20. Hanzo
    Hanzo Monkey+++
    That is my guess too. As many as you possibly can. But the shot glass of water from two of them... my guess is that was pretty much an all day result. That will only be a moral victory in getting your mouth wet and will NOT sustain you. Would probably need 50 to give you one liter. Maybe. I am just guessing from watching the video.
  1. SB21
  2. Navyair
  3. Ganado
  4. Dunerunner
  5. Yard Dart
  6. Asia-Off-Grid
  8. Asia-Off-Grid
  9. Asia-Off-Grid
  10. chelloveck
  11. Dunerunner
  12. Oddcaliber
  13. Asia-Off-Grid
  14. oil pan 4
  15. Bandit99
  16. phorisc
  17. cabot
  18. CATO
  19. madmax
  20. GhettoPass
