So what did you put away this week?
Discussion in 'General Survival and Preparedness' started by melbo, Aug 9, 2006.
  1. T. Riley
    T. Riley Monkey+++
    I don't know what that is but now would be the time. I have not hooked it into my existing plumbing yet.
  2. Elessar
    Elessar Monkey+++
    Added a box of #4 12ga for home defense. I'd hate to blow hole through the wall when the temperature is 9° outside and now way to patch the mess up. Checking into a small Honda generator.
  3. HK_User
    I'll take a picture later today of mine.
    It makes life easier when you need to shut down a feed to a place for freezing temps or if you need to do a repair.
    Like you said, now is the time. Even if you are not ready for an out building, garden or a Picnic table area right now then you can still valve it off and stub it out for later use.
    I'd like to also suggest you valve both sides of your hot water heater, again come a leak or time to replace the hot water heater then you do not have to shut down the whole house.
    Same goes for out side faucets, ours are supplied from valves inside the house. Come freeze time you simply close off that line, open the outside valve and all winterizing is done.
    Valves we used are all quality Ball valves.
    HK
  4. T. Riley
    T. Riley Monkey+++
  5. HK_User
    Two other suggestions that will save you grief later.
    Run only one inch supply lines, anything smaller and you will not be as happy as you might be with your system.
    At the supply to your pressure tank install a sediment tank, size and design is your choice but you can start with a section of 6" PVC pipe for the body of the tank.. This will keep most solids that are pumped up from the well from getting to your supply tank. Have at least a 1" drain line at the bottom of the sediment tank, this to check for sediment and drain as needed.. Good Idea to add one to your output also.
    T. Riley and ghrit like this.
  6. HK_User
    When I planned on the Manifold output I had typical exits boxed in before I laid the slab.
    Wall of Pump House is concrete so I used conduit clamps and racks to mount the manifold.
    HK
  7. T. Riley
    T. Riley Monkey+++
    @HK_User thanks, these are supply lines to various fixtures/faucets of your home, correct? You can isolate each one?
    HK_User and 3M-TA3 like this.
  8. HK_User
    Correct.
    T. Riley likes this.
    Fleshed out my 308 and 5.56 reloading capabilities - Dillon trim dies for bulk/QCB loads on the progressive, and a standard Dillon 308 die for precision loads. Also extra tool heads, a decapping die w/ extra pins, 2 lbs 4064 powder, 2,000 CCI #34 primers. Settin up my new reloading area next weekend. Turning my attention back to water storage now that I have more buy in from my wife and resident MIL after the tsunami talk this week and the Alaska earthquake. Will be off my 20 lb weight restriction next weekend as well so should be able to weasel the 150 lb containers out of my truck without injury to me or them.
    Gator 45/70, T. Riley and kellory like this.
    9MM, .40, .45 cal JHP..... other than that.... just more food. :)
    Gator 45/70, T. Riley and 3M-TA3 like this.
  11. chimo
    Food, powder, primers, bullets
    Gator 45/70 and Motomom34 like this.
  12. jimLE
    jimLE Monkey+++
    im definitely behind on posting.i've stocked up on some foods and other items as well,to whats in the pic's..
    Gator 45/70 and 3M-TA3 like this.
  13. LouDog
    LouDog Monkey
    This week was pretty productive for me. Did alot of dehydrating and food storage, bought some more water purification equipment. Started my portable solar power genertator, 400 rnds of my fav SHTF ammo ( fed lake XM855 5.56) spare parts for all my arms. And finally got around to getting my technicians HAM lisence.
    kellory, Witch Doctor 01 and Elessar like this.
  14. ghrit
    Congrats on the ticket. @BTPost maintains a list of hams, and does not share it without permission. Please PM your call to him if you wish to participate.
  15. LouDog
    LouDog Monkey
    awsome will do
  16. Elessar
    Elessar Monkey+++
    LouDog, you ROCK dude! That's some serious progress in my book. Nice job on your license!
    LouDog likes this.
  17. LouDog
    LouDog Monkey
    Thanks !!! I have a very long way to go. Wish I would have started sooner , but better late than never right ? :p
  18. Witch Doctor 01
    Picked up a dozen fiberglass arrows, and took a 4 hour class on Herb-ology
    Yard Dart, Gator 45/70 and LouDog like this.
  19. Gray Wolf
    Gray Wolf Monkey+++
    Scored 4 reloading presses, 2 single stage, i progressive, and 1 shotshell loader, a scale, powder measure, funnel, and 3 die sets
    for the princely sum of $40. Spending about $70 in replacement parts to get them up and running.
  20. Gator 45/70
    10x20 Ca-Bon
    Built by the Mennonite's
    . IMAG00272.
  1. survival junkie
  2. Dunerunner
  3. Dunerunner
  4. Dunerunner
  5. Dunerunner
  6. Dunerunner
  7. Dunerunner
  8. Dunerunner
  9. Dunerunner
  10. Thunder5Ranch
  11. Dunerunner
  12. Dunerunner
  13. Dunerunner
  14. Dunerunner
  15. john316
  16. Motomom34
  17. T. Riley
  18. HK_User
  19. Motomom34
