Survivalist Weather Forecasting
Discussion in 'Blogs' started by wildernessgal, Nov 23, 2007.
  1. wildernessgal
    wildernessgal Backwoods is a callin'
    For millennia, primitive and not-so-primitive societies have depended upon close observation of nature to forecast both short and long range changes in the weather. Without the aid of modern scientific methods of reading weather patterns, it was necessary to develop a keen eye for natural “predictors” which indicated change.
    Where to turn? To nature of course! An intimate knowledge of his environment already served to feed, clothe, and medicate primitive man. So, when it came time to explain and predict the mysteries of nature, he instinctively turned to that source for an answer.
    Primitive man was not so primitive as we might think. Even though he may have had to use mythological creatures in the sky and other “uneducated” methods to explain his perceptions, he still knew that if he saw birds roosting close to the ground, rain or snow was imminent, large crops of acorns presaged a harsh winter, and the clarity of those mysterious twinkling lights in the sky at times told him that the weather was about to change.
    Today, many educated people will dismiss old time weather lore as fables simply designed by primitive man to explain mysteries of nature that he could not explain any other way. On the other hand, in a time when modern forecasters usually are accurate only about 50% of the time, most people can remember at least one weather saying their parents or grandparents swore by. Do you ever remember as a child smelling that clean, fresh air that came before a rain, or the sound of crickets and frogs greeting the arrival of new moisture? Not all weather predictions worked, but many did indeed have a basis in scientific fact. Let's take a look at some that have been around a long, long time and the reasons that some of them are right.
    The Moon
    The moon has always been a source of fascination and wonder for primitive man. It was also one of the main weather predictors found in folklore that many times does have a scientific basis. “If the new moon holds the old moon in her bosom, the weather will be fair.” This occurs due to clear, stable, and dry air proceeding a high pressure system. It is this clarity that enables you to see the dark part of the crescent moon holding the old moon. This is usually a good predictor of 24 to 48 hours of good weather. “A ring around the moon brings rain or snow.” Another similar saying is, “When the moon is in her house, rain or snow will come.” When the moon appears to have a halo or ring around it, this is due to cirrus clouds in the higher altitudes. Cirrus and cirrostratus clouds typically proceed low pressure systems bearing moisture. These clouds also contain ice crystals which refract light, giving the impression of a ring. By counting the number of stars contained within the ring, you can fairly accurately predict how long away the rain or snow will be. Each star represents approximately 24 hours, but a faint star always gets 12 hours as far as I'm concerned. I've seen this work time after time, never seeming to fail.
    “If the crescent moon is tipped on its side (horns pointing up), it's going to rain or snow.” This one is up to you. I always go by this as being a predictor of rain since the moon then appears bowl shaped and seems to be filling with water (rain). If the horns are tipped to the side, some people believe that water is going to pour out on you. Still other books will say that this changes ever so many years and you just have to keep a weather eye on it.
    “If the moon's face is red, of water she speaks.” This saying of the Zuni Indians of the Southwest is very accurate. The red color is due to the presence of dust being pushed ahead of a low pressure front bringing in moisture.
    The following chart refers to the time when the moon changes into a new phase such as a new moon, first quarter, full moon, and last quarter. Depending on when it makes this change, the weather for the next few days should follow the chart faithfully. At least this is how the theory developed over one hundred years ago went.
    The Sun
    While not used as a weather predictor as often as the moon, the sun does offer some hints to future weather changes.
    Sun Dogs : If you look up around the middle of the day and see a rainbow or white band around the sun, look for a drastic change in the weather within 12-24 hours. If the weather is clear, plan on stormy weather; if the weather is dreary, plan on fair weather to arrive. A Sun Dog is the equivalent of a halo around the moon. If the weather is foggy and you see a sun dog, expect the fog to clear shortly.
    Red Sun: A red sun at dusk or dawn indicates dry weather. Compare this with a red sky at dusk or dawn as some people tend to confuse these two.
    Red Sky
    A red sky at either dusk or dawn is one of the more spectacular and beautiful natural weather predictors. By closely observing this phenomenon, you can achieve short range accuracy as good as or better than your local weatherman. In the Bible, Jesus in Matthew 16:2-3 is quoted as saying, “When it is evening ye say, it will be fair weather: for the sky is red. And in the morning it will be foul weather today: for the sky is red and lowering” when speaking to the Pharisees. An old English weather proverb based on this passage is: “Red sky at night, sailors delight, Red sky at morning, sailors take warning”; or “Evening red and morning gray, sends the traveler on his way. Evening gray, morning red, brings the rain down on his head.”
    At dusk, a red sky indicates that dry weather is on the way. This is due to the sun shining through dust particles being pushed ahead of a high pressure system bringing in dry air. A red sky in the morning is due to the sun again shining through dust. In this case, however, the dust is being pushed on out by an approaching low pressure system bringing in moisture. Don't confuse a red sky in the morning with a red sun in the morning. If the sun itself is red and the sky is a normal color, the day will be fair.
    Rainbows
    Rainbows play an integral part in weather predictions. Halos around the moon and sun dogs are both rainbows. A rainbow is also an obvious indicator of rain as it refracts the light and breaks it down into colors. Rainbows in the morning to the west indicate approaching rain, while a rainbow at sunset indicates that the rain is leaving and fair weather is on the way.
    Atmospheric Pressure
    As the air pressure around you either rises or falls, many changes in nature occur. Most of these are very obvious changes while others are of a more subtle nature. If you find yourself out in a marsh or swamp and the air really seems to stink more than normal, expect rainy weather. This happens when the pressure drops and the methane trapped on the bottom of the swamp is released in greater quantities. In reverse, as fair weather approaches and the pressure rises, things won't smell quite so strong. Mountains and other far away objects will appear to be much closer and more sharply focused as wet weather approaches and the air pressure drops. The dust particles in the air begin to settle to the ground and the air clears, allowing you to see more details of faraway objects. As a high pressure front approaches and the air becomes “thicker,” more dust particles become suspended in air and things take on their normal somewhat hazy appearance.
    Sound also becomes sharper and more focused prior to stormy weather. Instead of traveling upward and outward into the atmosphere sound waves are bent back to the earth and their range extended. Bird calls sound sharper, and, at my house, we can hear the blowing of the train horn as it rumbles through the valley below.
    “Sharp horns on the moon threaten bad weather.” This and a bright, clear moon are good indicators that wet weather is on the way. As the air clears of dust particles ahead of a low pressure system, the moon appears to come closer and be more sharply focused due to the lack of dust.
    Remember a grandparent talking about how their corns, bunions, or joints ached right before a rain? Again, this is due to the decreasing atmospheric pressure allowing the gas in our bodies to expand.
    Birds and bats have a tendency to fly much lower to the ground right before a rain due to the “thinning” of the air. They prefer to fly where the air is the most dense and they can get greater lift with their wings. With high pressure and dry air, the atmosphere becomes more dense and they can easily fly at higher altitudes. Some references state that birds and bats fly lower to the ground to ease the pain in their ears due to the lowered pressure. I don't believe this has any basis in fact, however.
    Smoke rising straight into the air means fair weather and smoke hanging low means rain is on the way. This is pretty much the same as with the birds and methane in the swamp. When high pressure approaches, smoke will rise whereas with low pressure it can't rise and tends to lay low.
    Clouds
    An ability to accurately read cloud formations is invaluable in predicting the weather. For a more detailed look into this, consult a good book on the weather. Each type of cloud is caused by specific actions in nature building up to fair weather, rainy weather, tornados, hail, etc. “Mare's tails and mackerel scales make tall ships carry low sails.” Mare's tails are actually cirrus clouds. They are found high in the atmosphere and are pulled into long streamers resembling the tail of a mare. The mackerel scales are altocumulus clouds. If a sailor noticed these, he knew that within 12 to 36 hours, the weather would be way too rough to be out on the open water.
    Plants and Animals
    Both of these seem to be uncanny in their ability to predict good and bad weather. Dogs and cats are notorious for knowing when a tornado or earthquake is imminent. Birds roost early and feed heavily before a rain or snow, and pigs and squirrels gather more debris to insulate themselves from cold weather.
    Plants and certain fungi such as rainstars can also accurately forecast the certainty of wet and dry weather. Chickweed, dandelions, bindweeds, wild indigo, clovers, and tulips all fold their petals prior to a rain. Rainstars, a type of fungus, open up prior to a rain and close in dry weather. Mushrooms abound when the weather is moist as well as do mosses and seaweeds. In fact, seaweeds exposed on the rocks at low tide seem to swell and rejuvenate in the high humidity proceeding wet weather. When the atmosphere reaches about 80% humidity, the bog pimpernel closes and gives rise to this old weather saying: “Pimpernel, pimpernel, tell me true, Whether the weather be fine or no; No heart can think, no tongue can tell, The virtues of the pimpernel.”
    Long Range Forecasting
    Not all of these sayings hold true every time under every circumstance, but you might be surprised at just how accurate they tend to be. I remember back to the blizzard of 1993 and how amazed my friends were when the previous fall I was able to predict to the week that we would be having an enormous snowfall that spring. To say the least, there were a lot of surprised people when we ended up being snowed in for a week with the blizzard of the century.
    There are a lot of signs for forecasting the weather a long way out with some of them being more accurate than others, but with all of them being controversial. I agree with the folklore that says you can figure on a bad winter if there is a heavy crop of acorns, and animals put on heavy coats or store up a lot of food. Don't forget the woolly worm either. Some people believe that the wider the brown part of a woolly worm, the colder the winter, while others believe that the wider the black part, the colder the weather. Go figure!
    This year carefully observe the “signs” and see for yourself how accurate they can be. Whether you are on the trail hiking, canoeing in the middle of the Okefenokee, or simply wondering whether you should head out to the lake on a fishing expedition, this knowledge can not only come in handy, it could potentially be a life saver.
    The above article came from
    http://www.wwmag.net/forecast.htm which is one of my favorite/they also put out the most AWESOME magazine! I just had to share!!!!!
    If it interests you, you can get a mag. subscription @ the linky below:
    http://www.wwmag.net/order.htm
    Overall I think we all should master those most "PRIMITIVE/SIMPLISTIC BASIC SKILLS" 'cause one day the "technology just may not be there" to help you. Just something to think about... Other than that, have a wonderful day... I know I sure am! ;)
    Sincerely,
    ~Wildernessgal~
    Hanzo, Ganado, Brokor and 3 others like this.
  2. CRC
    It always smells like Watermelon to me , right before it is going to rain....People look at me like I'm crazy..until about 30-45 minutes later....
    When it starts raining..... ;-)
    Growing up on the Ocean...I heard the "Red Sky at Night, Sailors Delight....Red Sky at Morning, Sailors take Warning" all my life....I always think about it when I see it too......
    Thanks WG..
  3. ozarkgoatman
    CRC
    I have heard of the red sky as well it seems like it works pretty well.
    I think WG thought I was nuts when we first met and I heard a dove cooing and told her that it would rain withen the next 2 days. The next day it rained. She kind of looked like this. :shock: Also when it looks like it is going to rain look at an ants nest. If it's really going to rain their holes will be very narrow at the surface. If it's not going to rain their holes will be flared out as normal.
    OGM
    Hanzo likes this.
  4. ozarkgoatman
    On high pressure days geese will fly high and on low pressure days they will fly low.
    OGM
    Hanzo and Brokor like this.
  5. I've always noticed that when it is going to snow anywhere from later that night to sometime in the early morning before dawn in any substantial amount, the sky becomes quite a bit brighter than it should be in its normal state starting around dusk (usually accompanied by a red tinge to the sky). So far as I can recollect over the years, this seemed to be accurate to at least 95'ish percent.
    Hanzo and tulianr like this.
  6. tulianr
    Accurate snow forecasting is one area that seems to consistently elude me. The last several serious snow storms that we've had, I have found myself staring at a beautiful starry sky hours before the snow started, thinking, "There's no way it's going to snow by morning." Admittedly, the professional forecasters have been wrong about as often as I have been.
  7. NotSoSneaky
    NotSoSneaky former supporter
    weather-rock-sign.
  8. -06
    -06 Monkey+++
    There is another line to the "weather rock"---if it is gone you just had a tornado. The old Boy Scout Fieldbook had a great section on weather prediction.
    Hanzo, Tully Mars and NotSoSneaky like this.
  9. kellory
    More lines than that. "White on top...it snowed.
    Jumping up and down....it is an earthquake.
    If it is under water.....it's a flood.
    Spinning wildly....tornado.
    If the rope is smoking.....forest fire...."
    Hanzo likes this.
  10. Motomom34
    Where I come from people discuss woolly bear caterpillars because they predict the coming winter. This woolly bear forecast is taken very serious by people.
    I knew someone who had broke a bone & they knew when the pressure was dropping.
  11. Witch Doctor 01
    If it's missing look out for thieving green beanie's...
  12. Motomom34
    Am I the only one that has no clue what this means? What?[dunno]
    KAS and BTPost like this.
  13. BTPost
    The "Weather Rock" Motomom, if the "Weather Rock" is missing.....
  14. Motomom34
    [slow]LOL! Sorry, that was a blonde moment. Duh to me!!
  15. KAS
    KAS Monkey+++
    red sky in morning is complete BS
    in the gulf if the crabsare swimming on the surface its fixin to get ruff
    tulianr likes this.
  16. -06
    -06 Monkey+++
    Old farmers tale--if it is raining and the chickens come off the roost then it will continue to rain. If they wait then the rain will soon stop. Guess they know somehow.
  17. Witch Doctor 01
    if the squirrels tail is bushy and the wooly Bear worms have more black it's gonna be a cold winter....
  18. BTPost
    If it is October, then it is going to snow...... If it is May, the snow is finally going to melt..... If you see lots of squirrels running around in the summer, then it will a good Trapping Season that next winter, for Pine Martin..... ......
  19. Yard Dart
    We had 33 days of rain straight for our state record... weather forecasting is easy up here in Seattle.... Raaaaaaaaaaiiiiiiiiiiiinnnnnn, some cloudy/foggy days, a glimsp of sun and then more rain.... :eek:
    Just for the record, it sounds bad just to keep the tourist from moving here. ;) Our two weeks of summer are awesome!!
    YD
    ColtCarbine likes this.
  20. BTPost
    Rain, rain go away, and come visit Bruce any Day.... The southeast Alaska Rain Chant.....
    KAS and Yard Dart like this.
  1. Dunerunner
  2. Dunerunner
  3. Dunerunner
  4. Motomom34
  5. Gator 45/70
  6. Big Ron
  7. john316
  8. Motomom34
  9. Big Ron
  10. Motomom34
  11. oldman11
  12. HK_User
  13. Yard Dart
  14. Gator 45/70
  15. Motomom34
  16. Motomom34
  17. survivalmonkey
  18. Thunder5Ranch
  19. Motomom34
  20. survivalmonkey
