What's sulphur good for?
Discussion in 'General Survival and Preparedness' started by Blackjack, Oct 18, 2007.
  1. Blackjack
    Blackjack Monkey+++
    I ask about sulfur (sorry I misspelled the title) because I was watching an episode of Jericho, and there was a list of needed items on the show.
    The list was: (what I can remember)
    Salt
    Morphine
    Antibiotics
    Iodine
    Sulfur
    I understand the others completely, but why sulphur?
    What can it be used for, and how can you get it?
    And Iodine?..... just an antiseptic right?
  2. Tracy
    Isn't sulfur used to make black powder?
  3. ghrit
    Yes, but there are medicinal purposes, all of which (if I ever knew) are forgotten.
  4. RightHand
    IIRC sulfur drugs were used to treat UTIs
  5. ghrit
    Sulfa, as in sulfanomide (? spelling is off?) was used to treat open wounds, not sure straight sulfur will do the same thing. Too lazy to google it up tonight.
  6. hartage
    hartage Monkey+++
    So many skills and knowledge that we have lost. I was thinking about the sulfer thing for a while and could not come up with a single thing.
    I just saw "alone in the wilderness" the full film. It never dawned on me that you can make all the things the guy made from scratch. The things I (most of us) would have to re-learn if the shtf were to really happen. Even if I have the tools he had I lack the knowledge and skill to use them effectively. The sulpher thing.... what other knowledge do I lack ?
  7. Quigley_Sharps
    <TABLE style="MARGIN-TOP: 1px; MARGIN-BOTTOM: 5px" cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD>
    Making black powder
    The practice of making black powder (often abbreviated 'BP')is often oversimplified in textbooks. Merely mixing the components, potassium nitrate, charcoal and sulfur, does not result in real black powder. The mixture this obtained is called 'green powder' or 'polverone'. It burns relatively slowly and leaves a lot of solid, unburned, material (residue). 'Real' blackpowder burns far more rapidly, leaving almost no residue. Its properties are very different from polverone. Making black powder at home takes some effort. It will require the use of a piece of equipment called a ball mill and can be produced by two methods. Either of the two methods described below is of suitable quality for most common purposes. The powder could be further improved by pressing and corning, if required, but this will not be described on this page. The components
    The standard formulation for black powder is: 75 parts potassium nitrate, 15 parts charcoal and 10 parts sulfur (as always, all parts are by weight).
    You can find these chemicals at www.skylighter.com
    . Which method to use
    There are two methods to make BP: The ball mill method and the precipitation (or 'CIA') method. You'll need a ball mill in any case. While both methods work, they each have their own advantages and disadvantages. The main disadvantage of the ball mill method is that it is essential that you have a safe place to let your mill do it's work. You need a place with no buildings, people or animals whatsoever in the neighbourhood, and you need to be able to turn it on and off remotely. It also makes a lot of noise. Advantage of the ball mill method is that it is less laborous. You can simply charge your mill with the ingredients, turn it on, do something else for a couple of hours and you're done. The CIA method is much more work: you first mill the charcoal and sulfur together (just like you would with the ball mill method), but this is followed by dissolving the potassium nitrate in hot boiling water which is then mixed with the milled charcoal/sulfur mixture. The potassium nitrate is then precipitated from the solution by mixing with ice cold isopropyl alcohol. This is followed by filtering (messy) and drying (takes a long time, and a good place with no ignition sources, since there is a flammable liquid involved).
    1. Take your raw charcoal and crush it with a hammer between two sheets of paper. Wear old clothing and do this outside, since it is very messy. Sieve the charcoal through a coarse sieve (about 30 mesh).
    2. Weigh the charcoal. To every 100 grams of charcoal, add 67 grams of sulfur, and fill 1/4th of your ball mill with this mixture. Put the media in and let the mill run for 3 hours.
    3. When you open your mill, you should find an incredibly fine black/greyish powder. Sieve this to get the media of the mill out, and weigh it. In a separate container, place 75 grams of potassium nitrate for every 25 grams of charcoal/sulfur powder you have. Put the potassium nitrate in your ball mill, and mill it for 3 hours. You should have a very fine white/greyish powder.
    4. Now mix the charcoal/sulfur mix with the potassium nitrate. Don't bother to mix it very thoroughly, since that will happen in the mill soon enough. To this mixture, add 6% of water. I spray it over the powder that I spread out on a sheet of paper to make sure all of it becomes wet. Put the wet powder in your mill and let it run for 5 hours. Every hour or so, check to see if the powder is still wet. If it dries out the risk of accidential ignition greatly increases.
    5. Sieve the powder to get the media out, spread it out on a large sheet of paper and let it dry. If possible in the sun. Needless to say you shouldn't heat it in order to dry it more quickly, just be patient.
    6. When dry, sieve the black powder through a few sieves to get several fractions for different purposes.
    The precipitation method
    2. Weigh the charcoal. To every 100 grams of charcoal, add 67 grams of sulfur, and fill 1/4th of your ball mill with this mixture. Put the media in and let the mill run for 8 hours.
    3. While the mill is running, place 600 ml isopropylalcohol in a large container for every 100 grams of charcoal/sulfur mix you have, and place it in the fridge.
    4. When you open your mill, you should find an incredibly fine black/greyish powder. Sieve this to get the media of the mill out, and weigh it. In a separate container, place 75 grams of potassium nitrate for every 25 grams of charcoal/sulfur powder you have. Put the potassium nitrate in an old pan, and add 40 ml tap water for every 100 grams of potassium nitrate.
    5. Place the pan on the stove and bring it to a boil while continuesly stirring. When the solution starts boiling, start adding small amounts of water while stirring all the time untill all the potassium nitrate has dissolved.
    6. Add an extra 10 ml tap water and the charcoal/sulfur mixture to the boiling potassium nitrate solution. Stir the charcoal/sulfur mixture in the solution. Make sure there are no dry clumbs left.
    7. By now, your isopropylalcohol should have cooled to at least 0 deg C or colder. Take the isopropylalcohol outside, and pour the potasium nitrate solution/charcoal/sulfur into the cold isopropylalcohol. Make sure there are no sources of ignition nearby! Stir for a few seconds.
    8. Cool the mixture again to 0 deg C at the fastest rate you can. The faster the better.
    9. Filter the mixture through an old cloth, and squeeze to get all the liquid out. Discard the black liquid.
    10. Spread the black mush out on a sheet of paper, and dry it in the sun. Don't try to dry it inside since it will produce a lot of flammable vapour from the ispropylalcohol. When it is still slightly wet to the touch, press it through a sieve to corn it. Then dry it further.
    11. When dry, sieve the black powder through a few sieves to get several fractions for different purposes.
    <HR>​
    </TD></TR></TBODY></TABLE><TABLE cellSpacing=0 cellPadding=0 width="100%" align=center bgColor=#333399 border=0><TBODY><TR><TD>[​IMG]</TD></TR></TBODY></TABLE>
  8. sniper-66
    Put it in a pantyhose stocking and when you are getting ready to go out in the woods, thwack it around your boot tops to keep chiggers and ticks out. The military had a liquid version for the same thing. If you eat small amounts of it, you will sweat it out and keep mosquitos off, of course, you will reak of sulfer.
  9. AlterEgo
    AlterEgo Monkey+++
    And if you live in Northeast Fla jou can just drink the water.[LMAO][LMAO]
    AE
  10. Tracy
    I talked to an old farmer who says he uses it for pest (bug) removal. "just put it on a pie tin, light it and get out." He says it'll kill anything alive (including plants) in an enclosed area.
    I looked in a old health encyclopedia and though it explained the need for it and what foods contain it, listed no "recipes" for using it medicinally.
  11. ghrit
    Sulfur and molassas? Heard of that, I have. Dunno what it's good for, but my grandparents had it in the house. Vile tasting. Went on G-pa's wheat germ.
  12. Brokor
    1. Visit Google.com
    2. Enter into searchbox, exactly as follows: "sulfur" + "sugar" + "medicine"
    3. Ask me how I knew that.
  13. sniper-66
    And I just thought it was a rotten fish smell!
  14. Blackjack
    Blackjack Monkey+++
    Ok..... how did ya?
  15. Seacowboys
    we used to burn it for improvised stink-bombs (rotten eggs) when I was a kid.
  16. Seacowboys
    Applications
    In the late 18th century, Furniture - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Ambox_globe_content.svg" class="image"><img alt="Globe icon." src="http://upload.wikimedia.org/wikipedia/commons/thumb/b/bd/Ambox_globe_content.svg/48px-Ambox_globe_content.svg.png"@@AMEPARAM@@commons/thumb/b/bd/Ambox_globe_content.svg/48px-Ambox_globe_content.svg.png makers used molten sulfur to produce decorative Inlay - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:3rd_century_BC_Eastern_Zhou_bronze_and_silver_flask.jpg" class="image"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/4/4a/3rd_century_BC_Eastern_Zhou_bronze_and_silver_flask.jpg/170px-3rd_century_BC_Eastern_Zhou_bronze_and_silver_flask.jpg"@@AMEPARAM@@commons/thumb/4/4a/3rd_century_BC_Eastern_Zhou_bronze_and_silver_flask.jpg/170px-3rd_century_BC_Eastern_Zhou_bronze_and_silver_flask.jpg in their craft. Because of the Sulfur dioxide - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Sulfur-dioxide-2D.svg" class="image"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/e/e4/Sulfur-dioxide-2D.svg/125px-Sulfur-dioxide-2D.svg.png"@@AMEPARAM@@commons/thumb/e/e4/Sulfur-dioxide-2D.svg/125px-Sulfur-dioxide-2D.svg.png produced during the process of melting sulfur, the craft of sulfur inlays was soon abandoned. Molten sulfur is sometimes still used for setting steel bolts into drilled concrete holes where high shock resistance is desired for floor-mounted equipment attachment points. Pure powdered sulfur was also used as a medicinal tonic and laxative.
    Sulfur has many modern industrial uses. Through its major derivative, Sulfuric acid - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Sulfuric-acid-2D-dimensions.svg" class="image"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/8/8b/Sulfuric-acid-2D-dimensions.svg/200px-Sulfuric-acid-2D-dimensions.svg.png"@@AMEPARAM@@commons/thumb/8/8b/Sulfuric-acid-2D-dimensions.svg/200px-Sulfuric-acid-2D-dimensions.svg.png (Hydrogen - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Hexagonal.svg" class="image" title="Hydrogen has a hexagonal crystal structure"><img alt="Hydrogen has a hexagonal crystal structure" src="http://upload.wikimedia.org/wikipedia/commons/thumb/c/c2/Hexagonal.svg/26px-Hexagonal.svg.png"@@AMEPARAM@@commons/thumb/c/c2/Hexagonal.svg/26px-Hexagonal.svg.png<sub>2</sub>SOxygen - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Cubic.svg" class="image" title="Oxygen has a cubic crystal structure"><img alt="Oxygen has a cubic crystal structure" src="http://upload.wikimedia.org/wikipedia/commons/thumb/5/55/Cubic.svg/26px-Cubic.svg.png"@@AMEPARAM@@commons/thumb/5/55/Cubic.svg/26px-Cubic.svg.png<sub>4</sub>), sulfur ranks as one of the most important industrial raw materials. It is of prime importance to every sector of the World economy - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Ambox_outdated_serious.svg" class="image"><img alt="Ambox outdated serious.svg" src="http://upload.wikimedia.org/wikipedia/commons/thumb/8/8f/Ambox_outdated_serious.svg/40px-Ambox_outdated_serious.svg.png"@@AMEPARAM@@commons/thumb/8/8f/Ambox_outdated_serious.svg/40px-Ambox_outdated_serious.svg.png.
    Sulfuric acid production is the major route in industrial sulfur chemistry on the way to many end-uses, and production and consumption of sulfuric acid has been regarded as one of the best indices of a nation's industrial development. [1]. For example, more sulfuric acid is produced in the United States - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Flag_of_the_United_States.svg" class="image" title="Flag of the United States"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/a/a4/Flag_of_the_United_States.svg/125px-Flag_of_the_United_States.svg.png"@@AMEPARAM@@commons/thumb/a/a4/Flag_of_the_United_States.svg/125px-Flag_of_the_United_States.svg.png every year than any other industrial chemical; although interestingly the rate of increase of U.S. production has encountered shocks since the mid 1960s, mirroring U.S. loss of industrial post-World War II - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Infobox_collage_for_WWII.PNG" class="image"><img alt="Infobox collage for WWII.PNG" src="http://upload.wikimedia.org/wikipedia/commons/thumb/5/54/Infobox_collage_for_WWII.PNG/300px-Infobox_collage_for_WWII.PNG"@@AMEPARAM@@commons/thumb/5/54/Infobox_collage_for_WWII.PNG/300px-Infobox_collage_for_WWII.PNG world influence. Principal uses for the acid include ore processing, fertilizer manufacturing, oil refining, wastewater processing, and chemical synthesis.
    Sulfur is also used in Battery (electricity) - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Batteries.jpg" class="image"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/3/3b/Batteries.jpg"@@AMEPARAM@@commons/3/3b/Batteries.jpg, Detergent - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Diskflaskor.JPG" class="image"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/3/34/Diskflaskor.JPG/220px-Diskflaskor.JPG"@@AMEPARAM@@commons/thumb/3/34/Diskflaskor.JPG/220px-Diskflaskor.JPG, the Vulcanization - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Roller-hockey-(Quad)-Ball.jpg" class="image"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/8/8e/Roller-hockey-%28Quad%29-Ball.jpg/200px-Roller-hockey-%28Quad%29-Ball.jpg"@@AMEPARAM@@commons/thumb/8/8e/Roller-hockey-%28Quad%29-Ball.jpg/200px-Roller-hockey-%28Quad%29-Ball.jpg of rubber, Fungicide - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Question_book-new.svg" class="image"><img alt="Question book-new.svg" src="http://upload.wikimedia.org/wikipedia/en/thumb/9/99/Question_book-new.svg/50px-Question_book-new.svg.png"@@AMEPARAM@@en/thumb/9/99/Question_book-new.svg/50px-Question_book-new.svg.png, ie skin care soaps, and in the manufacture of Phosphate - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:phosphate.png" class="image"><img alt="" src="http://upload.wikimedia.org/wikipedia/en/thumb/b/b1/Phosphate.png/220px-Phosphate.png"@@AMEPARAM@@en/thumb/b/b1/Phosphate.png/220px-Phosphate.png fertilizers. Sulfite - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Sulfite-ion-3D-vdW.png" class="image"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/d/d0/Sulfite-ion-3D-vdW.png/220px-Sulfite-ion-3D-vdW.png"@@AMEPARAM@@commons/thumb/d/d0/Sulfite-ion-3D-vdW.png/220px-Sulfite-ion-3D-vdW.png are used to http://en.wikipedia.org/wiki/Bleach_(chemical) Paper - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:ManilaPaper.jpg" class="image"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/b/ba/ManilaPaper.jpg/220px-ManilaPaper.jpg"@@AMEPARAM@@commons/thumb/b/ba/ManilaPaper.jpg/220px-ManilaPaper.jpg and as a preservative in Wine - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:White_Wine_Glas.jpg" class="image"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/7/71/White_Wine_Glas.jpg/140px-White_Wine_Glas.jpg"@@AMEPARAM@@commons/thumb/7/71/White_Wine_Glas.jpg/140px-White_Wine_Glas.jpg and dried Fruit - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Culinary_fruits_front_view.jpg" class="image"><img alt="" src="http://upload.wikimedia.org/wikipedia/en/thumb/2/2f/Culinary_fruits_front_view.jpg/250px-Culinary_fruits_front_view.jpg"@@AMEPARAM@@en/thumb/2/2f/Culinary_fruits_front_view.jpg/250px-Culinary_fruits_front_view.jpg. Because of its flammable nature, sulfur also finds use in Match - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Streichholz.jpg" class="image"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/c/c1/Streichholz.jpg/220px-Streichholz.jpg"@@AMEPARAM@@commons/thumb/c/c1/Streichholz.jpg/220px-Streichholz.jpg, Gunpowder - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:pyrodex_powder_ffg.jpg" class="image"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/d/df/Pyrodex_powder_ffg.jpg/220px-Pyrodex_powder_ffg.jpg"@@AMEPARAM@@commons/thumb/d/df/Pyrodex_powder_ffg.jpg/220px-Pyrodex_powder_ffg.jpg, and Fireworks - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Question_book-new.svg" class="image"><img alt="Question book-new.svg" src="http://upload.wikimedia.org/wikipedia/en/thumb/9/99/Question_book-new.svg/50px-Question_book-new.svg.png"@@AMEPARAM@@en/thumb/9/99/Question_book-new.svg/50px-Question_book-new.svg.png. Sodium or ammonium Sodium thiosulfate - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Sodium-thiosulfate-3D-vdW.png" class="image" title="Sodium thiosulfate"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/e/e3/Sodium-thiosulfate-3D-vdW.png/200px-Sodium-thiosulfate-3D-vdW.png"@@AMEPARAM@@commons/thumb/e/e3/Sodium-thiosulfate-3D-vdW.png/200px-Sodium-thiosulfate-3D-vdW.png is used as photographic fixing agents. Magnesium sulfate - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Magnesium_sulfate_anhydrous.jpg" class="image" title="Anhydrous magnesium sulfate"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/e/ec/Magnesium_sulfate_anhydrous.jpg/200px-Magnesium_sulfate_anhydrous.jpg"@@AMEPARAM@@commons/thumb/e/ec/Magnesium_sulfate_anhydrous.jpg/200px-Magnesium_sulfate_anhydrous.jpg, better known as Magnesium sulfate - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Magnesium_sulfate_anhydrous.jpg" class="image" title="Anhydrous magnesium sulfate"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/e/ec/Magnesium_sulfate_anhydrous.jpg/200px-Magnesium_sulfate_anhydrous.jpg"@@AMEPARAM@@commons/thumb/e/ec/Magnesium_sulfate_anhydrous.jpg/200px-Magnesium_sulfate_anhydrous.jpg, can be used as a Laxative - Wikipedia, the free encyclopedia, a bath additive, an Exfoliation (cosmetology) - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Skin.svg" class="image"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/6/6d/Skin.svg/200px-Skin.svg.png"@@AMEPARAM@@commons/thumb/6/6d/Skin.svg/200px-Skin.svg.png, a Magnesium - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Hexagonal.svg" class="image" title="Magnesium has a hexagonal crystal structure"><img alt="Magnesium has a hexagonal crystal structure" src="http://upload.wikimedia.org/wikipedia/commons/thumb/c/c2/Hexagonal.svg/26px-Hexagonal.svg.png"@@AMEPARAM@@commons/thumb/c/c2/Hexagonal.svg/26px-Hexagonal.svg.png supplement for plants, or a Desiccant - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Toluene_with_sodium-benzophenone.jpg" class="image"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/6/60/Toluene_with_sodium-benzophenone.jpg/220px-Toluene_with_sodium-benzophenone.jpg"@@AMEPARAM@@commons/thumb/6/60/Toluene_with_sodium-benzophenone.jpg/220px-Toluene_with_sodium-benzophenone.jpg. Sulfur is used as a light-generating medium in the rare lighting fixtures known as Sulfur lamp - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Hill_AFB_hangar_sulfur_lamps.JPG" class="image"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/6/63/Hill_AFB_hangar_sulfur_lamps.JPG/150px-Hill_AFB_hangar_sulfur_lamps.JPG"@@AMEPARAM@@commons/thumb/6/63/Hill_AFB_hangar_sulfur_lamps.JPG/150px-Hill_AFB_hangar_sulfur_lamps.JPG. Elemental sulfur crystals are commonly sought after by rock collectors for their brightly colored Polyhedron - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:pOV-Ray-Dodecahedron.svg" class="image"><img alt="POV-Ray-Dodecahedron.svg" src="http://upload.wikimedia.org/wikipedia/commons/thumb/6/66/POV-Ray-Dodecahedron.svg/120px-POV-Ray-Dodecahedron.svg.png"@@AMEPARAM@@commons/thumb/6/66/POV-Ray-Dodecahedron.svg/120px-POV-Ray-Dodecahedron.svg.png shapes.
  17. Brokor
    I'm a genius. In disguise. And...I am a remarkable googler. Plus, I had a hunch. I don't know, I wasn't expecting anybody to ask. LOL.
  18. FalconDance
    FalconDance Neighborhood Witch
    While sulphur has its uses, all it would do is kill me. I'm one of those weird ones who is highly allergic - to the point that if I drink too much wine (with sulfites), I get really really ill - can't even drink enough to get drunk on :(. Haven't tested it to the full limits to see what the threshold-right-before-death is. Just doesn't seem like a very bright thing to do, ya'know?
    (Lucky for me, there are plenty having very low sulfite content [booze]. And there's always mead - or really high quality ale or...)
    High sulphur water has to be boiled first before I can drink it, can't use sulphur-based medicines, etc. Yeah, it can get fun.
  19. RightHand
    Me too, but it has nothing to do with sulfites LOL
  20. Seacowboys
    If I drink too much wine, I just get happy. I sing and piss in the fire. There is not much that feels better than singing wine songs and pissing in the fire.
